Question about Delta Grinders
Bench grinder is firmly anchored, but still has a terrible vibration, unless I pull forward on the motor. What can I do?
Have you dressed the wheels? If vibration persists:
With the grinder off, spin the wheels by hand and check for sideways movement. If present then this is probably the cause.
I sort mine by inserting paper shims between the washers and the wheel. I do not know whether this is considered "correct" or safe so accept no responsibility.
Posted on Mar 20, 2009
  • 2,176 Answers
I would take a look at the wheels or wire brush before I went any further. Then I would remove both and just run the grinder to see if still vibrates. But usually one or both of the wheels are out of round.
Posted on Feb 19, 2009
Is the 4A912B Dayton 10" 1 HP bench grinder 3 phase or 1 phase?
If the plug on the cord has 2 flat prongs and one round one then its 110 VAC single phase. If the motor has 4 wires then I'd suspect 3 phase. The data plate on the motor will tell you for sure.
Nov 19, 2014 | Bench Grinders
I have a ludell (machine tool) bench grinder. The problem is that the grinder disc will not turn. The motor hums but won't turn. I took the disc off and turned the shaft by hand with the powder on and it...
Ah, the start winding is not operating. When you turn the motor by hand. When the motor speeds up, do you hear a click sound? This is the start winding switch working. There might be a capacitor that is wired in with this switch that is used to start the grinder. If this capacitor is fried, the motor will not start. If the switch is shot, also the motor will not start. There could also be a wire or connector in this part of the motor that is not connected, or fried and not making contact. These are a few things to look for.
Jan 30, 2011 | Grinders
My 6 inch Cummins bench grinder stopped working. When you turn on the switch it only has a quiet hum. Is it the capacitor?
Try wrapping a thin cord around the shaft many times to allow the shaft to be spun in the normal running direction when pulled. Pull sharply on the cord and turn the motor on--if the starting capacitor is bad, the motor should continue to run until shut off. If there is no capacitor, then the motor uses a start winding and a centrifugal switch to start. The switch is supposed to open when the motor comes up to speed. If you used to hear a loud 'click' when the motor was shut off and slowing down, then you likely have the start winding and switch. If the contacts on the switch become burned and not make contact, then it will display the symptoms you mention. You will need to access one or the other end covers to reach the switch. Hope this helps!
Jan 04, 2011 | Delta 23 684 6 Inch Bench Grinder Wheel,...
No control of speed on bench grinder,need schematic
Unless the motor is a brush type universal unit, there is commonly no way to change the speed of an induction motor. There are AC motor speed control units available, but cost more than the grinder as they change the frequency as well as the voltage. There are speed controllable grinders available that use brushes so that simple electronics can control speed. Hope this helps!
Dec 08, 2010 | Craftsman 6" Bench Grinder with Lamp
I have a Taiwan made 1/2 hp bench grinder that wont run only hums and now it wont even run if I spin it by hand and no capacitor. Is it junk now.
Hi there, with out seeing it I`d say your brushes are gone and ceasing. I hope this solves your problem.
May 18, 2010 | Grinders
The motor just sits there and buzzes, when there isn't any electicity bearings turn freely
There is a short internally in the motor. IMO not worth repairing, new bench grinders are pretty inexpensive.
May 14, 2010 | Wilton 17202 8" Bench Grinder
I retrieved a Buffalo bench grinder, Model B-6, from where it had been stored for at least 11 years. Prior to that, I don't know its history. I plugged it in, and it runs. Here is my question: Do these...
A bench grinder would be unlikely to need oiling, but if it has such a provision there would be spring loaded caps or a set screw caps on the motor body near both arbors. The real concern is if the wheels have been compromised by taking a hard bump that could weaken them. This is an unlikely problem if grinder hasn't been dropped or had something heavy drop onto a wheel. If you have no reason to suspect wheel damage, and it runs without squeaking or excessive vibration, and the cord is not damaged, and there are no loose parts on it - then you have nothing to worry about. But you might want to consider "dressing" the wheels. Google "Grinding dresser" and read the Wikipedia article.
Apr 13, 2010 | Grinders
Bench grinder buzzes
The capacitor has failed. Take it out and go to a motor shop for a new one.
Jul 08, 2009 | Black & Decker Saws
Vibration during spin cycle
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 13, 2008 | LG WM2688HWM TROMM SteamWasher
Why does my dw831 grinder keep tripping circuit breakers?
try checking the brushes.
to do this: remove the 2 small covers on the left and right side of the tool and push aside the coil spring holding in the brush. the brush should freely pull out of the holder.
when you have the covers off, look for charring or melting. and after the brushes are out, rotate the arbor to move the armature inside and look to make sure it's not charred.
if that doesnt help, take apart the handle and look for melted or exposed wire. dewalt likes to pack the wires in tight among the screws and sometimes the normal vibration of the tool will cause a screw to cut into a wire and short the wire.
new brushes and holders (if melted) are usually around 20 dollars US
Nov 17, 2008 | Dewalt DW824 5" Electric Angle Grinder
Grinders Logo
217 people viewed this question
Top Delta Grinders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Delta Grinder Expert? Answer questions, earn points and help others
