Question about Dynabrade Eraser Wheel With Hub For Dynazip Decal Removal Tool 92257
Need to remove DOT tape.
Looking for the best way to remove DOT tape off of several trailers without harming the paint.
    An expert whose answer gotĀ voted for 100 times.
  • 86 Answers
A heat gun (careful, some heat guns will remove paint!), or 1200 or higher wattage hair drier held over the tape while sliding a putty knife under the paint is the best method. The heat softens the adhesive and makes the tape easier to remove without damaging the paint. You'll still likely have to go back with lighter fluid and a cotton cloth to remove the adhesive still stuck to the paint. Don't use acetone or paint thinners, they attack the paint!
Posted on Mar 01, 2009
How do I recoat my microwave?
I assume you want to paint it. Preparation is the key. Rustoleum has some pretty good products that look close to stainless steal. Clean the outside thoroughly. The paint will only stick well to metal surfaces. Plastics will tend to crack and peel. Tape and paper off all the parts of microwave not being painted. You will not want to get paint on labels, keypad, plastics or the door seal. Paint takes and hour to dry between coats. Practice with long strokes on something else first. Several thin coats is better than one thick one. Fumes can be strong. Outdoors without wind or a garage will be the best area to paint. Paint is oil based and you will need paint thinner( or WD-40 in a pinch ) for cleanup. I don't think painting would be wise inside the microwave. I painted my range hood, and I swear it looks like its stainless steel. I used the brushed nickel color. Good luck.
Apr 12, 2014 | GE 24 in. Profile PDW7880G Built-in...
Remove Spray Paint Over Spray on Vehicle
Could try grim and wax remover/prep for auto bodies. Auto stores have it. Then polish/ wax the spot.
Mar 21, 2014 | 2004 Dodge Ram Pickup 1500
How do you avoid getting paint on the ceilings when painting your walls?
Yeah that is some concern there. You use painters' tape that is used for painted surfaces. You must specify what you need so that you will not buy the wrong item. There are tapes that are designed just for painted surfaces. This type of tape will not peel off the paint on your ceiling when you remove it unlike the ordinary masking tape. You can purchase this tape at our local stores near you or you can order it online. We also have other products such as preparation products, preparation equipment, finishing and cleaning and application accessories to make your work easier and quicker. Purchase all these paint accessories at the right store and with the best price.
Dec 05, 2012 | Corel Painter Essentials 4 for PC, Mac...
Is there a common adhesive remover that will work on the tape strip goo that is left behined from trim attachments on an automobile body? Goo-B-Gone and Goof Off, ect. just don't work that well.
wd40 works great on alot of glues and adhesives. spray it on, let it set four a minute,start wiping off with soft cloth. wash car with mild soap and water after. hope this works ,let me know.SARG..............
Mar 14, 2010 | 2009 Chevrolet Silverado 1500
I have a '97 f-150 4x4. I just had it painted and just bought new tires. the tires like to fling rocks which hit the bottom of the bed in front of the tire. I have noticed that on newer vehicles there are...
3M makes a Paint Protection Film that would serve your purposes. Do a Google search for "3M Paint Protection Film". It is available to the public, but not cheap. You do have to be sure you line it up correctly before applying it, because it is extremely difficult to remove without a heat gun and patience without removing the paint with it.
If my answer was helpful, please rate it as so. Thanks. Rolanddirty
Jan 01, 2010 | 1997 Ford F150 Regular Cab
Remove them from painted walls.
go to napa or loure local car care place and get goop hand cleaner
Nov 24, 2009 | Toys
How do I remove scotch tape from paited surface? When I peel it, it takes off the paint. I used scotch tape to hang spider webs for a Halloween party and now I cannot remove the tape without taking off the...
Yikes, sounds like you had a bad paint job! I would try goof off the waterbased orange gel first.
Sounds like you may need to take a bit of the peeling paint to your local paint store and get them to match it. A chip at least the size of a quarter will help them. Then fill the chipped area's with Crack Shot filler and touch up.
Nov 02, 2009 | 3M Scotch Filament Tape Hand Dispenser...
I want to know how to camouflage a jeep the best
Knowing how to paint a Jeep in camo patterns means you can hide your Jeep in the woods, marshy areas or in open fields without it being easily seen. Using Mossy Oak's Shadow Grass pattern, paint your Jeep with natural-looking shadows and grass blades. The 3-D look of this pattern allows you to easily hide your Jeep from water fowl, doves, deer and big game.
Things You'll Need:
  • Sandpaper (120 and 800 grit)
  • Wax and grease remover
  • Lint-free towel
  • Camo stencil
  • Masking tape
  • Masking paper
  • Respirator mask
  • Automotive primer
  • Automotive paint (black, gray, light tan and brown)
  • Automotive clear coat
  1. Sand the surface of the Jeep with 120-grit sandpaper until the surface is dull. You can use a dual-action sander for this step to speed the process. This removes the top clear coat and prepares the surface for primer. Primer won't stick to a shiny surface.
  2. Mask off areas of the Jeep that won't be painted, such as the windows, tires and passenger area of the Jeep. Wipe the surface with wax and grease remover and a lint-free towel.
  3. Spray primer on the Jeep in three thin coats. Allow each coat to dry completely. Once the primer is dry, use 800-grit sandpaper to sand the top layer of primer until smooth. This leaves a smooth surface for the paint. Wipe again with wax and grease remover and a lint-free towel.
  4. Paint a thin base coat of gray on the Jeep. Cover all of the primered areas on the Jeep so that no primer can be seen. Allow the paint to dry.
  5. Go over the Jeep with brown paint, spraying small areas of brown paint in no particular pattern. The finished effect should look like the Jeep is equally painted gray and tan. Hold the first stencil against the Jeep and use black paint to fill it in. Move the stencil over and paint again. Start at the front of the Jeep and work towards the rear.
  6. Move on to the next stencil and use light tan paint to spray the grass pattern. The grass should start at the bottom of the Jeep and reach up towards the top. For longer grass, don't spray the tops of the grass but instead move the pattern up, spray the stems longer and then spray the tops, making the grass stems long. Repeat this around the Jeep and across the hood. Go back over the grass stems with black paint, lightly spraying a few of the stems to give them a shadow look.
  7. Finish by spraying three coats of clear coat paint onto the painted areas of the Jeep. This protects the paint from UV rays and keep the camo pattern looking good.
Tips & Warnings
  • Paint is best applied using a paint spray gun and air compressor, but canned spray paint will work.
  • Never sand or spray primer or paint without using a painter's respirator mask.
Resources: Customice Camo Stencils
I really hope help you with this (remember rated this help) Good luck.
Oct 21, 2009 | 1984 Jeep CJ7
Dynabrade Eraser Wheel With Hub For Dynazip Decal Removal Tool 92257 Logo
165 people viewed this question
Top Dynabrade Saws Experts
Tom Chichester
ray gallant
Are you a Dynabrade Saw Expert? Answer questions, earn points and help others
