Question about ASUS A8N-SLI Deluxe Motherboard
Boot up I replaced heatsink fan with the zalman.The thing booted up like three times went to bios but could not get it to boot from cdrom.To put in xp.Now it starts but dont speed up like before when it starts & boot worked fine before.I new about the heatsink fan never let it run with out it.at first take out the board put it back in & it would start & go to biosNothing now.Please Help
  • 1 more comment
  • bigguy1967 Feb 19, 2009
    It said put it on 2&3 pin for 15 sec then put it back plug it in & power it up.At first it reset but nothing now.I will try takeing out the bat for a hour.but if it goes i stil got to get it to boot from rom to put in xp.I never had any **** before set the boot order & it was all good thank you much.
    Should you put grease on top of processors then the fan or does it need it?silver grease.
    Thank you.
  • ASUS Master
  • 4,806 Answers
Hi there.
Try clearing the cmos
Boot up - d015d7b.jpg<<<<< you will see in the picture a plastic jumper (in this case coloured green), move it to the other position and hit the on/off button, then put it back in its original position and power up the machine again. Hopefully the issue will have been sorted. If there is no jumper remove the battery for an hour and make sure the power cord is removed from the back before you clear the cmos
Good luck and thanks for using Fixya!!
Posted on Feb 19, 2009
  • Lee Hodgson
    Lee Hodgson Feb 19, 2009
    Yes its silver heat sync compound that goes on top of processors, this ensures that the heat is dispersed evenly
I put in my op sys. disk to reload operating system,its not reading the disk,tried pic cd, working foin .si its not the dvd/cd drive???
eMachines T5048?
Suggest you enter BIOS Setup, and in Boot Options, set the first boot device to CDROM.
This makes the computer boot from the Recovery disk.
How to enter BIOS Setup? (May be called CMOS Setup also, but I don't believe the computer is that old)
Look at the bottom of the monitor screen, as soon as the eMachines logo comes up. It will state what key to press to - enter BIOS Setup.
Usually it's the DELete key, or F2 key,. for eMachines. May be the Tab key.
Window of opportunity went by, and you didn't get into BIOS Setup?
S'okay. We just need to know what key to press, for now.
Got the key written down?
Open the optical drive, and put the Recovery disk in. Close the optical drive tray.
Now hold the Power On button in, and for a count of 10 seconds.
Turns the computer off.
WAIT 1 minute, turn the computer on.
AS SOON AS you press the Power On button, start tapping on the enter BIOS Setup key.
Tap in 2 second intervals.
Hear beeps? Ignore them. They are Stuck Key Error Code beeps, and it is you that is doing it.
Takes a few seconds. Now you should be looking at the BIOS Setup utility, and the Main menu.
BIOS Setup utilities change from computer to computer.
That's because there are 3(?) major BIOS manufacturing companies, and each BIOS has a different version.
(Phoenix/Award and AMI)
The menu headings may go across the top.
Just one example;
Main / Advanced / Power / Boot / Exit
Or they may be listed in a column,
http://www.buildeasypc.com/sw/bios_setup.htm
http://www.computerhope.com/help/phoenixa.htm
(Scroll down a little)
http://www.daossoft.com/documents/boot-from-cd-award-bios-setup.html
When in the BIOS(CMOS) Setup utility, you CANNOT use the Mouse anymore. You have to use the Keyboard to navigate around.
With the menu's going across the top, for example; you would use the Right Arrow key, and highlight -> Boot
Then press the Enter key.
With menus that are in a column, use the Down Arrow key to highlight Advanced, or Advanced BIOS. (Or Advanced CMOS)
Press the Enter key.
You will see - First Boot Device, Second Boot Device, Third Boot Device, and Boot from other.
To the right you will see the various devices, the computer can boot from;
HarDDrive, (HDD-0), CDROM, Floppy, Internet, etc.
You want CDROM to be to the right of First Boot Device.
If the devices are just listed in an order, you want CDROM at the Top.
With First Boot Device, Second Boot Device, etc listed;
Use the Down Arrow, and highlight First Boot Device.
Your cursor will now be in the device order list.
Use the Down Arrow key to highlight CDROM.
Now look at the navigation guide at the bottom.
To move CDROM to the Top, you may press the;
Page Up/Page Down key, or the +/- key. (Plus/Minus key)
Depends on what is listed in the navigation guide at bottom.
(If +/- key just press the - key)
With CDROM at the Top press the Enter key.
Things differ here too;
A small window may come up asking, Save Changes?
It may show F12 - Save Changes
Or it may show a Y for Yes, and an N for No
(Or Yes/No)
If F12 just press the F12 key, and the computer will restart.
If you have the Recovery disk in the optical drive, the computer will now boot from it.
If Yes/No, or Y/N; use the appropriate Arrow key, and highlight Y, or Yes.
(Note: If Y just press the lower case y. The uppercase Y is just shown for clarity)
If the Recovery disk is in the optical drive, the computer will boot from it.
Recovery disk isn't in the optical drive? No sweat. Put it in there.
Now press the CTRL key, ALT key, and DElete key AT THE SAME TIME.
This makes the computer restart.
If you have never approached this procedure before, it probably looks like, "Wa-wa-wa".
(That's what my niece states when I try to explain computer technology. Wa-wa-wa from the Peanuts cartoon. lol!)
You pull up the BIOS Setup utility, and tell me what you see.
You'll be my eyes, and I'll step by step you through it.
We will post back, and forth in a Comment.
Regards,
joecoolvette
Feb 07, 2013 | E-Machines T5048 (7136) PC Desktop
Reset cmos and now it won't showhard driveand it
can u view the HDD in Boot sequence in BIOS boot seq...have u reset the BIOS/COMS using any tools...try reseting the BIOS boot seq to boot from HDD insted of floppy or CDROM...also check how many HDD is displayed in the BOOT seq...the machine normaly boots from HDD 0....
else try to boot from CDROM....and insert a BOOT CD/WinXP cd in the CDROM drive...
Dec 15, 2009 | HP (D7580-60003) Motherboard
I just installed a new hard drive into my gateway desk top and put recovery cd in and its says missing operating system
You will need to go into the BIOS screen and set the first boot device to CDrom. You can get to BIOS when the machine first boots, as soon as you see writing on a black screen press the bottom to get to setup. When you get to the setup screen look for an option to set boot devices or "boot priority". The first boot device needs to be CDrom and the second device can be Hard Drive. Now save the settings. This time on boot the computer will boot to the CDrom restore disk and you can follow its guides to restore your system.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 29, 2009 | Computers & Internet
Still the same problem will not boot
high im josh in cebu phils. the computer will not boot only power A lot of things could be causing this ,try process of elimination,open case ,remove all addin cards except video ,diss connect cd drives and floppy ,unplug mouse and keyboard and boot computer keep adding things back in.one by one put the hardware back in.be sure you conected properl the hardisk. or if still go to bios setup menu then choose boot settings.select hard drive to boot first then save the changes then reboot your pc. good luck
Feb 21, 2009 | ASUS A8N-SLI Deluxe Motherboard
I replaced the heatsink fan it booted up like three times.tryed put load xp wouldnt boot up from cd rom.Iset boot priority to cdrom.I tryed to reset jumper took out bat all night.the first time it booted...
Well, first you should check wether the fan actually starts when you turn on the pc. If it doesnt your cpu will be overheated in no-time, causing the pc to reboot. That fan then probably has the wrong voltage, or requires to much power, which your power supply may not be able to provide.
If it works, you should try to find out how powerful this fan is, meaning how much air it moves per minute. If this fan is less powerful than the previous one, your cpu will be overheated.
If neither of these solutions apply, I guess you should contact your vendor and request replacement. It may be just the fan that's broken.
Feb 20, 2009 | ASUS A8N-SLI Deluxe Motherboard
Instantly shutdown
This sounds like it could be a heat issue. When you're in windows, you're using the processor more than if it just sits idle in BIOS. Using your cpu creates more heat. Make sure there is no dust in the fan or the heatsink on the cpu. Also, remove the heatsink and clean the old thermal grease compound off the heatsink and cpu and reapply fresh thermal grease.
Jun 27, 2008 | Biostar M7VIT 800 (M7VIT8A02) Motherboard
Boot up problem
plz check the first boot device is hard disk in your bios setup if it is not then make it, then put your findings here
May 27, 2008 | Samsung (SC-152) Internal 52x CD-ROM Drive
Boot sequence problem
try booting to DOS screen only by inserting a boot-able floppy disc (I use Win ME disc at this point although my system is also Win XP). Then select "boot with CD-ROM driver". It will detect your CDROM drive and assign a letter. Now insert the CD and boot from there. I have done this sequence many times with no problems.
Jul 13, 2007 | Compaq Armada E500 Notebook
Your CPU may have a problem
Have you removed all memory, other cards and unhooked all other drives to see if a short exists there? With a 300W PS some other component may be pulling too much that the CPU can't start so it tells you the problem is with the CPU or The CPU its refering to is on the video card? Good Luck, Tim
Feb 10, 2007 | Albatron K8T800 (K8X800 PRO LL)...
ASUS A8N-SLI Deluxe Motherboard Logo
64 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
