Question about Coleman Powermate 5000W Home Backup Generator #PM0435
Power cord hook up color code red white black green where do they go to in the 220 socket
    Scholar:
  • 45 Answers
If your plug and outlet are 4 blade, two blades will be flat, the black will connect to one flat blade and the red will connect to the other flat blade,makes no differance to which,the white will connect to the middle blade with a silver color screw terminal,the others will always be brass in color!,the green will connect to the blade that is either "L" shaped or round.looking at the male plug from the blade side it looks like a crows foot,top left blade will be at 11 oclock,right blade will be at 1 oclock,these two are critical, one must be black the other must be red, center is white, other is green. good luck.
Posted on Feb 20, 2009
Need to know how to hook up to 220 power supply what wires go where we got a red wire,black,white, and green which is ground can u help?
L1
L2
L3
Neutral
Earth
North America
Black
Red
Blue
White
Green
There is no blue cable in a 220V, so you have only; white, black, red and ground always green colored wire.
Looking your plug frontal side.
Green Ground on top (semi-circle)
black on left
red on right
white on bottom (neutral).
Jan 10, 2011 | Miller Bobcat 3 Phase Welder Generator...
What colors match up for a 4 prong wire plug on the maytag alantis dryer
If you're speaking of replacing the terminal connection where the 220 hooks to the wire it should be left to right >>> black, white, red, white ground to dryer frame screw.
If the power cord itself it's the same accept the green wire grounds to the frame insteag of the seperate white on the 3 prong configuration. Red and black interchange, white takes center of the three nuts (should be silver but not necessarily. Make sure green is conncted to the frame.
Good luck and bve careful.
Dec 11, 2010 | Dryers
We just moved into an older home, the 220 dryer outlet is set up for prongs. I went to a hardware store and bought a Magnum 4-wire cord that matches the outlet. My dryer has a 3 wire cord. I removed the...
The red and black are the "hot" wires... white is the neutral and the green gets hooked to the frame of the dryer...
Here is a tip that gives more detail...
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Aug 28, 2010 | Faber Pro Magnum 605989 Kitchen Hood
I am trying to convert the 3 prong cord to a 4 prong cord and don't know where to put the grounding terminal from before...it was on the dryer internally.   I got everything hooked up correctly (i...
The following link explains how to correctly install a 220VAC appliance cord to your dryer:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
Read through the instructions provided and let me know if you have questions. This advice is how to convert from a 3 prong to a 4 prong appliance cord. You simply match the corresponding colors of the wires on the cord you intend to attach to the matching colors at the terminal block on the back of the dryer. If the wires are not color coded at the terminal block, the outer two wires (left and right) are the HOT leads, the center wire is the Neutral. Make sure the neutral and ground wires remain independent of each other in a 4 wire configuration. The green wire should be terminated on a ground lug on the equipment cabinet while the neutral is terminated at the terminal block.
Let me know if you require further assistance. I hope this help you.
Feb 09, 2010 | Whirlpool WED5500S Electric Dryer
Connecting 220 plug to 185SG welder- Power cord on welder, Black,Red and yellow w/grn stripe Plug- Black, Green and white Which wires do I hook together?
are you sure you have the right plug?wite wires are normaly found only on 120v and 347v systems. but if it realy is 240v then black to black, red to wite and yellow/green to green.
Oct 24, 2009 | Clarke Power Products Mig/Fluxcore 180En...
Hooking a 4 wire power cord to a dryer that came with 3 prongs
*First ; before starting unplug unit or shut off breaker.
you should be able to match up color for color on your dryer, the fourth wire, green (ground) screws to the chassis, or cabinet. if your wires aren't coded as you say, it is red, white and black, left to right. see picture I've supplied.981ddeb.jpg
hope that helps
good luck
Sep 26, 2009 | Whirlpool LER4634J Electric Dryer
Replacing front turn signal socket on 1990 dodge shadow
Okay. Hook black to black.
Green to green with white stripe.
Yellow to red with white stripe.
That should work. Nothing is going to blow up if it's wrong. It just won't work.
May 15, 2009 | 1990 Dodge Shadow
How to hook up a cord to the maytag neptune dryer color codes
these are single phase so just copy red to red black to black white to white and green is ground
May 04, 2009 | Maytag Neptune MDE5500AY Electric Dryer
We bought an electric dryer from sears outlet
220 Cords are usually color coded - BLACK, WHITE, RED, GREEN for Ground. Inside the dryer where you connect the wires should be the same colors. Just put the Black with the Black and so on. Make sure the plug is for a dryer and not a stove.
Mar 26, 2009 | Kenmore Dryers
Wiring directions for Kenmore 800 Dryer
Hello mynexthome,
Sounds like you did everything correctly however it is possible the wall receptacle may be miswired. The white wire is the neutral, black and red are the line feeds ( hot ) and green is ground. If you are sure the receptacle is wired correctly and that the power cord is wired as you say it is, then there may be an internal issue with the dryer..or some packing material was not removed and is burning off. ( make sure the drum can spin freely and you aren't smelling a belt burning) The red and black are normally on either side of the neutral but you should match the color code on the terminal block on the dryer. Hope that helps...
Regards,
Rick
Jan 03, 2009 | Dryers
Coleman Powermate 5000W Home Backup Generator  #PM0435 Logo
272 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
