Question about Whirlpool Inglis IP4400 Washer
My washer will not spin or drain
My washer will go thru allcycles except for the spin cycle. when itr gets to the spin cycle it stops and will do nothing else
    Problem Solver:
Most washers have a timer relay if it has started to go out this is one of the problems that can happen so check thie timer relay it is the big nob you turn to start your washer. Just so you know sometimes the relay cost more then a new washer but it's worth cecking out.
Posted on Feb 18, 2009
Washer won't spin. Motor goes thru cycle but not spinning
My kenmore washer won't spin - EASY FIX (PART ONE ...
? 5:45
Feb 1, 2013 - Uploaded by Michael Borders My Kenmore washer's agitator stopped spinning my cloths during the wash. NO BIG DEAL!!!! EASY and ...
How To Fix A Washing Machine That Is Not Spinning or ...
May 13, 2013 - If your old or new washing machine does not spin we have some diy fix tips ... Fix Washing Machine That Won't Drain - Washer Not Draining ...‎Washer Not Draining Water - ‎Washing Machine Service ... - ‎How To Fix A Washing ...
Nov 02, 2015 | GE GTWN4250MWS 27" top-load washer with...
If the timer advances normally thru the spin and drain steps of the cycle you selected, than the problem that would cause neither spinning or draining, is the wash motor is not reversing. The motors is a two direction motor. It spins clockwise for normal agitation, but counterclockwise to engage the wash drum clutch and operate the drain pump. I would ask you to check for motor sounds at all during the spin and drain cycles. The pump reversing in the spin or drain cycles can be a function of the machine's lid safety switch, or if not the motor switch or timer contacts. The lid switch is first thing to check here, for sure! If the machine seems to stop running when it comes time to drain or spin, the lid switch is your best bet!
Hope this helps.
Jan 16, 2011 | Roper RAS8445KQ Top Load Washer
I have an Estae(whirlpool) washer that i have had for 9 yrs. It works fine until it get to the spin cycle. Then it stops and the water stays in the washer and will not drain. Every different wash mode...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
Dec 12, 2010 | Washing Machines
Kenmore 110 Spin Cycle
Assuming that this is a basic top load, direct drive, neutral drain washer it seems as if the problem is likely in the timer.
The transmission and draining are controlled by the motor which gets it's power through the timer. If the timer isn't advancing once it gets to the spin cycle area, the motor keeps getting power, the machine keeps spinning and only by pushing in the control knob will the motor stop.
Here are a couple of places to look at how the machine works and parts for a basic Kenmore washer.
Sears parts site:
Enter your model number and you'll see a number of sub catagories for the washer components.
Whirlpool Installation and maintenance PDF.
This is a public domain Whirlpool manual describing how the washer works and a good troubleshooting section.$FILE/L-55.pdf
Sep 21, 2009 | Kenmore 22642 Top Load Washer
Does not agitate or spin - fills and drains - checked belt & pulleys seems fine
Welcome to fixya.
I'm Huuum and happy to assist you,
The washer is equipped with a lid switch failure detector. If the lid switch
should malfunction, the detector will stop operations for your safety.
Read below
First,turn the control dial to proper cycle and pull dial out to start the washer. If
equipped with buttons, be sure they are fully depressed.
Close lid and pull dial out to start the washer. For your safety, washer will
not agitate or spin unless the lid is closed.
should malfunction, the detector will stop operations for your safety. Call for
Pauses are normal. Wait and see if the washer will start again.
Please remember to leave a rating before you go!
Thank you
Sep 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
The tub never starts to spin when it hits spin cycle.
If your washer functions when the door is shut it cannot be a door problem. The likely thing here is you may have a drain problem....your drain oulet filter (or out pump) could be blocked. This requires cleaning; when the washer goes thru all the functions except spin it is most likely your drain is clogged. Aft u have cleaned the filter & pump check by a small spin. Before you attempt, wall socket off & keep bucket handy to collect water.
Apr 29, 2007 | Crosley CW6000 Front Load Washer
Whirlpool Inglis IP4400 Washer Logo
231 people viewed this question
Dan Webster
Dan Webster
Sal De
