Question about Garmin StreetPilot c550 GPS Receiver
My Garmin c550 just stopped working today. It is about 3 yrs old. If it is a battery, how can I get it replaced? I'm in Orlando, Fl
  • dutchgirl50 Feb 26, 2009
    I have the same garmin and it too is 3 years old and it just stopped working. It is not making the connection somehow. If I turn it on the battery is just about dead because it has been running on the battery instead of the power source in the car. Any ideas?
Mine did the same. Wouldn't power on. The manual says if it doesnt power on when plugged into a power source, reset it.
There is a groove on the faceplate under the Garmin logo. place your thumbnail there and gently pry off the face plate. Look for the reset button on the right side, press it.
The unit should power on for normal use.
http://www8.garmin.com/manuals/StreetPilotc550_OwnersManual.pdf
If you need to re-set it often, update the system software.
Posted on Mar 11, 2009
Where can I find a Samsung repair center? in Orlando, Fl
Best place for Samsung repair (including Samsung Galaxy S3 and Galaxy S2 Screen / Glass repairs) is XpressFix and 1 Hour Cell Phone Repair. They are the place for cheap Samsung repair and Galaxy Glass replacement in Orlando, FL. Samsung Galaxy Screen Repair Orlando or try this site for Samsung Galaxy Glass Repair in Orlando, FL They also offer iPhone repair services.
Sep 03, 2012 | Samsung Galaxy Tab 101 Tablet...
Will not turn on
It is possible that the internal battery has discharged, and is unable to recharge due to a blown fuse inside the cigar lighter plug or a blown fuse in the car's fuse block for the cigar lighter outlet.
  1. Unscrew and remove the silver or black, round end piece.
  2. fileservlet?date=1&kb=%7b6b85cfa0-194d-11dc-44cd-000000000000%7d&id=%7b6e53bea0-6874-11dd-436f-000000000000%7d&ext=jpg
  3. Remove the fuse (glass and sliver cylinder) and replace with a new fuse.
  4. Ensure that the silver tip is placed in the end piece. Screw on the end piece.
fileservlet?date=1&kb=%7b6b85cfa0-194d-11dc-44cd-000000000000%7d&id=%7b6e476290-6874-11dd-436f-000000000000%7d&ext=jpg
Consult your car's owner's manual for locating the fuse block in the car. Both fuses must be good.
If you're unable to power up the c500 outside of the car (running on internal battery) your c550's internal battery may no longer be able to accept a charge. This will require a battery replacement - or use with a cigar adapter only. You may have to return the GPS to Garmin for a battery replacement - but there are some third party battery providers for some Garmin GPS units. If one is available for the c550, you may save enough money to make going the third party route worthwhile.
Please rate this replay if helpful - good luck!
You can download / view a copy of your c550 manual here.
Aug 09, 2010 | Garmin StreetPilot c550 GPS Receiver
Will not charge c550 garmin
OK, THANKS, THE MOST LIKELY PROBLEM HERE IS THE BATTERY IS DEFECTIVE.
Nov 11, 2009 | Garmin StreetPilot c550 GPS Receiver
Battery dead garmin streetpilot c530
you have a battery for the wrong model, I think they also changed the configuration of the same model number so that it had to be returned for proper service.No matter what you do a 3 pin wont fit a 5 pin socket.
Jun 21, 2009 | Garmin StreetPilot c550 GPS Receiver
IS THERE A REPLACEMENT BATTERY AVAILABLE FOR THE STREETPILOT C550
There are replacement batteries available. Don't post in all caps please it is frowned upon.
Jun 02, 2009 | Garmin StreetPilot c550 GPS Receiver
Won't turn on after first time
saw this on a different forum.....I got one for xmass.....hope it doesn't happen to me!!!!!!!!
I apologize for the inconvenience. After further research with our engineers, a problem has been discovered on your C550. A file has been created to stop the unit from turning off and locking up. Please download the new file from your computer to the unit. The file is attached to this email along with instructions on how to get the file into the unit.
The following procedure will update the software in your C550 series and correct the power issue you are experiencing with your Garmin C550 series
1.) Let the Garmin sit without power for at least 24-48 hours.
2.) Plug the C5xx series into the your computer (using a USB port in the back of the computer) with the cable provided with the unit.
3.) After removing the faceplate on the front of the Garmin press and release the reset button. At this time the C550 series will reset and power on.
4.) Save the attached file included in e-mail from Garmin Product Support. Save this file to the desk top on your computer. Note: This will make it easy to find.
5.) Open the My Computer window (by accessing the start menu on the bottom left of your computer screen).
6.) Locate and open the Garmin Mass Storage device.
7.) Locate the Garmin folder and open.
8.) Open the remoteSW folder.
9.) Copy the file that you have saved to the desktop and paste it into the remoteSW folder you have just opened. Make sure that none of the files contained within the remoteSW folder is highlighted, or you will not be able to save the new file.
10.) A message window will pop up asking you to confirm that you want to replace the file; Select Yes.
11.) Disconnect the C550 series from the USB cable and let the unit restart. A message will appear on the screen stating "Updating PLD Software".
Note: the screen will fade out and go blank during this process. Do not be alarmed, this is part of the update procedure, and the screen will return to normal within seconds.
Dec 26, 2007 | Garmin StreetPilot c550 GPS Receiver
Reprogram
go to menu and  where to.>my location.
touch Set Home --select an option
done
Oct 07, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot c550 GPS Receiver Logo
1,149 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
