Question about IBM ThinkPad T30 2366 Notebook
T30 wil not boot. ligts up then nothing. remove power to reboot
I have the same problem wiht no fix. i went to replace the monitor cable as the screen back light stopped working. Once i did this I press the power button and it goes through the noral light sequence and when the Z light comes on and the computers stops booting. then when i press the power button to try to boot again nothing happens ( no lights or nothing). I switched the cables back and I have the same problem. It seems somthing else is out of place, but i'm not sure what it could be. To reboot i have to remove the AC power and the battery for 10 seconds and then it will attempt to boot again.
  • thinkpadict May 04, 2009
    I have a ThinkPad T30 2366-91U, which displays the same problem as yours.
    The only way to revive the laptop is to disconnect the battery andcharger and connect an external monitor to laptop back in the blueconnector. Then press the button that is activated when you close thelid and turn on the laptop. However, this only works while I have anexternal monitor.
    When I switch between CRT/LCD (Fn+F7), laptop immediately shuts down :(
Toshiba a305 s6841 wihte screan
White Screen usually means the screen is bad. Get ready to replace it. If you system seems like it booted up all the way but the screen is white, more than likely the screen is bad.
Plug in an external monitor and see if thedisplay shows up on it. It can be any kind of monitor even the old big fat crtmonitors as long as it has a vga cable to connect to your computer's vgaport. If so that proves your video card is ok. The video will showon most systems when you reboot without you having to do anything. Some systemswill require you to hit the FN (Function key) + F1 thru F12. Hold downthe FN key then hit the correct key for displaying on the monitor (F1 thruF12). The correct key will normally have CRT/LCD on it or it will havethe icon of a display.
Apr 26, 2012 | Computers & Internet
SCREEN WENT BLANK ON MY HP PAVILION LAPTOP. REBOOTED AT LAPTOP BOOTS UP FINE, BUT STILL HAS BLANK SCREEN. AUDIO WORKS, AND CAP LOCK AND NUM LOCK FLASH. dtcorman@comcast.net
HI,
Do a power drain, this may cause by an electrical charge in the motherboard itself,Im Not really sure how it affects the display of the computer but this method usually fix such problem like that, First, removed the battery then unplugged the AC adapter the press and hold the power button or the ON/OFF button for at least 30 seconds then connect the power supply back to your computer then turn it back on, if nothing happens,there is a possibility that the problem is with the LCD or monitor itself, maybe it will need a replacement...
Hope this will help...Your response is very much appreciated...
Jan 21, 2011 | Computers & Internet
My computer is not starting up when i turn the power on. It will turn on but will anthing but a black screen. This screen has no backlight. Also, nothing seems to be working other than the power. The hard...
few things to try.
remove battery and just boot off power cable.
remove hdd and see if you can get bios screen
reseat memory
if you have 2 memory chips try removing 1 first, same proble the replace and then do the other
try an external monitor or tv
most laptops require this to be enabled by pressing a function key and an F key.
this should either fix or narrow down the faulty part
Nov 15, 2010 | Acer Aspire One PC Notebook
T30 Intermittent Booting Problems - Depending on screen angle
It is issue with the screen cable connection. Replace it. or it is getting chaffed and causing issue in proper signal and power to the screen. It is hardware issue.
Apr 24, 2009 | IBM ThinkPad T30 2366 Notebook
Asus laptop - screen went blank and will not turn back on
I'm assuming your screen shows nothing at all, even the bios or boot screen as it turns on.
If you can hook it up to an external monitor then your video adapter is working. Try using the vga output on the laptop. If it doesn't show anything use you display select feature. I'm not sure what button it is on your laptop but on mine it is Fn+F8 (look for a button that shows a laptop and/or a rectangle).
If you can see it with an external monitor, you should try to uninstall and reinstall the video adapter. After you reboot the computer hopefully it will work.
However, if it still does not work, you will probably need to reseat the monitor cable. Do this by opening the screen panel. on the back is a flat cable tat plugs in to the LCD. This is usually covered by tape. Carefully remove the tape, unplug the cable and plug the cable back in. Don't forget to replace the tape!
I have fixed two computers in the last two weeks by reseating this cable.
Hope this helps and good luck!
Jan 10, 2009 | ASUS A8Jm Notebook
PC will not reboot.
Either something has wiped out your operating system and you need to reformat the hard drive and reinstall it, or your hard drive went Since it worked fine the day before and just did this right away, my guess it that your hard drive went bad. But you can try both options though. Hope this helps.
Sep 13, 2008 | IBM ThinkPad T30 2366 Notebook
T30, replaced fan, no boot, no beeps
Did you replace the fan because of a no start problem, or something else?
Aug 30, 2008 | IBM ThinkPad T30 2366 Notebook
T30 boot problemos screen.
you have been trojaned hit by spyware
2 main progs. you might want to look for spyware blaster and spybot search and destroy these are freeware and doesnt require signup these will clean your comp of the bugs
May 20, 2008 | IBM ThinkPad T30 2366 Notebook
Thinkpad T30 - LCD Not working
I dropped my laptop and screen was verry hard to see unless u shined a bright light at it. the inverter just under the lcd screen happened to come unpluged. I dont know if i was just lucky or if this has happened to more people. I hope this helps some one else.
May 11, 2008 | IBM ThinkPad T30 2366 Notebook
IBM T30 - no screen - sortof booting
i own a t-30 myself with all the same problems i am reading about not reading ram beeping on startup no screen display but you could here hard drive running before these symptoms started the first symptom i ever noticed was if i picked the unit up with my left hand on the left front corner to move it it would boot down and then would not re boot properly (no screen, beeping) until i would smack the case then it would boot fine note: ram slots are located in the left front corner. I always assumed i had a cold or broken solder joint on the main board the last week the thing started running flakey i noticed i was only reading one of my 256mb ram chips so i powered down switched the two chips to the other ram slots and rebooted i noticed one chip was really warm the other cold the comp. booted up perfect and ran perfect for 2 hrs. same prob. so i bought two new 512mb chips installed the and have had none of the above listed problems ever since
Dec 17, 2007 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T30 2366 Notebook Logo
232 people viewed this question
Top IBM Computers & Internet Experts
joecoolvette
joecoolvette
Brian Sullivan
Brian Sullivan
Jax Planet
Jax Planet
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
