Question about Amana NDE5800AY Electric Dryer
Belt broke on Amana dryer
How do I chang the belt. the dryer will turn on but the tub will not spin. I put on a new belt and pulley
  • 547 Answers
Belt goes around drum and motor pulley and under tentioner
Posted on Feb 18, 2009
Motor runs, but clothes tub will not spin, what is the problem? There is a vynyl looling inch belt on the tub.....tub spins freely with hand control.
either the belt slipped out of the idler pulley or the belt itself broke,, click on this link for easy instructions for your machine http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm please take a moment to rate my response Thanks good luck
May 30, 2011 | Whirlpool LER4634J Electric Dryer
How do you replace the drive belt in a kenmore dryer model 88042
Pull the fron off. Remove tub, should have a spring loaded idler pulley next to the motor. Make sure that it is not broke and spins freely. Also check tub support rolers on each side. They shoule spin freely. If ok, put belt around tub, install tu. Put belt around spring loaded pulley. May need a hand holding tub while you install pulley. Put front on. Make sure the fron of cover fits inside the tub seal. Good luck. email me with issues, bobby.crochet@lyondellbasell,com.
May 14, 2011 | Kenmore Dryers
Frigidaire dryer tub will not turn
It sounds as thou the dryer drive belt has either broke or slipped off the motor drive pulley.
To determine which is the case, you'll need to unplug the dryer from the wall outlet (safety first!) OR turn off the gas valve too. Now pull out the dryer so you can remove the rear service access panel at the bottom of the dryer. Once you've removed the access panel, get down and look into the dryer with a flashlight and see if you can see the electric motor. Now see if you can see the drive belt around the motor pulley, or if the belt is broken and has fallen into this compartment.
If the belt is not on the pulley, grab hold of it and see if you can spin/rotate it around the drum, if you can do this all the way around, the belt is likely still good (check for damage as you slide the belt around).
You should be able to get the belt onto one side of the pulley and with your hand, carefully rotate the motor drive pulley to get the belt back on the drive pulley.
If the belt is broken, you'll need to install a new drive belt, which will take some further instructions to perform and will be made eaisier if you can provide the full model number for your dryer.
Hope you find this Very Helpful and best regards!
Aug 18, 2009 | Frigidaire Dryers
Whirlpool cabrio dryer belt falls off after install
If you're turning the drum backwards the belt will fall off. Make sure you're turning the same direction the motor will spin it.
Aug 11, 2009 | Amana NDE5800AY Electric Dryer
Won't spin or start
Sounds like the screen/sock combo got the tub in a bind and the drum belt broke.
If you want to pursue replacing the belt, let me know.
Apr 30, 2009 | Amana LGA10 Dryer
Amana dlw330 washer belt urned & broke again
Had the same problem on a machine I worked on. Changed the belt... was burnt and broken. Second time I replaced the belt, I ran it through all of the cycles and listened to it on SPIN cycle.. Although it's spinning.. it's making an extremely LOUD noise... It's the Spin bearing that is gone out. When a load is put in, and in spin cycle, the bearing is oveloaded..(being dry).. and putting extreme pressure on the motor and belt. When the drum reaches a point where the bearing just won't spin, the belt stops, and spins on the motor pulley, wearing it through.. (And smoking a great deal).. until it breaks.. again. I believe the top "Spin bearing" is about 75.00 or so.. and a BEAR to replace. Hope this helps
Feb 26, 2009 | Amana DLW330RA Top Load Washer
1. unplug dryer
2. popoff the top off
3. take front off (unscrew)
now you can get access to the belt look in bottom of dryer there is a giude wheel for the belt
4. place belt around drum and pulley make sure you add tenstion
5. replace front and top
Thank you for useing Fixya
Jan 29, 2009 | Amana ALE866SB Electric Dryer
Can't get replacement parts back on Kenmore 60 series dryer.
The belt has groves, right? Make sure the groves go over the motor pulley from the right. The idler pulley is spring loaded. Place the belt around the idling pulley with the smooth side of the belt on the pulley. This should work.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Amana Dryer belt instalation
Remove the power to the unit and the bottom access panel. Remove the front bulkhhead where the drum sits on by undoing four screws one for each corner.Verify felt seal on exhaust fan cover is airtight on flange of duct. If seal is installed improperly air flow will be restricted which can cause poor dryer performance.Belt must be positioned around cylinder between center and rear bafflescrews with the ribbed surface against the cylinder. You gotta push up on the spring loaded idler pulley the easily slip on the belt to the motor shaft. make sure that the ribbed part of the belt wraps around the drum and motor shaft and not kinked.
Jul 31, 2007 | Amana DLE330RAW Electric Dryer
Amana NDE5800AY Electric Dryer Logo
119 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
