Question about Kenmore 63942 Dryer
No heat replaced heater element,checked hi limit,thermal cut off ,thermal fuse,timer, and still no heat????????????????????
  • 188 Answers
Check the home electrical fuse panel or reset the breaker (even if it looks like it's not tripped).
Posted on Feb 19, 2009
  • Paulo Feb 20, 2009
    How was that inappropriate? Do you have 240V going to the machine?
  • Paulo Feb 21, 2009
    Hi, I'm still waiting for a response from you so I can try to help you resolve this issue... I'm looking for a FixYa rating!
No Heat- have replaced thermal cut off, thermal fuse and the heating element with no success. Any idea what else I should check?
  • Thermal Fuse,Timer, Temperature Sensor, Coils, Gas Control Valve, Radiant Flame Sensor, Igniter, Cycling Thermostat, High Limit Thermostat, Heating Element!
  • The things listed above can all cause no heat in drying if they are not working, or working correctly!
Mar 02, 2016 | Kenmore Dryers
Whirlpool dryer bad heating element AGAIN
Hi Warren Fink
Try this solution to your problem
A vent clogged with lint can cause the dryer to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
Please take time to rate me
Bud
Oct 18, 2012 | Whirlpool Dryers
Does the Kenmore Series 700 dryer use circuit breakers or a thermal fuse to shutoff the heating element?
All Kenmore Electric Dryers use a thermal cut-off or thermal cut-out, hi-limit thermostat, and a cycling thermostat apart from the motor centrifugal switch as parts of the heating circuit. The thermal cut-off/thermal cut-out and the hi-limit thermostat are located on the heater duct/element duct while the cycling thermostat is located on the blower housing.
The thermal cut-off/cut-out serves as a safety measure and blows open should the dryer overheats or should the hi-limit thermostat fails to cut off power to the heating element. Check the continuity of the thermal cut-off/cut-out and if open, replace it including the hi-limit thermostat.
Aug 22, 2011 | Dryers
Electric dryer spins no heat, replaced heater element and high limit thermostat, tested thermal fuse and it does have 0 ohms, thermistor reads ~50 ohms.
in addation to checking the high limit t-stat have you checked the thermal cut off (the small t-stat) on the heater housing where the element fits into, the high limit t-stat and the thermal cut off BOTH shoud have 0 ohms (the thermal fuse is in the blower housing) the cut off is on the heater box, if you have checked those to be good, check that the heat relay on the control board is closing and sending power to the element, if not replace the control, if all above are good then the motor switch is bad and not sending power to the element(thats a built in safety feature so the dry would never heat when the motor isnt running)the element of course heats only when 240 volts ac is to the element ,120vac from the relay on control through the high limit t-stat then through the thermal cut off finally to the element and 120vac from the motor switch for a comined 240 vac
Jul 20, 2011 | Kenmore Dryers
Will not heat
If the model number you posted this question under is correct, your heating circuits are comprised of the following components:
1. Heating Element
2. Thermal Cut-Out
3. Hi-Limit Thermostat
4. Internal Bias Thermostat
5. Thermal Fuse
You can access them by UNPLUGGING the dryer and removing the rear panel.
As viewed from the rear of the dryer, your Heating Element will be located on the RIGHT hand side inside a heater box. The Thermal Cut-Out will be located on the outside of the heater box at the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
The Internal Bias Thermostat and Thermal Fuse are two small components mounted on the Blower Fan housing on the lower LEFT hand side.
You can refer to the following parts illustration for assistance:
http://pcappliancerepair.com/model-display.php
The components are listed as follows:
Heating Element (Item 17)
Thermal Cut-Out (Item 6) - This is a replacement kit. Includes Item 15 when ordering.
Hi-Limit Thermostat (Item 15)
Internal-Bias Thermostat (Item 20)
Thermal Fuse (Item 19)
If your dryer is NOT configured this way, please post back with your complete MODEL NUMBER (located on a nameplate around the door opening) and let me know.
If you need assistance on how to troubleshoot a dryer, you can refer to this link:
http://www.fixya.com/support/r3574266-thorough_dryer_advice
The MOST common causes of heat related problems:
1. Blown Thermal Cut-Out.
2. Missing 1/2 your input voltage at the wall receptacle (the dryer will still run with half the voltage missing, but won't heat - double check your source voltage at the receptacle and/or your circuit breakers.
3. Bad power cord, causing 1/2 the input voltage to be missing.
4. Blown heating element.
Read through all the information provided and let me know if you have any questions. I hope you find this information helpful.
NOTE: Take all resistance readings with the dryer UNPLUGGED and the component under test isolated (meaning disconnect any wire leads to ensure the accuracy of your readings).
Apr 23, 2010 | Whirlpool LER4634J Electric Dryer
My kenmore series 500 dryer does not heat up
The closest model number reference I could find for what you have provided is "110.69522800". If this model number is correct, your heating circuits are comprised of the following components:
1. Heating Element
2. Thermal Cut-Out
5. Thermal Fuse
You can access your heating circuits by UNPLUGGING the dryer and removing the rear panel.
http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fK0809032-00003.png
Heating Element (Item 14)
Thermal Cut-Out (Item 1)
Hi-Limit Thermostat (Item 34)
Internal-Bias Thermostat (Item 40)
Thermal Fuse (Item 9)
If the dryer is running, but not heating, this is not always an indication of a blown heating element. If you need assistance on how to troubleshoot a dryer, you can refer to this link:
The MOST common causes of a dryer that will not heat are:
1. Blown Thermal Cut-Out (replace the Hi-Limit Thermostat along with the TCO if found to be bad).
2. Bad Heating Element.
3. Missing all , or part, of your input voltage at the wall receptacle - double check your source voltage at the receptacle and/or your circuit breakers.
4. Bad power cord. Check the terminal block on the back of the dryer with the cord plugged in. If the voltage is good at the receptacle, but missing a the terminal block, you may have a bad power cord.
Read through all the information provided and let me know if you have any questions, or need further assistance. Please post back with your correct MODEL NUMBER if the number I have provided is incorrect. I hope you find this information helpful.
Apr 19, 2010 | Kenmore 500 6952 Dryer
Element not heating
If the model number is correct, your heating circuits are comprised of the following components:
1. Heating Element
2. Thermal Cut-Out
5. Thermal Fuse
You can refer to the following parts illustration for assistance: http://pcappliancerepair.com/model-display.php
1. Blown Thermal Cut-Out (replace the Hi-Limit Thermostat along with the TCO if found to be bad). 2. Bad Heating Element.
Read through all the information provided and let me know if you have any questions, or need further assistance. I hope you find this information helpful.
Apr 19, 2010 | Whirlpool LER4634J Electric Dryer
No heat and believe it to be the thermal fuse on kenmore dryer 63
Unplug it, remove the back, f73a9b7.jpg1. Hi Limit (small limit upper right hand side of this pic) the most frequent problem if dryer RUNS but no heat AND you have
checked the element and found it to be good. 2. heater assembly.
3. 250f limit (if bad no heat, timer won't advance)
4. heater element
5. Fuse(350F), if blown(open) the dryer will NOT run.
(if you do not have a meter remove and inspect this heater coil for breaks).
6. control thermostat
7. heater (warms thermostat to shut it down faster for delicates)
Apr 13, 2010 | Kenmore 63942 Dryer
How many thermostats are there and where are they located?
1. Heating Element
2. Thermal Cut-Out
5. Thermal Fuse
Thermal Cut-Out (Item 9)
Internal-Bias Thermostat (Item 8)
Thermal Fuse (Item 7)
If you have any questions, or need further assistance, please post back and let me know. I hope you find this information helpful.
Mar 21, 2010 | Whirlpool WED5700S Electric Dryer
Kenmore dryer (electric )
You will need to UNPLUG the dryer and remove the back panel to access. The heating element is located inside the heater box on the right-hand side of the dryer (facing from the back). Simply disconnect, the wires leads and remove the mounting screws to remove.
Now...you mentioned removing the thermal fuse. Did you check the thermal cut-out or the hi-limit thermostat? These components are small silver disc-shaped devices mounted on the heater box assembly. As you are facing the back of the dryer, the hi-limit thermostat is located near the terminal connections of the heating element. The thermal cut-out is located farthest away from the heating element closer to the top of the heater box. Usually when you have a no heat problem, it the thermal cut-out, hi-limit thermostat, or heating element that goes bad. If the thermal fuse is bad, you generally have a dryer that not only won't heat, but won't even turn on. I hope I'm not confusing you. In a nut shell, there's a difference between the thermal fuse and the thermal cut-out. If you had large accumulations of lint in your dryer, I would bet you have a blown thermal cut-out.
If you wish to check the parts listing yourself to make sure you have the correct parts, go to searspartsdirect.com, type in your model number and look under the "Bulkhead" heading. The thermal cut-out kit is what you need to order for a no heat problem. It's listed as item #1 (part #279816). This also includes the hi-limit thermostat. It is recommended by the manufacturer to replace BOTH of these components at the same time. The heating element is listed as item #14 (part #279838).
Look under the "view diagram" heading and you can see where all these components are located, using the exploded view of the dryer assembly. The thermal fuse you mention is listed as item #59 in the drawing and is located on the air baffle housing.
This is still an easy fix. I just want to make sure you're identifying the correct parts. I don't think you want to purchase parts you don't need.
I hope this helps you. If I've managed to confuse you, please post back with your questions and I can guide you in the right direction.
Apr 16, 2008 | Kenmore 43142 Front Load Washer
Kenmore 63942 Dryer Logo
74 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
