Question about GE Spacemaker JVM1640SJ Microwave Oven
I HAVE A GE MICROWAVE PROFILE MODEL JES2251SJ02 IT WAS WORKING PERFECTLY AND THEN IT STARTED TO ONLY OPEARTE FOR SIX SECOND AND SHUT OFF
  • bjfitx Apr 14, 2009
    No matter what cooking time you set (over 30 seconds), the microwave will run for 27 seconds and then just stop. It does not heat during the 27 seconds either!!!
5 Suggested Answers
MicrowaveSvc
  • 8865 Answers
SOURCE: GE Profile Model # JVM2070SH001
Sadly, we hear of this over and over.
This is usually due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
GE had a campaign (but not a recall, mind you!) covering several models.
Details are in their bulletin at http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf
Even if your model is not on the list, the same problem can occur, requiring a kit. I just think the difference is that GE has stopped paying for the repairs.
The parts kit (that GE used to pay for) is part # WB27X10489 and is shown here: http://207.234.249.73/mwd/wb27x10489_ge_mag_stir_kit.jpg
(Your model may use a different kit - this is shown for illustration purposes only).
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 09, 2008
SOURCE: GE Profile Spacemaker 2.0 Microwave
Hey, "timebomb" thanks for that comment but there is absolutely no food stuck there but we did fix it using another persons comments. We went to a local computer repair store and they GAVE us that anti static paper for FREE and we opened up the digital display and covered the inside back portion with the paper that I mentioned and IT TOTALLY WORKED our microwave has been working perfect now since we fixed it on like January 3rd, 2008. We are shocked!!!!!!! Boy, my interned bill paid for itself this month because after doing research we knew that it was going to end up needed a new magnatron plus labor costs, I would have hated to see that bill. WHAT A JOKE, GE definitely knows that this is happening. They SUCK!!!
Posted on Jan 14, 2008
  • 43 Answers
SOURCE: GE Profile turned off as soon as it start
If you can program it and the problem occures when you push START. Then the problem is a door switch, or the control panel not having a completed circuit. Think of your control panel as an off-on switch.COOK, the control panel switches on for 100% of the time programed. DEFROST,The control panel turns the Cook-Relay on for 30% and off for 70%, on, off, on, off,for the time you programmed for DEFROST. This is how it works. There is no lowering of the output. The output is 100% anything other than COOk is done in % of time on, % of time off. This is why you can hear a "Bump" when Defrosting. The "Bump" is the Cook-Relay sending power to the High Voltage Side, 30% on, 70% off.
Posted on Jan 26, 2008
MicrowaveSvc
  • 8865 Answers
SOURCE: G.E. Profile Microwave Model JVM2070SH01 turn table does not turn.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 16, 2008
MicrowaveSvc
  • 8865 Answers
SOURCE: microwave dead even though power works
It sounds like the magnetron overheated and opened the thermal fuse on the magnetron.
This can be caused when the internal cooling fan is not running or by a magnetron that is failing.
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
It is vital that the cooling fan runs, or the magnetron will be destroyed.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can also find helpful exploded view diagrams and order parts by entering your full model number here.
The magnetron will have a 5 to 9 year warranty. Your manual will tell you that.
You can download GE owner's manuals and installation instructions here.
If needed, GE may send you a replacement magnetron. GE Customer Service is here.
Posted on Dec 08, 2008
GE Profile Microwave, model JES2251SJ02, just stopped working.
1= reset the c.breaker from your home see if are tripped and reset.
2= open for thermal fuse open, test continuity with DVOM OR VOM and replace.
3) test the power cord for open or broken or break.
4= check the switch for door maybe is open must be continuity until 0 , or swtich defective see the diagram attached. God bless you
Jul 13, 2012 | Microwave Ovens
I have GE Profile microwave model PVM1870SM1SS and last week while running, suddently it shut off. There is no power, display buttons and stopped running. Please advise.
From the description a major part has failed, the magnetron is suspect because it suddenly shut down in cycle, if the unit is less than 7 years old it probably has a inverter board and tends to fail, also there is the possibility the keypad control board has stopped working. The microwave in my opinion is worth getting checked out and repaired, but it will be expensive.
Apr 03, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
Ge profile jes2251sj02
If it's heating and shuts down, the thermal fuse may be defective, monitors the temperature of the magnetron, or the magnetron is overheating.
Mar 23, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Store on top microwave OK?
Who or from where did you encounter this notion? Only if there are air vent slots on top that might get blocked, otherwise placing items on top is fine.
Oct 11, 2009 | GE Microwave Ovens
Microwave dead even though power works
Dec 04, 2008 | Microwave Ovens
No more heating, GE Profile Microwave JVM 1870CF02
I think its the mag tube, mine went out the same way. GE will provide the mag tube for free just call them...have a local ge certified tech out to put it in.
Aug 31, 2008 | GE JVM1850 1000 Watts Microwave Oven
Model #JES2251SJ02 trips immediately 20 amp circuit breaker. How many amps does this microwave need to work properly?
I called Public Service and they suggested either a dedicated line or upping tha amps of that c-breaker. I need to call an electrician to help me decide which is best for my house.
Aug 20, 2008 | GE Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
857 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
