Question about Toshiba 55H70 55" Rear Projection Television
I need to get the front panel off how do i do
I need to get the front panel off so i can clean it how do i do that????
  • 184 Answers
Pull off the two speaker grills. They will seem like they are going to break but they'll snap out. You'll then see the 8 screws that hold the plastic lower facing in place. (4 on each side) Once you remove the facing, you can see the 4-6 screws that attach the screen assembly at the bottom of the screen. Once you've removed them, you simply place a hand along the left anf right edge of the screen assembly and pull up. This will pull the screen assembly off the plastice hooks inside the cabinet that hold the screen assy. in place. You can now clean the mirror and lens assys. You can use windex on the mirror but many projection TVs have plastic lenses so use a prepared solution from a video store or make your own with luke warm water and a couple drops of dish washing liquid. Don't get the lens too wet, so that water drips onto other parts of the TV.
Posted on Feb 18, 2009
Washing machine works well but, water settles in the front lip of the washing machine. Is that normal? Looks like if sitting could cause mildew issues
If it is a front loader then you might need to clean the clean out trap behind the bottom panel. Check your manual first. Some units have three screws that hold the front bottom panel on. When the front panel is removed there might be a strainer that would need to be unscrewed. The screener slides out and usually catches all sorts of items. Be aware that water might also come out too. Remember this is a generic answer as all washing machines are different do check your manual.
Sep 13, 2017 | Washing Machines
A leading cause of poor drying results in that type of dryer is lint build up in the blower/lint filter housing. That build up will restrict air flow through the dryer causing very long dry times. To repair that the front panel would need to be removed and clean all the lint build up from that housing and blower wheel area.
To remove the front panel DISCONNECT POWER TO THE DRYER, on the bottom of the dryer inside of the door rim will be 2 phillips headed screws,remove those and lift off the top. At the top corners where the front panel connects to the cabinet will be 2 more phillips headed screws remove those and the front panel will pull off and out of the way. With the front panel off the blower housing will be in the lower left side clean lint from it and also the sure to clean all the lint from the lint filter housing which will be attached to the back side of the front panel. In addation to cleaning that area be sure to check and clean the exhaust duct tube as well.
Oct 13, 2011 | General Electric Dryers
The machine stopped with one minute left in the cylce and it won't re-start or allow me to push cancel/end cycle
I unplugged my machine and this reset it, but the filter in the machine needs to be cleaned and the hose in the back might also need cleaning. Clean the hose in the back first and then see if the machine will drain. Once it is drained you will need to clean the filter. It is in the front of the machine behind the access panel. It works best to prop the front of the machine on small boards. The three screw for the panel are on the bottom. Once these are removed you will see the plastic filter. Twist the cover off and clean the filter. WARNING: Have towels on floor before opening filter. Plenty of water will still be in the filter area.
Feb 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How do I clean the lint from the dryer past the lint trap?
you need to unplug the dryer,then with a putty knife stick it in between the top panel and the front panel and there are clips one on each side that you release with the putty knife and remove the front panel or you could have two 5/16 inch screws on the bottom of the front panel but i believe your model has the clips,when you remove the front panel you need to clean out the duct that the lint filter slides into,vac out the inside cabinet where the motor is,put it back together then pull out the dryer and remove the vent line from the rear,if it's a long run to the outside you can stick a leaf blower inside the vent line and blow all the lint out to the outside hood,before you blow it out go outside and make sure the hood is clear then blow out the line,
Oct 30, 2010 | Maytag HYE3658AY Electric Dryer
Front panel has gone yellow with the heat
it will not clean you will need a new front panel
Jun 30, 2010 | Heating & Cooling
How to remove front cover for cleaning
I don't know too much about your particular make / model but most window units have a 1 piece front cover which is usually held on to the main cabinet with 1 or 2 screws at the sides and 1 or 2 behind the filter panel. You will need to remove the front panel to remove the vents as they are usually fitted from behind the panel.
May 31, 2010 | Friedrich QuietMaster SM18J30BR Air...
Where is the pump/filter located on my Kenmore Front Loader Washe
It is just behind the lower panel. Remove the 3 screws from the lower panel (the panel just below the door), the screws are on the lip on the bottom of the panel facing the front of the machine. Pull down and toward you to get the panel off. The filter and clean out are in the center. Unscrew the cap to remove and clean out, but have lots of towels ready, there will be water coming out.
Apr 20, 2010 | Kenmore HE2 Plus Front Load Washer
KA dryer has been running without a lint filter. Other owner. I need to know how to take off the front and back panal to clean inside due to fire hazzard. Mdl # KGYE800TWHO . Need schematic drawing. I am...
Disconnect Power. Lift Cover on lint filter. Remove two Phillips screws taking care NOT to allow them to fall into the blower housing. Next, place a putty knife in the space between the upper and lower panel at the front of the dryer about 4 inches in from either side to push up the retaining clips while pulling on the lower panel. This will release the lower panel and give you full access to all the main components and most internal areas needing cleaning.
The only area affected by running with no lint filter is accessed by removing the rear panel. With rear off, the filter housing on the left will have several 5/16" hex head screws to be removed for access to the blower wheel and housing interior. With screws removed go to front and insert putty knife in the seam between the top and front panels about 4 inches in from both sides. Lift top at same time and raise when disengaged.The filter housing can now be moved sufficiently to vacuum the interior from the rear removing any large foreign objects first.
You have now cleaned all the dryer areas that need cleaning. Don't forget the airflow through the vent line of the house.
Reverse the above process to reassemble unit. Good Luck.
Wiring Diagram for your model is located at link below:
KGYE800TWH0 Wiring Diagram
Oct 02, 2009 | KitchenAid Dryers
I can't totally clean the lint trap on my PYE2300AYW Maytag dryer. How can I completely remove the lint trap to clean it?
If lint has gotten past the lint trap, you can attempt to use a brush just like the previous poster suggested. If that doesn't work you'll have to disassemble the unit. You only need to lift the top up and remove two screws on each side that connects the front to the side panels. The front should then swivel outward. Be sure to detach the door switch and wire guide from the front panel before completely removing it. You can then lift the front panel up and away. You'll need to clean the opening in the bottom of the front panel and also the entrance to the blower.
Jul 07, 2009 | Maytag Dryers
Front Panel
unscrew the screws around back, but hold front will start falling when screws are out
Jan 14, 2008 | RCA D52W19 52" Rear Projection Television
Toshiba 55H70 55" Rear Projection Television Logo
112 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
