Question about Plantronics Explorer 220 Bluetooth Headset Wireless Headset
LG Shine won't connect to Plantronics Bluetooth
Have to disconnect the bluetooth, take battery out of phone, wait a couple minutes, then put battery back in and start phone. Bluetooth then connects until I shut it off. Then have to do the process all over again.
Take the metal battery cover off and you shouldn't have a problem. it should connect right away. I guess the metal interferes with the connection. there's no need to take the battery out.
Posted on Apr 15, 2009
How do i connect my plantronics head set to my blackberry phone? I HAVE TRIED THROUGH BLUETOOTH BUT DOESNT seem to be working
It may be that just the sequence of things are not working. Turn your phone off, remove battery, wait about a minute. Replace battery turn phone on. Use this link to the Pairing Guide.
Good luck from Headsets Direct!
Sep 10, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I have an LG phone and my Discovery 925 bluetooth from Plantronics won't connect anymore. When I have it in discovery mode my phones message states "no devices found."
You want to make sure that there is no other bluetooth interference on your phone and follow the instructions on the link for the Plantronics Discovery 925 (see page 4).
Jul 17, 2011 | Plantronics Discovery 925 Bluetooth...
Trying to connect my plantronics bluetooth to my samsung cell phone. I can find my instructions manual to put in the passkey. I tried four zeros, but it did not connect. You you help me, please?
First you want to make sure there is no other bluetooth interference. To reset the phone, turn off your phone, then disconnect and reconnect the battery, this should reset the phone. Then carefully follow the pairing instructions in the Explorer 360 User's Guide, pages 3-5
Apr 20, 2011 | Plantronics Explorer 360 Bluetooth Headset...
Unable to pair LG GM200 bluetooth 2.0 A2DP with Plantronics Pulsar 260. Error: "Request Failed" Please help in connecting this two devices
Each pair of BT enabled phone and headset is a particular world. I don't have the Plantronics, but my LG phone pairs fine with my Lubix stereo headsets. I'll tell you how I managed to pair them: I put my headsets in pairing mode. Then, on my phone, I go to 'Connectivity > Bluetooth > Device list > Options > New'. If my bluetooth stack is off I'm prompted to turn it on. It starts to search for devices, and comes up with my BT headsets' name, I press 'Pair', it prompts me for the pairing code. I enter '0000' (the same code for your Plantronics' headsets, by the way) and Ok. Then, back to the Device list, I select the BT headsets and go to 'Options > Connect'. I'm good to go. After listening to music, I use to go again to 'Connectivity > Bluetooth > Device list', select the headsets and press 'Options > Disconnect'.
Hope it works for you.
Cheers! Carlos
Apr 18, 2010 | LG GM200 Cell Phone
I have lost my lg shine usb cable hoe can i
If you have bluetooth on your computer then you can connect this way, if not go buy one from your local retailer and pair it up with your computer, there should be an option in the PC Suite for your Shine to connect by bluetooth failing this get on Ebay and buy a cable for a couple of quid
Dec 03, 2009 | LG Shine KE970 Cellular Phone
How to connect the LG Voyager - plantronics discovery 925?
From all my research in the past few days (1-11 March 2010) I have found out that bluetooth hands free via bluetooth is not possible with the Motorola Droid or the Eris Droid. The problem is with the Google android operating system not your bluetooth device. After calling Motorola and Verizon tech support, both say that "They are working on it." I really hope they update/fix their os because I really want to buy a couple of their phones. They said to wait until 31 March 2010. Hopefully they will get their act together.
Jun 25, 2009 | Plantronics Discovery 925 Bluetooth...
Pairing LG Shne cu720 to Plantronics Explorer 220
Try holding down the button on head set untill the phone reconizes
Jan 01, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Bluetooth wont stay connected
probably a hardware issue on the phone itself...
i would call up lg support first ask them why is this...
bluetooth does have a 10m range and connecting a bluetooth headset shouldnt be as far as 10m
Aug 21, 2008 | LG Shine CU720 Cellular Phone
Blue Tooth Connection for LG Shine
I have been having the same problem with my 720 trying to reconnect to a bluetooth. I have purchased a Plantronics 220 and also a Motorola one. My phone will connect one time, and shortly after my test call, it will disconnect on its own, and I cannot get it connected back. I thought it was the bluetooths messing up but actually it is my phone. I have contacted LG about this problem and they told me I would have to send my phone back so they can take a look at it. So you may want to call them and put in Another Complaint.
Jun 18, 2008 | Cell Phones
Lg shine bluetooth problem
Alright so I had the same problem. My solution that works most of the time is this: while bluetooth is off, in the phone, go to menu, bluetooth, settings, and play around with the device name (instead of LG TU 720 make it LG TU or fucklg for instance) pretty much anything should do.. change the memory storage maybe between memory card and handset.. try turning the phone off and taking out the battery too, maybe even the sim card if you're really desperate, or all of the things i just mentioned in order. Replace everything, reboot, turn on bluetooth and try pairing.. This works with my plantronics headset now (there was a good few months where i gave up on it). It's a pain in the *** but it gets the job done for me... try it out.
May 13, 2008 | LG Shine KE970 Cellular Phone
Plantronics Explorer 220 Bluetooth Headset Wireless Headset Logo
178 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
