Question about Aroma Kitchen Appliances - Others
I accidentally put the rice into the outer pot of my aroma rice cooker, I shook most out but some is still stuck there. Any suggestions? How can I remove the bottom of the cooker to clean it out? Thanks.
The problem has been solved - the bottom cover of the rice cooker was unscrewed and pried off, and after removing the insulation, etc. the rice was removed.
Posted on Feb 19, 2009
Can i use the aroma rice cooker w/ 220v?
All you need is a power converter. Go to amazon and put in the search bar 220 volt power converter.
Best regards,
Bill
Oct 25, 2014 | Aroma Rice Cooker ARC-914sbd 8-Cup Cooked...
IM IN LONDON. I PURCHASED AROMA RICE COOKER THROUGH AMAZON.120V RICE COOKER. How to use it here in London?
Look on the information label to see how many amps it draws at 120 volts. Multiply the amps by 120 to get watts. Next you'll need to get a transformer that will handle the watts when changing 240 volts to 120 volts
Oct 10, 2014 | Aroma Rice Cooker ARC-150sb 20-Cup Cooked...
When I put cook button its going to warm alwayas.Please suggest me what to do. I bought just 5 months before.
You should have a button that says something like white rice and brown rice....the cook button is for steaming veggies...
Here is a tip that will help you figure out about using a rice cooker...
How much Rice and Water go in the Cooker
heatman101
Feb 02, 2011 | Aroma Kitchen Appliances - Others
Need instructions on how much water and how much rice for rice cooker
answer from page 6 of the instructions: http://www.aroma-housewares.com/manuals/ARC-914S_InstructionManual.pdf
UNCOOKED RICE
WATER WITH MEASURING CUP
INNER POT WATER LINE
1 Cups
1-1/2 Cups
Line 1
2 Cups
2-1/2 Cups
Line 2
3 Cups
3-1/2 Cups
Line 3
4 Cups 4-1/2
Cups
Line 4
Sep 12, 2010 | Aroma ARC-914S 8-Cup Rice Cooker
Water to rice ratio in an Aroma ARC 1000
Water to rice ratio is usually the same regardless if you have a rice maker, or are cooking it in a pot on the stove. 2 parts water to 1 part rice works everytime.
Jun 08, 2010 | Aroma ARC-930 20-Cup Rice Cooker
ARC-838TC 20-Cup Rice Cooker: Lost the instructions on how to use the aroma arc ...
Here is a tip that I wrote about rice cookers and the amount of rice and water needed...
http://www.fixya.com/support/r5396567-much_rice_water_go_in_cooker
heatman101
May 18, 2010 | Aroma ARC-838TC 20-Cup Rice Cooker
3 CUP AROMA RICE COOKER WILL NOT HEAT --ONLY 4 MONTHS OLD
1. Is the cooking pot filled with water? If there is no weight, it will not turn on.
2. Is there a pilot light? If no power, you have a unit that was probably returned by someone else.
3. The heating element/plate thermal fuse may be blown. Either replace the fuse or the whole unit.
Mar 06, 2009 | Kitchen Appliances - Others
I got this rice cooker as a gift, but will not work.
I had the same issue with my tefal cooker.
It may be that the bottomof the pot is a little bend in and it you can push it out a little, it may then push the thermostat down the required distance
Marco
Jan 26, 2009 | Rival Kitchen Appliances - Others
Kitchen Appliances - Others Logo
1,144 people viewed this question
Top Aroma Kitchen Appliances - Others Experts
Jim Goldsmith
Jim Goldsmith
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you an Aroma Kitchen Appliances - Other Expert? Answer questions, earn points and help others
