Question about Kenmore 73822 / 73824 Bottom Freezer Refrigerator
Just purchased used 596.73824200 bottom freezer. Would like to know year manufactured and size in cu.ft.. Need lower shelf for freezer door. (Do not have a manual)
  • pnjathome Feb 19, 2009
    What I need is not in this list. We need the shelf that goes into the door of the freezer but thanks anyway.
    Sincerely,
    Jackie
  • 410 Answers
You can go here and find the parts you need. i really cant tell what age your refrig is by the model#  i believe it is a 24 cu ft. if you can give me a serial# off of the unit i can tell yo how old the unit is. thanks Peyton
Posted on Feb 19, 2009
  • peyton thompson
    peyton thompson Feb 19, 2009
    According to the model number listed the only shelf available for the freezer door is item numbers 8, 9, and 10 on the page I linked for you.
    Are you seeing a place for a 2nd shelf? let me know I'd like to help you find the part you need. thanks peyton
  • peyton thompson
    I had a ******** moment I just realized what part you need. its the basket that slides in and out wiht the freezer door. is that correct? if so the part number is Basket, lower fz Part # 12754803 at sears.com the price was approx 35.00. let me know if that is what you need. thanks again peyton
I have a Magic Chef freezer built older than 20 years. 15.2 cu. ft. pt. no. 101403-1
Hello Darrell;
My name is Peter. I am a retired field service technician.
Why do you think your Magic Chef is still working after 20 years? Your unit was manufactured with reliable cast steel components.
Do you want to purchase a new unit with more efficiency with components manufactured with plastic and cast ceramic. If you do decide to purchase a more efficient unit, do not discard your well build Magic Chef. When the new unit fails after 5 years, you will always have the older well built unit.
Nov 13, 2014 | Magic Chef Freezers
Kenmore model 795.7500401 need to know cu sq ft
Here is a tip that I wrote that tells you how to figure out how big your refrigerator and/or your freezer is...
New Refrigerator Size or Refrigerator Cubic Feet
Heatman101
Aug 27, 2010 | Kenmore 71279 Bottom Freezer Refrigerator
Not freezing on top shelf of door
try to replace the Styrofoam cup then put on the top.. if the same happens.or it will be frozen it means styrofaom is .................................. then use another...
Jun 22, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Where is the drain in the freezer? Can I access it?
It is near the bottom of the freezer, if you remove the lower basket/shelf you will see a 'step up' and a back panel with slots above the step. The drain opening is just below the slots in the back panel. This link may help if you are going to clean it out. Let me know if it helps. Thanks
http://www.fixya.com/support/r4686046-water_leak_from_freezer_ice_freezer
May 03, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Kenmore upright freezer, about 16 cu ft. Buildup
symptoms you are describing are faulty door seals, try putting a thin piece of paper between door and frame to make sure doors are sealing,also when did you do a full manual defrost??(once a year even with auto defrost)
Apr 07, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
I have a maytag upright freezer. It is on the coldest setting. A bowl of water on the bottom shelf freezes overnight. The middle one is freezing, but not entirely. The top one is still water, but cold....
check to make sure door seals are touching the frame all round, could be an air leak,also make sure there is no ice build up around the inside casing. if so fully defrost unit,clean all vents/drain pipe, then turn back on and leave it for 24hrs (freezers work beast when full).....and door shut..how many times have you closed door after them????
Mar 01, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
Not cold at all, a pizza box was knocked vertically behind the bottom sliding shelf of the freezer. the shelf in the closed position, pressed the box against the back of the freezer where the cold air...
if the fridge is still working then a 48hr total defrost should kick it back into life as restricted air flow will overice the evaporator...this is shown by a build up of heavy frost on the lower section of rear panel in the freezer
Dec 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frost build up on 1 shelf then 2 shelf and so on - hard freeze on top soft freeze on bottom upright 7.5 freezer
door gasket sealing properly kids hanging with door open? condenser clean? if its a forced air condenser if it is a static freon problem. Tom
Jun 16, 2009 | Kenmore 7.5 cu. ft. Upright Freezer 28702
Freezer defrosting
need to defost the whole freezer get the door to close correctly...
May 27, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Not freezing equally
Look for frost build up on back wall at bottom the auto defrost may be out. Check if the evaporator fan is blowing. If not it's stuck by something or needs replaced. If not The sealed system may have a leak or restiction causing it to only work closest to the evaporator i.e. the lower shelf.
Apr 22, 2008 | Frigidaire Freezer 16.7 cu. ft. Upright...
Kenmore 73822 / 73824 Bottom Freezer Refrigerator Logo
119 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
