Question about Vector VEC136 TV Receivers and DVRs
Looking for manual Vector Stormtracker Elite, model WC300DSV
Trying to set up all the functions and need a manual. I can't even figure out how to set the time and uausally my intuitive abilities allow me set up with out a manual but not in the case. Thanks for any help.
  • Anonymous Apr 27, 2009
    same here
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
Black & Decker took over Vector. The manual can be found at http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Vector/WC300DSV.pdf .
Posted on Jun 21, 2009
SOURCE:
Can I sew buttonholes on a 5525?
If your machine has a straight-stitch and zig-zag function, you can always sew buttonholes. It would be helpful if your machine has the ability to set the needle left-center-right, but a buttonhole can still be done even without this function. Whether or not your machine has a programmed buttonhole function will be included in the owner's manual.
How to sew buttonhole with an old machine
How to Sew Button hole tutorial
Just practice on scrap fabric before trying it on your garment.
Feb 19, 2016 | Sewing Machines
How to remove auto brightness feature?
webcam displays colours b> Webcams are useful in both personal and business functions, from video chatting to video conference calls. When your webcam displays strange colors, it is usually due to a problem that is easily fixed even without advanced technical abilities. By trying at-home solutions before sending the computer or camera in for service, you can save time and money.
Lighting
Lighting is a common cause of strange webcam colors. When your webcam does not have enough light, it compensates by adjusting settings internally. The adjustments can result in color shifts that are not true to life. Bright, diffuse lighting reduces the workload on your webcam and allows it to display colors as they are. The light source should be behind the computer and pointed at your face to reduce shadowing and provide an even light. Avoid light sources behind you, as they can cause extreme contrast between your face and the light. b> Webcam Settings b> Most webcams come equipped with customization settings that allow you to adjust the display. Changing the settings while watching a preview webcam image can help you fix odd colors on the display. The location of the video settings varies, but is often located in the Preferences, Settings, Configure or Video menus. Adjust the tint, contrast and brightness settings until the image shifts to a normal color scheme. Webcam Drivers b> Webcam drivers allow the camera to function properly. When your drivers are corrupt or out of date, they can affect even the most basic display abilities. Webcam manufacturers publish the most recent driver downloads on their websites, usually on the individual product page, along with instructions for installation. To allow your computer to communicate with the webcam and use the drivers, run a software update to install any recent versions. b> Special Effects b> Some webcams come with built-in special effects that allow you to customize the appearance of the video stream. If an effect was enabled during the last session, it may stay on when the camera is turned on again. Turning the effects off will usually resolve the problem. The location of video effect settings varies by webcam model and manufacturer. Logitech Video Effects are located using the mask button in the QuickCam menu. On a Mac, effects for the built-in iSight webcam can be changed in the Effects 1 and 2 menus in the Photo Booth application. Hope this helps.
b>
Jan 17, 2013 | Computers & Internet
My webcam iball c8.0 is showing blurr images and is fully blurrr
Lighting
Jan 16, 2013 | Computers & Internet
How do I set up manual payroll canada
I am trying to figure that out too. So far the best solution I've found is by going to the Help topic "Using QB w an outsourced payroll service"
Goodluck.
Aug 18, 2009 | Intuit QuickBooks Premier 2008 (3-User...
Zenith Z212G radio, Need preset modification instructions
Zenith Z212G radio, preset modification instructions
  1. Display desired station
  2. Press Memo Set button to make "Memo" flash on display
  3. Select desired preset number
  4. Press Memo Set button to save
Apr 12, 2009 | Zenith Z115S Clock Radio
Date/time stamp control in Menu won't allow access
In many cameras these settings depend on the shooting mode. Did you change the shooting mode? If so, return to your normal shooting mode and the function should be available again.
If this doesn't fix your problem I need to know if you have your camera's user manual. If I can find the solution in your user manual I need to know if you can read the steps in your own manual or if I need to provide you a link to read the manual online.
Jan 11, 2009 | Canon PowerShot A530 Digital Camera
Setting up Quickbooks for my business
Alot depends on the version of QuickBooks. On some versions, the manual was included on the cd. It will also be determined by the type of business you are setting up.
As a last resort, you can look for manuals in used book stores, or call Intuit customer service to purchase a manual.
I
Aug 18, 2008 | Intuit Computers & Internet
Setting the date on a Guess G95290G
When you pull the dial out, you can pull it out into two different settings. One will allow you to set the clock/time. The other will allow you to set the date (the day of the month). It took me a while to figure this out as well, even witht he manual.
Aug 16, 2008 | Watches
Vector VEC136 TV Receivers and DVRs Logo
1,977 people viewed this question
Top Vector Televison & Video Experts
Marvin
Marvin
Are you a Vector Televison and Video Expert? Answer questions, earn points and help others
