Question about JVC HR-XVC19S DVD Player/VCR
I had d problem where mi dvd was unable 2 eject cuz it was locked, so i uplugged it den pluggd it bak n held d power button and it suddenli went off as i was holdin d button n now it doesnt wanna *** on..pls help
    President:
  • JVC Expert
  • 300 Answers
Normally when the VCR is plugged in, the display should blink. If not, it could be broken. Since I am not sure about this model, do an experiment. Unplug the unit. Wait for a few minutes. Plug it back in and insert a video cassette. If it powers up and the display turns on, VCR should be OK. The unit may be reset to factory default and the remote might be set to different code. The remote can be reset to factory setting by removing the battery for a few minutes.
Posted on Nov 15, 2009
Locked Tray DVP-SR320 Sony DVD Player
see this causes and fix it. God bless you
Possible causes:
  1. Worn, stretched, oily, flabby, belt.
  2. Dirty mechanism or gummed up lubrication.
  3. Stripped gear or other mechanical damage.
  4. Defective motor or bad connections to motor.
  5. Bad drawer/eject button.
  6. Missing/bad voltages from power supply.
  7. Defective microcontroller or other logic.
  8. Dealer antitheft lock enabled.
Oct 15, 2012 | Televison & Video
I put in a dvd into the dvd player, and went to eject it. I pressed the eject button and a "locked" caption came up on the screen. I dont have the owners manual and I cant figure out how to...
You may have enabled the child lock feature, try pressing the Return, Enter and Power buttons together to toggle the lock off. If this is disabled and you still can't open the tray, turn off the unit and unplug it. After 30 seconds or so, plug the unit back into the electrical outlet. Attempt to open the tray. If this does not solve the problem, try pressing Power + Stop + Eject buttons together. Also try pressing Disc1 + Stop + Eject simultaneously (if a disc1 button is on the remote or player).
If the error message is t - L C K or persists after trying all of the above steps, then you need the unit serviced.
The manual is available at the Sony support site: http://esupport.sony.com/US/perl/model-documents.pl?mdl=DVPSR200PB .
I hope this helps.
Apr 16, 2011 | Sony DVP-SR200P DVD Player
My panasonic dvd player shows locked when I tried to eject. I can't eject tehDVD. My kids could have jinxed it. Model panasonic sc-pt550 TQ
There are two lock conditions for this device.
If you can't eject the disc:
Enabling removal of disc
1. Select the DVD/CD function.
2. At POWER ON condition, press and hold down the stop button and the power button on the player for at least three seconds.
(The message, "___LOCKED_" appears when the function is activated.)
If you can't operate the functions:
Enabling operation of selector and disc
2. At POWER ON condition, press and hold down the play button and the power button on the player for at least three seconds.
Hope this helps!
Apr 08, 2011 | Panasonic DVD-S52 DVD Player
Dvd player will not eject or play dvd. It just keeps spinning and says "reading." I've tried unplugging for 2 minutes, pushing close/open and stop at the same time(hold for at least 3 seconds)....
Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray. Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.6 Jan 2013
Solved: DVD is LOCKED will not eject. please help. Manual ... - the ...
https://community.sony.com/t5/Home-Theater.../DVD-is...will-not-eject.../td.../55919.
or try this link. Dvd player will not eject or play dvd Google Search
Oct 18, 2017 | RCA DRC8295 DVD Recorder/VCR Combo
I HAVE A JVC XV-THP3 DVD PLAYER. MY LITTLE GIRL WAS PRESSING THE BUTTONS ON THE FRONT AND HAS LOCKED THE DVD TRAY. CAN YOU HELP ME PLEASE?
Hi there, I just had the same problem with my daughter, looked in the manual and it says to hold down the stop button and press the eject button on the unit. That should unlock it, its the same procedure to lock it, in case you want to prevent you daughter from attempting to play biscuits!!
Regards, darren
Jan 08, 2009 | Panasonic DVD-A110 DVD Player
DVD stuck
In the front side of the dvd drive you will see a small hole ...so to eject that cd put one niddle in that hole and .
Now press the button at just after that apply a force on niddle .suddenly you will notice that cd will come outside ,if not try more times and you will learn to eject the cd when you are unable to do it by pressing the eject button...
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
May 01, 2008 | Panasonic DMR-EH55 DVD Recorder/HDD...
Cdr tray/door won't open
Thanks
Dilip Bagdi
Technical Associate
Aug 09, 2007 | Philips CDR785 3-Disc CD Recorder
Locked dvd tray.
To unlock, manually press and HOLD the open/close button & the stop button simultaneously, and HOLD them both down until the lock picture disappears.   The DVD will eject when you press the open/close button.
To lock the DVD inside the machine, repeat the same step, and it will lock it inside.
Apr 07, 2006 | Panasonic DVD-A110 DVD Player
JVC HR-XVC19S DVD Player/VCR Logo
149 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
