I have a Sony DVP-NS715P DVD player connected to my Yamaha receiver (using the digital coax only for audio) but my receiver is showing "Pro Logic" on every DVD I play. The menus on the player and on the movies themselves are set to DD. I just switched from an older model Toshiba DVD player that never gave me this problem. Doesn't make sense...?
I have a Sony and I had to enable both dolby digital 5.1 and DTS in the player's setup meny. Note that I said player and not DVD. Imade this mistake. You can select dts till you're blue in the faceon a DVD menu, but won't get it if you don't enable the output in theplayer's menu. Hope this helps. I hate to say it, but youmay need to read the book that came with your player. I did ;-)
John
Gary A. Edelstein <
-- ++++++++++++++++++++++++++++++++++++ RPA - Raggio Pocket PC Applications # ++++++++++++++++++++++++++++++++++++
Was this helpful?
Yes
No
Solution #2
posted on Aug 01, 2007
pandamama - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Some suggestions, which may or may not work:
Check the receiver setup to be sure the digital input you're using for the coax in is assigned to the input switch for the unit and the receiver is set to check for or use a digital audio input. Check the DVD setup menu to set it for bitstream out. Also, if you have the analog L/R audio outs going to the receiver, disconnect them and see if it makes a difference.
Gary E
|Gary A. Edelstein | (remove NO SPAM and .invalid to reply) |"We have met the enemy and he is us." - Walt Kelly's Pogo
sony DVP-NS55P dvd player i am having trouble with it playing any disc it will say loading for 2 min...
(More)
sony DVP-NS55P dvd player i am having trouble with it playing any disc it will say loading for 2 min then display cannot play, i have opened the unit up cleaned the lens multipul times, sometimes it will work for a little bit then freeze and i have to have it reload and it will go back to cannot play
i have a sony dvd player and would like to use my ge universal remote,but i have lost my list of...
(More)
I HAVE A SONY DVD PLAYER AND WOULD LIKE TO USE MY GE UNIVERSAL REMOTE,BUT I HAVE LOST MY LIST OF CODES.
when i insert some original dvd , in the player its showing "cannot play" and on tv its...
(More)
when i insert some original dvd , in the player its showing "cannot play" and on tv its showing "problem in area limitation", so pl send the changes to do , to solve the problem the player is ntpc format which i purchased in "usa" but i am using in india.
We are unable to use this player as the unit initially powers up then 10 seconds later powers down....
(More)
We are unable to use this player as the unit initially powers up then 10 seconds later powers down. What can I do to fix?
