Question about Casio Cassiopeia Fiva Notebook
My Hp IPAQ PC won't Sync with My Vista Computer
I have a HP IPAQ pocket computer 1900 series using a 3.7 active sync and it won't sync with my vista computer. Is there somthing I can use to get them to sync. a program converter or something.
Window Vista syncronizing with iPAQ 3835 problem
In order to sync any iPAQ with Windows Vista, you will need to download and install Windows Mobile Device Center 6.1 from http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/device-center-download.mspx.
Activesync will only work for XP Operating Systems and earlier.
Notes
  • To find out whether your version of Windows Vista or Windows 7 is 32-bit or 64-bit, click Start, right-click Computer, and then click Properties. The version is listed after System Type.
  • You can use Windows Mobile Device Center 6.1 only with phones running Windows Mobile 2003 or later. ActiveSync and Windows Mobile Device Center won’t work with Windows Embedded CE 4.2 or 5.0, Pocket PC 2002, or Smartphone 2002 devices. (To see which Windows Mobile operating system you’re using, and if your phone doesn’t have a touch screen, click Start > Settings > About. If your phone has a touch screen, click Start > Settings > System tab > About.) To sync content to any of these devices, you must use a USB or serial cable and your computer’s Internet connection and File Explorer.
  • You must use Microsoft Outlook 2002, Outlook 2003, or Office Outlook 2007 to sync your e-mail, contacts, tasks, and notes from your computer.
  • You must use a USB cable to connect your phone to your computer the first time you use Windows Mobile Device Center to sync.
Jan 11, 2010 | HP iPAQ H3835 Pocket PC
I have a Ipaq 2200 version 4.2 2003 will it active sync with windows7
In order to sync your iPAQ with Windows Vista or Windows 7, you will need to download and install Windows Mobile Device Center 6.1 from http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/device-center-download.mspx.
Notes
Dec 30, 2009 | i-mate Pocket PC
I AM TRYING TO SYNC MY HP iPAQ TO MY COMPUTER, BUT AN MESSAGE ERROR SAYS THAT 'RAPI.DLL' IS MISSING. WHERE I CAN DOWNLOAD 'ACTIVE SYNC' AND 'RAPI.DLL'
You can download the Microsoft ActiveSync from:
http://www.microsoft.com/windowsmobile/en-us/help/synchronize/activesync-download.mspx
This package contains the rapi.dll inside it.
Note: Microsoft ActiveSync is for windows XP and earlier version only. In case of Microsoft VISTA download Windows Mobile Device Center.
Jul 11, 2009 | HP iPAQ RX3115 Pocket PC
HP Ipaq h1940 won't sync with Vista
Hi. While holding power button, and pressing reset will do a hard reset to your PDA (reset the device to its factory default settings). So if your PDA is working well, don't do it. As for the syncronization with your Vista PC; Winodws XP uses the ActiveSync software for syncronization, and for Windows Vista, Microsoft developed a brand new syncronization software called "Windows Mobile Device Center". It can be downloaded here: (http://www.microsoft.com/windowsmobile/en-us/help/synchronize/device-center-download.mspx). When you download/install this software to your PC, you should be able to connect your PDA to your PC without any problem, and definitely without changing any OS in your PDA or PC. Hope this helps.
Jun 01, 2009 | HP iPAQ H1940 Pocket PC
Active sync problem
check your anti-virus and firewall software - this can prevent outside connections being made over activesync
Nov 30, 2008 | HP iPAQ H1940 Pocket PC
Windows Vista
Go to control panel and select active sync.
Jun 11, 2008 | HP iPAQ rx1950 Pocket PC
use microsoft windows mobile device center
Jun 11, 2008 | HP iPAQ H1940 Pocket PC
Ipaq H4150
Have you used a Vista PC as the host machine? ROM updates can only be done from a Win XP or 2000.
Hook the iPaq to an Win XP or 2k PC, install active sync first, and then get the ROM update again. Run the Rom Update Utility and it will recognise the iPaq and will update it correctly. :)
Dec 10, 2007 | HP iPAQ H4150 Pocket PC
HP iPAQ 4150 battles Vista -- HELP
The Microsoft Windows Mobile Device Center requires that the first sync be made via the USB sync cable. After the h4150 is plugged into the Vista machine, the WMDC opens and prompts you through setting up a partnership. Then you can set the h4150 to sync via Bluetooth.
ActiveSync works fine with Vista. Ignore that other guys post.
Nov 29, 2007 | HP iPAQ H4150 Pocket PC
Ipaq rx 1710 and vista
well u have to activate the Vista Sync Center which is standard and it works with the Rz1710. Otherwise u have to go to Microsoft download center and search for the driver there
Aug 10, 2007 | HP iPAQ RZ1710 Pocket PC
Casio Cassiopeia Fiva Notebook Logo
218 people viewed this question
Top Casio Computers & Internet Experts
Piyal Perera
Piyal Perera
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
