Question about Kenmore 64254 / 64252 / 64259 Top Freezer Refrigerator
The upper freezer is no longer cold enough to freeze water; the refrigerator itself seems to be working o.k., but I'm not sure of that even.
  • 93 Answers
It seems that you are low on freon if your freezer does not freeze enouht water you need freon cause you have a small leak in the system thanks from gilles
Posted on Mar 15, 2009
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
I just replaced my automatic ice maker in my Samsung french door refrigerator. Now the temperature is not cold enough to freeze the water which leaves the ice bucket with water not ice. Freezer works
Repair for a Freezer That Is Running But Not Freezing ...
homeguides.sfgate.com > ... > Other Types of Mortgages
This is the heat you feel blowing near the freezer when it's in a cooling cycle. ... Also, using a freezer to cool hot items or opening the freezer frequently will ... If you noticewater pooling on the floor when the freezer is running but not freezing, ...
Why Is My Freezer Not Cold Enough? - Articles - Networx
www.networx.com > ... > Electrical > Appliance Repair > Read Article
Sep 1, 2011 - Next, make sure the freezer isn't overloaded and that the evaporator fan ... are choked with frost, restricting the airflow that makes the freezer cold. ... In verycold weather, a freezer in the garage may heat up, since there isn't enough warm ...unit (even on automatic-defrost units, in case there's a lot of water).
refrigerator - Freezer is cold but not freezing at all - Home ...
Dec 20, 2015 | Refrigerators
I have a sharp fridge SJ-P49N-SL. A recent power outtage in the area lasted 8 hours. When the power came back on, the fridge seemed to be ok. But, after 5-6 hours of operation, the freezer is not cold...
Checked Freezer Fan is working. Also checked defrost Fuse in freezer.
To checked freezer fan is working or not open freezer door press Door Switch and checked Cold air is coming from duct or not.
Aug 10, 2011 | Sharp Refrigerators
My freezer is very cold but not freezing water into ice. The door was only partially closed because a towel was in the way but after fixing that it has been 6 hours and it's still not freezing. The...
That really cause the freezer not to freeze water because of that towel. Since you already remove the obstruction, just observe it and it will gonna freeze the water. Be sure that the door gasket magnet has tightly closed freezer door and no cold air is going outside. If there is, again it will takes longer to freeze water into ice.
Just observe and it will gonna go back to normal operation.
Good luck to you.
Jul 03, 2011 | Frigidaire Side By Side Refrigerator 26...
Top of freezer not freezing, bottom of fridge is?
Could be the evaporator fan motor is not working. This is what circulates the air from the freezer to the refrigerator section.
Aug 24, 2009 | Refrigerators
Hotpoint CTF15ELD top freezer refrigerator - freezer O.K. refrig too warm
It's likely the door was inadvertently left open, and the cold air passages from the freezer have built up enough ice that the cold air from the freezer has no way to enter the refrigerator. Check the cealing of the refrigerator. If you can see or feel ice in the passages between the freezer and fridge, you can probably solve the problem by finding a safe temporary home for your food, and leaving the refrigerator unplugged overnight.
May 25, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Ice Maker frost and freeze where ice drops into refrigerator door
You need a service guy to look at it. It could be water leaking or a simple case that the flap isnt sealing and the ice melts and then freezes the flap open
May 14, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Nov 10, 2008 | Frigidaire FRT15B3A Top Freezer...
My refigerator and freezer are not cooling enough
Is the fan in the freezer running?? Is there frost on back panel of freezer??
Oct 03, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore 64254 / 64252 / 64259 Top Freezer Refrigerator Logo
73 people viewed this question
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
