Air con is leaking water from sides and bottom, how do I get the front off to clean out the small filter inside??? Steph Walkerston
  • asblakes Feb 19, 2009
    Sorry it is a high wall mounted Fujitsu , cold only no heater, it's 6 years old and never had any trouble with it before.
  • luke bussenschutt May 11, 2010
    what kind of a/c is it high wall split, window a/c,
  • 51 Answers
When an airconditioner leaks water it is usually from the drains being blocked with build up. The easiest way to take care of this problem is to use a wet vac, and suction the blockage out. Your drain is located outside. It will most likely be made of pvc. That is where you apply the suction.
Posted on Feb 20, 2009
My AC unit leaks water inside
Isidro, If it's a window unit you will need to tilt it up from the inside. Thank you and please leave me feedback. Clean around the bottom of any debris so it can drain on the outside.
Jul 12, 2016 | Panasonic Heating & Cooling
Why is my air con leaking out the front of it I want to get to the overflow pipe inside but dont know how to remove the front caseing other than the filter part
Check where the condensate pipe goes onto the ground first as sometime spiders or wasps will block the end of the pipe. It is unlikely that the pipe is blocked inside although as you have seen the water does flow out inside..
Feb 29, 2016 | Filter Heating & Cooling
Left front inside car is full of water under the floor mats,can it be from the air con and how to resolve the problem
LOOK UNDER NEATH VECHICLE ON LOWER BACK FIREWALL WHERE HEATER CORE HOSES RUN ON THE PASSENGER SIDE LOOK FOR SMALL EVAPORATOR DRAIN HOLE. TAKE A SHOP VAC AND SMALL VACUUM LINE HOSE ABOUT 3/8 SIZE VACUUM IN THE DRAIN HOLE THAT WILL REMOVE DEBRIS THAT BLOCKING OFF DRAIN HOLE WHICH KEEP EVAPORATOR WATER LEAKING INSIDE CAR.
Nov 25, 2010 | Nissan Pathfinder Cars & Trucks
Water leaking out of unit, not out of flow tube.
Some models have a hose, some don't , maybe the drain hole it's restricted, condensor normally it's in the back of the unit, you might have to remove one of the side panels.
Dec 23, 2009 | Convair Portable Air Conditioner
Our carrier reverse cycle airconditioner is leaking inside the house after a hour of use. how can we fix this? we have cleaned the filters in the inside unit and it still leaks,it works fine as a heater...
Did you blow out the drain? If so pull the front off of the air handler unit. Ckean out drain pan. This drain pan had small holes on either side that run from the sode drain clean those out. Also if your coil is dirty it will pull water back and cause it to leak. Try cleaning coil and dain pan plus blow out drain. Rus
Dec 13, 2009 | Air Purifiers
Water leak on passenger side on 99 chevy s 10 not anterfreeze, leaks when not being driven
there is only one thing that leaks water there, that is the AC condensation drain, water forms as part of the AC cooling the evaporator core, this water must be drained away or it will flood onto passenger area, so there is a drain on the passenger side at bottom of firewall, will leak allot of water depending on how humid the air is.
May 05, 2009 | 1999 Chevrolet S-10 Pickup
Water leaks when filter is connected
Does it leak from the back or the front of the appliance ??
Aug 25, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking from bottom right-rear near valve. Changed inside filter.
you might have a clogged drain in the bottom back of the freezer. When the freezer defrosts the water has no where to go and comes out the front.
Aug 11, 2008 | Frigidaire FRS26R4A Side by Side...
Heating & Cooling Logo
169 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
