Question about Whirlpool GU2400XTP Built-in Dishwasher
DISHWASHER 6TH SENSE COMES UP WITH CODE F4 CAN'T GET IT TO WORK
HAVE JUST MOVED INTO HOME AND HAVE NO OPERATION GUIDE FOR DISHWASHER. ADP6966 TURNED DIAL AND PRESSED START IT KEEPS STOPPING AND COMING UP WITH CODE F4. HAVE CHECKED FILTER FOR BLOCKAGE SEEMS TO BE CLEAR.
    Top Expert:
  • Whirlpool Master
  • 78,289 Answers
What u have to do is take the cover off the bottom giving u access to the motor and all the pipes drain all the pipes and the salt store container blow out the drain pipe n thats it simple as basically f4 is when the pipes are water locked normally due to power failure half way through a cycle
Posted on Feb 18, 2009
    Genius:
  • 1,847 Answers
F4 problems, solved by *thoroughly* cleaning and de-greasing the filter frame, basket and sensor - we also quickly realized that there was a low threshold for oils/greases/debris of any kind, so we rinse and load.
This week's F4 was solved after a good hour of removing outflow tube (clean), cleaning and inspecting all interior parts. Another forum post indicated pump/impeller blockage may also cause F4, so I took some light gauge wire, taped the end so as not to scratch or snag, and jammed it into the outflow opening in the well, poking vigorously at the impeller blades. 10 seconds later I was able to run a complete cycle of *already clean* dishes without problem. It ain't scientific, but I can get on with my day!
    Sergeant:
  • 326 Answers
Unplug the dishwasher for couple of minutes.remove every utensil from the unit.also clean it properly from inside.then check out for any small oject blocking any where inside.clean it propely and check out.it will work.
Dishwasher lower spray arm will not move or turn by hand
Search Results
    Dishwasher Spray Arm Not Turning ' Home Guides ' SF Gate
    homeguides.sfgate.com > Foreclosures > Other Foreclosures
    Remove the lower tray of the dishwasher to freely access the spray arm. Turn it byhand, and if it doesn't move freely, you will need to unscrew or unbolt any ... How to Remove the Lower Wash Arm on a Maytag Dishwasher MDB7000AWW ...
    Maytag dishwasher bottom spray arm doesn't turn - Home Repair Forum
    www.homerepairforum.com > Forum > Indoor Home Repair > Appliances
    Jan 3, 2009 - 5 posts - ‎3 authors
    I'm now soaked, but I was able to determine that the lower arm isn't turning. There's a LOT of water coming out, but it doesn't move. Turning by hand I can turn it freely, it spins like a top. .... You may not post new threads; You may not post replies; You maynot post attachments; You may not edit your posts.
    How do i remove the lower spray arm of my Maytag .
Jan 18, 2016 | Maytag Dishwashers
Tip
Tumble dryer not heating how to fix heater, thermostats, Ntc sensor.
We have all these tutorial guides that will help you with your Whirlpool 6th sense
How to clear error codes
How to service a pump unit on condenser tumble dryer.
How to replace belt, motor or bearings.
Tumble Dryer Not Turning, How To Replace Capacitor
We have all repairs guides on these Whirlpool 6th sense Tumble Dryers
http://www.how-to-repair.com/help/tag/6th-sense/
on Jan 21, 2015 | Whirlpool Dryers
HOW DO I LOCATE THE HEATING ELEMENT ON THE 6TH SENSE DRYER
take the back panel off it is located in the rear.
Mar 19, 2010 | Whirlpool Dryers
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
Whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
how do i replace my belt on my tumble dryer
Jan 09, 2010 | Whirlpool Dryers
F4 fault on fisher paykal dish drawer
F4 fault would inidicate the temperature sensor that senses the water temperature is faulty or the heating element is not working.
Looks like you will need a technician to visit and have a look.
Dec 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dryer not heating, still tumbling
your heating element could be burned out...or a thermal switch could be stucknot allowing the element to turn on
May 25, 2009 | Dryers
Whirlpool dishwasher
We had same problem with our ADP 5966. An engineer over the phone said he thought it was related to machine being unable to drain. I checked the drainage pipe connection to u-bend under sink, and sure enough, there was a major blockage. Cleared that and hey presto, problem solved.
Jul 31, 2006 | Whirlpool 24 in. ADP5966 Free-standing...
Whirlpool GU2400XTP Built-in Dishwasher Logo
455 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
