Question about Rowenta TO818 2-Slice Toaster
Rowenta toaster with a heating element that does not heat
Where can I get a new part?
    President:
  • 267 Answers
You can get parts for this unit . if you did you cannot change an element there rivited in there at the factory , not made to repair
Posted on Feb 19, 2009
How can I turn on the steam?
If the iron has been used for some time, it may have become clogged and is unable to generate steam. If you do not hear sounds of water boiling, the heating element may have failed.
Mar 19, 2016 | Rowenta Effective Iron
Where do you buy heating elements for black and decker perfect broil?
I was unable to locate the replacement heating elements for your toaster oven. These parts do not appear to be available. Probably buting a new toaster oven is your best bet.
May 08, 2014 | Black & Decker CTO4400B Toaster Oven with...
My black & decker tro964 is not heating
That may sound like a stupid question, but is it plugged in?
Have you tried to plug in the toaster on a different power outlet?
If there is a ground fault switch where the toaster is plugged in (that's those outlets which have 2 buttons on the front, one labeld "Test" the other usually labeled "Reset") unplug the toaster and push the "Reset" button and try the toaster again. To test, if the power outlet, were the toaster is usually plugged in, is working, try a hair dryer or any other device on that outlet.
Its most likely cheaper to replace the whole toaster than to replace the heating elements, for about 40 $ since that's the price of your toaster on some websites.
Jan 06, 2014 | Black & Decker TRO964 Toaster Oven
Parts heating element
I received a new euro-pro ritisserie convection oven for Christmas and I just love it, but, the heat bars stopped heating. I miss it so much and don,t know what to do to fix it. Barb Tyrley
Oct 11, 2013 | Euro-Pro TO161 Toaster Oven with...
RH end element was not heating to same temperature as middle element. Bought and fitted new end element but still same problem ie this new element still not heating to correct temperature high causing...
the new version has a plastic cover over element wires its best just to change all elements to solve this if you have had this toaster a wile the old elements dont have it,,,make sure its correct ones fitted as they are all different watts ..
Feb 23, 2011 | Dualit Vario Combi 2+1 65-Slice Toaster
My toaster oven stopped heating all together.
your heating element has gone bad or there is some bad wiring in the oven itself
to check open up the toaster oven and look at the wires coming from the heating elements inside to the timer on the front panel if there is no bad wiring then the heating elements are bad and the toaster oven needs to be replaced
Jan 02, 2011 | DeLonghi XR640 Retro 1500 Watts Toaster...
Toaster no longer heats. Can I purchase the heating element and install myself?
mcdevito75 here, Chances are the heating elements are soldered in on the toaster and may take special tools to fix, if the heating elements sre burned out, maybe better to get another toaster.
Jun 19, 2010 | Dualit Vario 2 Slices Toaster
Rowenta DX-8800 will not heat. Location of heating element?
The heating element is incorporated in the base. Rarely is the heating element bad. Its usually a connection or control problem. You cannot just replace the heating element.
Dec 30, 2008 | Rowenta DX-8800 Iron
Heating elements
I think this is a common problem with these kind of toaster ovens. Mine isn't a Toastmaster - mine is Cook's Essentials (from QVC), and my upper elements have also warped and split, although mine are curved downwards.
Dec 12, 2007 | Toastmaster 328 Toaster Oven with...
Rowenta TO818 2-Slice Toaster Logo
225 people viewed this question
Top Rowenta Kitchen Appliances - Others Experts
Tom Chichester
Bill Boyd
Ravi
Are you a Rowenta Kitchen Appliances - Other Expert? Answer questions, earn points and help others
