Question about Brother Multi-Function Center MFC-3360c All-In-One InkJet Printer
TROUBLE SHOOTING There was a paper jam and we got all the paper out followed manul. Now it still says PRINT UNABLE 30 SEE TROUBLE SHOOTIIN AND ROUTINE MAINTENANCE CHAPTER IN THE USER'S GUIDE. So i did but its still not doing anything and it keeps coming up. Please help as my mum trying to print work stuff and shes really upset so im trying to help
I am having a problem as well. I can't use the Fax either. Very difficult to see th jammed paper. Followed all instructions, but unable to clear the jam.
Posted on Aug 15, 2009
We do have a sheet that is jammed, we are unable to pull it out, we did try from the back, underneath and also opened the front, but unable to pull out the toner and the drum. Please help as soon as...
Hi goldenhor978,
I see that you are having issues with you Brother DCP-7030 All-In-One Printer.
You mentioned that you have a jam in it but could not pull it out and that you have tried all possible options to remove the Jam.
Check this link it has all the information that can help you with your concern, it also has visual pictures to show how and what other options you can do to remove the Jam.
Manual Trouble shooting Guide.
In the manual Go to section IV Appendixes,B troubleshooting and Routine, Error and Maintenance Messages, Paper Jam.
Follow the steps where you can locate the paper Jam troubleshooting for further details on your Query.
I hope that this helps.
Thank you for choosing Fixya,
mvincentc
Jun 21, 2011 | Brother DCP-7030 Digital All-in-One Laser...
UNABLE TO PRINT, CHECK ROUTINE MAINTENCE AND TROUBLESHOOTING I
Could be many problems. Did you get a error code number? If so, look for that in the manual or go to the brother website and check
Jun 16, 2010 | Brother MFC-9420CN All-In-One Laser...
Will not print. in window it says "unable to clean MFC-420CN" see trouble shooting and routine maintence. How do I fix this problem I no longer have a book with this fax printer machine.
You could check for a paper Jam or foreign oblect in the machine, under the top cover and in the back cover.
If there isnt a Jam in the machine it means there is a mechanical problem. There is a sponge in this machine and once it is full it wont be able to absorbe any more ink from the cleanings. You will need to bring it in for services, they would replace the sponge and reset the cleaning counter.
Check the brother website to find a service center in youre area.
Apr 10, 2010 | Brother MFC 420CN All-In-One InkJet...
Clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide.
Hi there. . . okay . . . Follow this step
1.) Unplug your printer.
2.) Plug your printer again while holding the menu button 15 sec.
3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK
4.) then numbers appear looks like this ###:### ###:###.
5.) now push the MONO button until the purge:#### appears on the LCD
6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
7.) - switch off the printer ,switch it on
- ready to print
- CHEERS!
 email me if I help you. . ryuuzaki182@gmail.com
Mar 20, 2010 | Brother DCP 165C Compact Color Inkjet...
Unable to init.
If there is no jam it is generally a mechanical issue such as...
1. The planetary arm assembly not engaged correctly
2. Ink cartridge/purge switch harness not connected correctly
3. Purge cam switch broken
4. Gear(s) on maintenance unit broken
5. Paper feed motor broken
6. Main PCB defective
I find that if there was a paper jam, and the user pulled the paper out, option 4 is most likely. It is the smallest of cracks but ruins everything!
You will need to contact your local ASC for repair, find it here.
Thank you for using FixYa! – Don’t forget to rate our service.
Dec 20, 2009 | Brother MFC-5840CN All-In-One InkJet...
Message unable to print 50
Machine Error 50 either means that there is a loose object inside the machine (usually piece of paper), or that there is a mechanical error which would need you to have the machine sent to service.
Jun 02, 2009 | Brother MFC 240C All-In-One InkJet Printer
Print unable see trouble shooting and routine maintenance
sending fax is working alri.ght, only when I try to recieve fax it gives an error 30 on the display. At the same time it unable to clean. Please help me with this.
Jan 17, 2009 | Brother Multi-Function Center MFC-240C...
DCP 115C does not print
Check for foreign objects, such as a clip or ripped paper, inside the machine.
Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely
the manual states for this problem
"The machine has a mechanical problem.
OR
A foreign obstacle such as a clip or ripped
paper is in the machine."
Aug 05, 2008 | Brother DCP 115C All-In-One InkJet Printer
Error message on my mfc 420 mc
this has been written many times here in the forum.
plz search forum "unable to print"
Jun 22, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother Multi-Function Center  MFC-3360c All-In-One InkJet Printer Logo
169 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
