Question about Samsung LE32R73BD 32 in. HD-Ready LCD Television
Intermittently, picture seems to break up into
Samsung lcd LA40F8IBDX intermittently, picture seems to break up into vertical panels. each of these panels has streaks running horizontally. It i turn the tv off for a while and turn it on, then sometimes picture is fine again for an hour or so then streaks start again.
    Problem Solver:
  • 13 Answers
Replace the cable from the source. if the images tiles up it could be the cable and I suggest doing this first: replace the cables, they are the lowest cost to check, and in some cases the cable company will replace the length of cable from the TV to the wall for free (or part of your monthly payment). You could always make your own the stuff for that can be found on sites like www.compressionconnector.com of course you could always buy the cable if needed. I am assuming this is occuring during normal TV viewing. if it occurs while watching DVDs or from other sources you likely have a problem with your TV and may need to get it repaired.
Posted on Feb 19, 2009
My Vizio E470i-AO has a light gray horizontal streak about 6-inches wide that runs across the entire screen with a tapered vertical tail about. We can watch TV, but the picture is not as sharp.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 24, 2015 | Vizio Televison & Video
LNS4695DX/XAA Samsung tv vertical and horizontal lines on picture - all components
Thats usually caused by the Tconn board and or its connection also samsungs have been plauged with tab bond issues with the LCD panel itself. Send a pic of the issue to customerservice@tvrepairworld.com and they will be able to tell you whats happening with it be sure to include the model number with the pic
Mar 13, 2012 | Samsung Televison & Video
I am getting muti- colored streaks across the screen in various colors.
In what way are you getting these streaks? horizontal, vertical? Are they stationary or do they move with the picture?
Jan 10, 2011 | Samsung LN46A650 46 in. LCD HDTV
I have the same problem with a Toshiba RGZA 46RV535U purchased 2/2009. My picture gets darker in the center 1/3rd of the screen intermittently. I have removed and reconnected all cable connections on the...
The tubes are horizontal but require disassembling the cover and the inverter
board completelyfrom the chassis. There were 17 of these flourescent tubes stretching the ful length horizontally. They are so fragile.
Jan 01, 2011 | Toshiba Regza 46RV535U 46 in. LCD HDTV
Mt 32 inch Bush lcd has a yellow streak running vertically through the picture. Is it worth getting it repaired ?
A yellow streak down the middle of an LCD Direct view TV (Not projection) is almost 100% the LCD panel. NO, just buy a new set.
Mar 30, 2010 | Televison & Video
Dark shadow-like vertical streaks thru LCD screen (Sharp)
Hi, I have a Sony Grand Wega LCD Projection TV that has a blotted gray streak across the front of the screen. I only use a damp cloth to clean the window and that doesn't seem to help. It really shows up on light pictures and is unnoticed when the picture is a little darker. What can I do to fix this problem???
Aug 19, 2009 | Philips 32PF5531D 32 in. LCD Television
Samsung 940NW Streaking
Your description, without a photo of the streaking leaves us to wonder what direction the streaking occurs. If it is vertical, the LCD display has bad edge connections and the only service you can do is attempt to locate the bad connections by pressing the edge of the display till the streaks cease, then locate the portion on the board and solder it. Another type of streaking that cannot be repaired is the actual loss of LCD contrast in the display. The display has to be replaced. Horizontal lines are usually the result of a board issue and the whole board is replaced. The CCFL tubes get yellow tint to them when the get older and that is right after they get brighter.
Mar 02, 2017 | Samsung SyncMaster 940NW
Horizontal streak in screen
Does it only show up on Cable or does it shows on all Dvd, Cable, Sat, etc ?
Jan 09, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Samsung LE32R73BD 32 in. HD-Ready LCD Television Logo
369 people viewed this question
Henry  Thomas
Henry Thomas
