Question about GE GSS25LGM Side by Side Refrigerator
GE Profile icemaker will make ice but won't dump into the tray
PSS26MSWASS Serial RM411942 Almost 2 years old.
  • 410 Answers
GE uses an electronic icemaker that is not field serviceable. if the Icemaker is getting water then something in the icemaker has failed and the complete icemaker must be replaced. the part number is wr60x10093 I believe and can be purchased online and many different places or thru local appliance parts supply house. thanks peyton
Posted on Feb 19, 2009
Our icemaker just stopped working. I can feel ice
You need to replace the ice maker. If you could send a model we could get you the exact part number for that.
Thanks
May 23, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Fridge icemaker is not working - Help!!
I installed a new icemaker (cost approx $100) and its making ice. Very easy to install yourself (remove 4 screws holding part below icemaker, then unplug icemaker, and unscrew the 2 screws holding it in place.). Good luck-
Jan 28, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Ice dispenser does not work unit makes ice and water works fine
As long as the ice trays are filling with water, it's not actually the function of the ice maker to make ice. Ice simply forms because the freezer compartment is cold.
The icemaker's function is to sense when ice is formed in the trays and to dump the ice into its container.
This requires the use of a thermostat to sense the water/ice temperture and 'tell' the icemaker when it's time to dump the ice.
During the dump cycle, a heater briefly comes on as the arm swings through the ice cube compartments to assist in loosening the ice cubes and make them easy to dump.
If the icemaker is filling with water but you get no ice, I suspect that either the control circuit (thermostat, relays, and wiring) is not 'telling' the heater to come on, or the heater is burned out.
Some units also have a timer circuit such that both the timer contacts and the thermostat contacts must be close in order to initiate a dump cycle (i.e., it must be time to dump and the water in the cubicles must be frozen).
A skilled homeowner could make these repairs, but if you don't feel comfortable taking your icemaker apart and testing the components, I advise leaving the job to a qualified repairman.
I hope this helps. Good luck.
Sep 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Arctica won't make ice; ice was frozen solid yesterday. After removing, it won't make any more ice cubes.
Sep 12, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Model 22 Icemaker is not making ice
The following assumes that the ice trays are properly filling with water. If not, check the water control valve.
Sep 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
I poured water into the icemaker and ice cubes are formed but will not be dumped into the empty tray of my ge profile
The icemaker is bad then . It will have to be replaced by removing 2 screws and a plug connector . Easily replaced . Make sure the icemaker is turned on though .
Aug 16, 2009 | Refrigerators
I am unable to get ice. Cleared the tube.....arm on ice maker is down. I have a ge performance profile TFX22PP
Pour about 1/2 cup of water into the icemaker . If it dumps the cubes after freezing , replace the water inlet valve . If it holds the frozen cubes and does not dump , replace the icemaker . Also make sure the coils are clean of dust , lint , etc ...
Aug 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker does not make ice after first harvest.
theres whats called a cam inside of the ice maker and that is more than like;ly the problem. you can but your own ice maker from place like first service. good luck.
Jan 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice Dispenser on GE Profile PSS23MSTC does not work.
sounds like the ice is stuck together and the auger can't turn. remove ice tray and dump old ice new cubes should begin falling into tray after 30 minutes or so.
Jan 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker just stopped making ice
As these ice makers cycle there is an arm that moves up while the ice is being freed from the ice maker. After the ice is dumped into the dispenser bin the arm continues a downward motion. If it encounters ice in the downward travel it shuts the ice maker off. If this arm is locked in the full up position the ice maker is manually shut off. Check this arm and make sure it is not locked in the up position.
May 15, 2008 | GE PSS26MGS Side by Side Refrigerator
GE GSS25LGM Side by Side Refrigerator Logo
294 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
