Question about Sony CMT-NE5 CD Shelf System
No disc error
I believe its the support pad thingie on the underside of the lid, it "sometimes" works if i tilt it , how can i fix it?
    Top Expert:
  • Sony Master
  • 74,634 Answers
Hello
You are not right. The fault is with its Laser pickup unit itself. Replace it with same type and number. OK.
Posted on Jan 24, 2012
F 5 error top draw only
Fault code F5 is a lid fault error. It could be one of many issues and generally will need a technician to fix it. The problem could as simple as the lid seal that seals the drawer being displaced or the actuator motors that bring the seal down being faulty. Turn the mains power off to the dishwasher and back on. This should bring the actuator motors to start position. If this does not fix it then check under the top housing for any signs of lid seal break. If it looks ok then you have to call technician to fix it. The fix involves taking the drawer out carefully without damaging the wiring and hoses underneath and checking the lid seal assembly underside of dishwasher housing.
Mar 15, 2015 | Fisher and Paykel 24 in. DD603H W Built-in...
Flashers dont work.only sometimes ,if i put hazzard lights on they will work again for awhile
sounds like a loose connection or possibly dirt is preventing a full contact dirt / dust / food something ...
do you have {Tilt wheel} ? if so the wires may be from over time and use bending and causing friction etc to break and allowing only connection sometimes such as if you use the tilt wheel and just by luck allow it to make contact this is very common with tilt wheel
could also be the blinker relay not making full contact ..locate it i believe on your vehicle its either under the dash otherwise next to the fuses it is round and silver in color { aluminum }
would need to know if tilt wheel is an option 1st to better my answer and if so replacement of the lever 4 way or removal of the lower steering column removal to determine the break in the wire or wires for repair hopefully it will be an easy fix for you .
Dec 31, 2009 | Chevrolet Impala Cars & Trucks
I realized that my GE washer was not spinning because the lid actuator pad is missing. I can pull the hook to make it work, but it needs the pad. They cost about $30 for a small piece of plastic! Is...
all that lid pad is ;is a strong magnet in plastic. find a strong magnet in a craft store. fridge magnets wont work they arent strong enough.
Sep 12, 2009 | GE Washing Machines
No Red Rings, can't turn on
try difrent powerbrick and take the extra fan out
Jun 18, 2009 | Microsoft Xbox 360 Console
Ps3 disc read error
my ps2 had the same problem, i called some one to fix it and he changed the blue thingy (i call it the blue laser) and it worked for me
hehe...sry for no helping much
Apr 09, 2009 | Sony Playstation 3 (PS3) Console
Loose? pad thingie (no disc)
Hello
The focussing secion coils inside the laser pickup unit is faulty. There is no repair to this fault, except replace the laser pickup unit with same type and number.
Feb 18, 2009 | Sony CMT-NE5 CD Shelf System
ND Code
The grinding is in the pump, probably some soda change. nd is no drain. Which model front or top load? Top load the pump is front right and has two hoses on it. Try to drain the water out and tip the machine back enough that it stays and spin the belt off. Set it down and use a putty knife and feel along the first two inches left and right where top meets the front panel. You find two catches that when depressed will allow access to the top underside. Hold the lid and tilt the top back, make sure the console clears the back wall and gently let the lid go back, make sure it stays. Ok the front panel has two 5/16 hex head screws holding it to the sides. They are one inch down at either side, hard to see with out light. Once these are out the panel tilts towards you held at the bottom by two prongs, tilt and pull the bottom towards you and up. The pump has three 5/16 hex screws or 3/8 and the rest is wet and looking in the pump for junk to clean out.
Sep 06, 2008 | Maytag Neptune FAV6800AW Top Load Washer
1989 cutlass oldsmobile with tilt steering wheel ?
remove column trim, insert ket turn to on position, and push the pin in at the underside of the steering column pull straight out please rate -jeff
Jul 29, 2008 | 1989 Oldsmobile Cutlass Supreme
Canon 9900f scanner glass removal
I would not worry about the underside of the glass unless you are having problems. The focal length of the ccd that captures the image is very specific and probably will not pick up anything under the glass. It is normal for the underside to look foggy but it will not hurt anything.
Jul 25, 2008 | Canon CanoScan 9900F Flatbed Scanner
Motor drive not working on a ps2 slim
Do you mean the the disc isnt spinning?
1st off check for a small black plastic post on the underside of the lid. It points down. it's towards the back. If that's not there, the disc brake stays on ie; disc wont spin.
2 Check for debris where the lid comes down into the 2 sensor switches . One near the power/reset switch and one at the left side rear. The switches are tiny and if they get junk in 'em , they wont work
Jul 21, 2008 | Video Game Consoles & Games
Sony CMT-NE5 CD Shelf System Logo
131 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
