Question about Bosch 24 in. SHU53 Built-in Dishwasher
SHU4302UC/U06 runs for hours. What's the fix?
Bosch Dishwasher
  • Anonymous Apr 24, 2009
    Both my sister and I are having this problem with our Bosch.
  • 547 Answers
Posted on Feb 18, 2009
Bosch Dishwasher Model SHU5315UC/U06 Looking for Cycle Buttons That are no longer avail #176079
There are several places on-line where you can find this parts. Depending on where you are. For example you can look up
May 08, 2016 | Bosch Dishwashers
Bosch SHU4302UC/UO6 runs three hours.
Maybe wash temperature. The machine may be trying to heat the wash water to a preset temp and it is taking an extended time to get there. Maybe a faulty temperature probe or a bad element?
I know you will ask how this is possible when you have a final temp of 120 but that sound like a drying cycle temperature to me; not a wash temp.
I would leave the thermometer in through the cycle and you will probably find it will slowly get hotter in wash cycle and finally switch after a certain temp has been obtained.
Oct 05, 2017 | Bosch Dishwashers
I have a bosch dishwasher shu6805uc/u06 to long to wash.
Well not going into the dry cycle could be a timing issue or a EOC (control panel) issue and will need to be addressed. But most dishwashers these days have a active run time during normal cycle of 110 to 120 mins, and thats not including the heated dry feature. I would let the unit run and see if it will finish on its own, and if I say it pushes two and half hours then something is wrong. A tech would most likely have to look at it, also a power reset could help but thats like a 30% chance.
Dec 30, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
I have a Bosch dishwasher Model number SHU4302UC. The dishwasher takes about four hours to wash dishes. During the rinse cyle it can be running for over an hour and I will open it to look in side and find...
possibilities are that of an inefficient heating element ie..scaled up if hard water area especially. whilst the cycle is being completed then the components are working... so other than the element check the drainage for blockages (slow draining adds time) & also water pressure as low pressure adds time to the filling..
Dec 21, 2009 | Bosch Dishwashers
Washer will not start. Lights come on, but nothing else happens.
I have a Bosch Dishwasher, SHU6805UC/U06, During a cycle it was interrupted by opening the door. It was left open for an hour. When the door was closed again the lights came on but the cycle did not continue. The motor did run but no water was rushing. Power interrupted to the machine did not enable it to reset or restart. How do we get it going again?
Mike,Laurie,& Dory
Apr 15, 2009 | KitchenAid Dishwashers
We have a +11 year old Bosch SHU3006/UC/U06 that never leaves the wash cycle. We had to stop it during our last test run at 3 hours. Chat advise is suggesting a water temperature problem (I origionall...
Check continuity of the heating element to see if it is broken/open.
The dishwasher prefers that the incoming water (water heater) be 120 degrees (F)
Apr 04, 2009 | Bosch SHU3036UC Dishwasher
Bosch SHU4302UC/06 Sound Like It is Work But NO WATER
float switch is in the flood position and the drain pump is running.. there is water under the dishwasher or that switch is stuck up..
Aug 15, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Running a LONG LONG Time and Watering Remaining
You could try running the machine with the drain hose leading to a large bucket. If it works OK in this situation then the blockage will be most likely where the drain hose joins the house drainage system - often at a junction under the kitchen sink. With the drain hose disconnected you should be able to see the blockage and clear it with a suitable pointy tool.
Let me know if this sorts it. Thanks, D.
Jul 31, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
No, the water does not heat up. Thanks.
Mar 12, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU53 Built-in Dishwasher Logo
1,342 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
