My hp designjet 450 won't communicate with my computer. It's a new(used)plotter to me, I downloaded the driver, but no communication. A test sheet prints fine.
  • 11 more comments
  • larsen3d Feb 18, 2009
    I don't have another cable, although I swithched ports on the computer...still nothing. Any other ideas before I buy a new cable?
  • larsen3d Feb 23, 2009
    I've purchased a new parallel cable and still nothing. I've tried printing from a command prompt, wordpad and CAD, but nothing. I reinstalled the driver and it says "ready" next to the printer icon. Any ideas?
    I reinstalled my driver and still nothing. This is a new "used" plotter to me. When I first got it, I replaced the belt and got it running. I have never had this plotter run with this computer, my old dj430 worked great though.
    I checked connections, restarted both and nothing. One of you said to be careful of the order that I turn on the printer and computer. I found no info on this so I don't know the order.
    If the communication board on the plotter is bad, what is involved? Neither of the other 2 ideas applied.
    The only other devices attached to this computer are my new "pluglink" for my wireless connection and the usual computer hookups-mouse,...
    I never had a cd, as it was purchased used so I downloaded the driver from HP and installed it with the add printer wizard.
    The other computer here is on the other side of the house. It would be a big deal to unhook it, and install the driver on that one- any other ideas first?
    The printer is new to me but used- year 2000? Could I have hurt anything when I had it taken apart to replace the belt?
    My dj430 that I had installed on this computer before, "fried" from a power outage. I had my computer plugged in a power surge strip, but not the plotter. Could this have hurt the computer's port?
  • larsen3d Feb 24, 2009
    This is a huge plotter, not possible "to take it in"
    I believe it's an E series- that means it takes a 36" roll, right? Are those numbers you gave me the communication board? Is replacing this something that should be left for a professional? I replaced my belt but is this difficult or potentially dangerous to the plotter? I'm trying to save money but this is becoming a headache. Thanks for your input.
    WHen I went on the hp site and did automatic detection of products it said "no hp products found". I tried both of my ports.
    President:
  • 392 Answers
Change the cable and test it... If it couldn't help you I suggest you to plug your printer to other computer to see if the source of problem comes from computer or printer. By this way you could find the source of problem and then do the best! At the end I suggest strongly to call with the support part of HP.
Good luck
Posted on Feb 24, 2009
  • 547 Answers
You need to go in to your control panel and find it on list if not there add it it should be under printers
    Sergeant:
  • 326 Answers
Take the printer to any near by local repair cener of printer with your driver cd of printer instyallation.and ask the repair person to connect the printer at his service center in front of you.if the printer gets connected get your pc connections checked further but if the printer also does not get connected there then get your printer repaired there itself.
thanks.
Posted on Feb 23, 2009
    Scholar:
  • 165 Answers
As it clearly indicates that the problem is due to the socket loose internally where the wires are connected.the socket is actually soldered internally if that socket is loose nothing will happen.let you chasnge all the wires ,drivers,softwares.that socket has to be repaired.to repair that socket you should be familioar with soldering jobs.as it can be in any end of the wire the socket is faulty.the printer socket can also be faulty but as you said printer is new its rare chance of printer socket but can be possible.or the pc socket can be faulty where the wires get connected.
    President:
  • 2,653 Answers
How did you originally install this printer's software?
With a cd from HP?
Do you have any other computers around that you could use temporarily to see if the problem occurs with them too?
Please don't rate my solution until we've finished up.
Thanks!
  • RescueTechLA
    RescueTechLA Feb 23, 2009
    Which version of Windows are you using? Which service pack?
    You can find this easily by right-clicking My Computer and choosing Properties.
  • RescueTechLA
    RescueTechLA Feb 24, 2009
    Find somebody with an older laptop. You're using a parallel cable to hook it up, right? If not any laptop with usb will be fine.
    Sergeant:
    Champion:
  • 237 Answers
It sounds like the communication between the plotter and the computer is non existent. These can be a few things one the communication board on your plotter my be bad. Next it could be a bad cable if your using parallel or usb. Last if your on a network it could be an I.P address setting.
John C
  • 2 more comments
  • John Cole
    John Cole Feb 23, 2009
    its is going to most likely be the communication board on your printer
  • John Cole
    You need to open up the side with the comm ports on it and replace the board.
  • John Cole
    is this a D or E series
  • John Cole
    It should not of hurt it. This is the jet direct card for your printer for
    J2591-69001
  • 544 Answers
Thank you for choosing Fixya.com
Please check the connection thru printer and computer.
after that please restart your computer and printer.
let me know if anything change happens
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 82 Answers
You need to uinstall the printer drivers again. Disconnect the printer from your computer and reinstall the printer drivers. Only plug in the printer when the software tell you too. For some reason HP has issues if you do not follow the directions of the software. Make sure you get latest driver from the HP website for your operating system. Please post response so I can keep hacking at it fo you.
Posted on Feb 19, 2009
  • 6,487 Answers
If possible for you to try installing the printer to a different computer to check , that will be better before you buy a new cable...
    Sergeant:
  • 250 Answers
How to load a printer on a pc step by step instructions
http://freepctech.com/pc/xp/xp00168.shtml
http://kb.iu.edu/data/aksl.html
click the links 1 by 1 and read the instructions to connect the printer and follow them carefully as it will work properly.
  • 217 Answers
Printers may not communicate to the computer due to a com port conflict... please specify which OS...and if there are any other devices attached besides KB,monitor,mouse
Posted on Feb 18, 2009
  • Saroj Sharma
    Saroj Sharma Feb 19, 2009
    uninstall the printer completely (restart necessary ) first ensure there are no other devices attached that may conflict with the printer and then reinstall the printer
    Genius:
  • 1,847 Answers
This seems issue with the ports. reinstall the printer after unplugging all the other device connected to the computer.
    President:
  • 1,314 Answers
Have you tried swapping out the cable?
Plotter will not print
Check lan card led blinking pattern., Replace lan card(Jetdirect card 620n) & check, mostly lan card issue might be there..
Jun 12, 2015 | HP DesignJet 5500PS InkJet Printer
02.1.10 error plotter t610 and solution
The error code 02.1:10 means the plotter has a communications problem between the main logic board and the carriage PCA. The possible parts at fault are: The Carriage PCA, Trailing Cable, or the Main Logic Board, all available here: Designjet T610 Parts
You can watch this video to see how to remove the covers Designjet T610 Belt Replacement How To Video
The service manual is here: Designjet T1100-T610 service_manual
Sep 18, 2013 | HP Designjet T610 InkJet Printer
Error code 02.1.10
02.1:10 service station error- failure to reach home position .
you need a service tech to replace the service station within the plotter
Aug 14, 2013 | HP Designjet T1100ps Printer
I bought a used HP Design Jet 450 C...But its showing the cartridge and data solid orange light and ready light is constantly green. I brought a new black cartridge, the printer takes in the paper and...
I think the problem is not the computer. You shoud check the plotter by running the test print without the computer. When plotter's power is on, press Setup and Cancel keys simultaneously. If it does not print, then the plotter need repair.
According to your descriptions, there is System Error Code shown on your control panel. when the lights on for Ready+Cartridges+Data (DKL), it may have 9 possible causes referred by Service Manual page 2-7. You can check all these 9 items to see which one causes the problem.
Dec 17, 2010 | HP DesignJet 450c InkJet Printer
MY PLOTTER DOES NOT TAKE PAPER
***try to clean sensors: maybe it's dust on them.
Then if you are running latest Windows versions, you'll need a driver. Hp has dicontinued your plotter.
www.plotterdriver.it
Apr 02, 2009 | HP DesignJet 450c InkJet Printer
HP DesignJet 450c printer issues.
You can purchase a External JetDirect card from any reputable HP (or computer) agent. This will allow you to plug the 450 directly into the network. The problem with the large format printers not being supported is strange to me. I have never had a problem, simply load the drivers and away you go. If the 450 drivers dont work for you, you can select any of the older drivers (750c recomended) and they will work on the 450c
Feb 26, 2009 | HP DesignJet 450c InkJet Printer
Driver for HP Designjet C1633B
USE the designjet 650C (C2859B) driver, works fine for me...
May 05, 2008 | Office Equipment & Supplies
HP DesignJet 450c driver for windows vista
THIS SOLUTION IM ABOUT TO TELL YOU IS IN MY EXPERIENCE THE EASIEST ONE JUST DOWNLOAD THE WINDOWS XP DRIVER FOR THE HP DESIGNJET 450C PRINTER AND INSTALL IT INTO THE WINDOWS PRINTER PLATTFORM, YOU MAY SEE SOME ANOUNCEMENTS FROM YOUR COMPUTER TELLING YOU THAT THE PROGRAM YOUR TRYING TO INSTALL MAY NOT BE COMPATIBLE "DONT LISTEN TO THEM" JUST CONTINUE YOUR INSTALLATION AND PRESTO YOUR DESIGNJET PRINTER WILL WORK PERFECTLY
Feb 20, 2008 | HP DesignJet 450c InkJet Printer
jasbo
jasbo
