Question about Lexmark X4270 All-In-One InkJet Printer
How to scan to email
How do i scan a page to send in a email
    President:
  • 2,692 Answers
Download the users guide for use directions:
http://www.lexmark.com/publications/pdfs/2007/4200/en.html
Posted on Feb 18, 2009
  • 105 Answers
SOURCE: 922 Printer Scanned File Email Attachment Problem
The simplest and fastest option is to compress the document with either WinZip or PKZip. That compression makes the software ignore the attachment. Both programs are pretty universal so that recipients would be able to uncompress the files at the other end. You can download the programs for free from www.tucows.com. Just search their site for those compression applications. If you are on a Mac, you can obtain Stuffit to do the same thing.
Posted on Jul 01, 2008
safenude
  • 124 Answers
SOURCE: scan multiple pages to email
Do you have Microsoft Office?? If you do try this:
First, gather the paper you want to scan. If your scanner has anADF, you can load a stack of pages at a time. The first time you scan,Document Imaging detects the ADF for you.For more information about the ADF and whether your scanner has one,see the documentation that came with your scanner.
You will also want to sort your paper; if you have color pages thatyou want scanned in color, sort these in a separate stack from theblack and white pages. Load your first page, or first stack of pages(with an ADF) in your scanner.
Then, start Microsoft Office Document Scanning (the scanning component of the Microsoft Office Document Imaging program.)
  • On the Windows Start menu, point to All Programs (Programs in Windows 2000), point to Microsoft Office, point to Microsoft Office Tools, and then click Microsoft Office Document Scanning.
Tip If Microsoft Office Document Imaging is already running, you can start the scanning component by clicking Scan New Document on the File menu.
Set up your scanning optionsIn the Scan New Document dialog box, do one or more of the following:
  • To view your scanned file(s) in Document Imaging after they have been scanned (recommended), select the View file after scanning check box.
  • If your scanner is equipped with an ADF, click Scanner, and then select the Use automatic document feeder check box.
  • If your scanner is equipped with an ADF and you have double-sided originals, select the Original is double sidedcheck box to scan both the front and back of multiple pages. Place thepages in the feeder so that the page fronts are scanned first.The Microsoft Office Document Scanningdialog box will appear after each scan, allowing you to turn the pagesover and scan the page backs. Document Imaging automatically collatesthe pages in the correct order after scanning is complete.
  • If you have a true duplex ADF (one that automatically scans both sides of the page), do not select the Original is double sided check box. Instead, in the Scan New Document dialog box, click Scanner, and then select the Show scanner driver dialog before scanning check box. When your scanner driver dialog box appears during scanning, select the proper duplex settings.
  • If you want to scan pages manually, select the Prompt for additional pages check box. Office Document Imaging will pause after each page is scanned, allowing you to place the next page in your scanner.
  • By default, optical character recognition (OCR) is performed onyour document during the scanning process. Although performing OCR addstime to the scanning process, it also has the following benefits:
    • When you open the scanned document in Microsoft Office DocumentImaging, you can search for recognized text in the document, copyrecognized text in the document to another document or program, andsend recognized text in the document to Microsoft Word, withoutperforming OCR manually.
    • You can have your scanned files saved with an automatic filename based on the first words on the page (this is the default.)
    To turn off OCR during the scanning process (you can perform OCRmanually in the document in Document Imaging after scanning), do thefollowing:
    1. In the Scan New Document dialog box, select the preset you want to use, such as Black and white.
    2. Click Preset options, and then click either Create new preset (and then type a name for the preset), or click Edit selected preset.
    3. On the Processing tab in the Preset Options dialog box, clear the Use OCR to recognize the text of the scanned image check box.
Select location, name, or file type for the scanned filesPart of the scanning process is to save a scanned page to a file. Bydefault, when you scan multiple pages, the pages are saved in one file.If you want to save each scanned page as a separate file, select thenaming convention for the scanned files, or change the location or fileformat of the scanned files, do any of the following:
  3. Do one or more of the following:
    • To save each scanned page as a separate file, select the Save each page as a separate document check box on the Page tab.
    • To change the location for the saved files, click the Change button on the Output tab, and select a location.
    • To select the way the individual files will be automatically named, click one of the File Name options on the Output tab. (If you have turned off OCR during scanning, you will be unable to use the Auto name based on first words on page option.)
    • To select the file format the scanned pages will be saved in, click the Advanced button on the General tab, and select the options you want.
  4. Click OK.
Scan your pages
  1. In the Scan New Document dialog box, make sure the preset you want to use is selected, and then click Scan. If you selected the Original is double sided check box or the Prompt for additional pages check box, the Microsoft Office Document Scanningdialog box appears periodically to let you know that the scanner hasfinished. You then have the option to continue scanning (place anotherpage in a scanner that doesn't have an ADF) or turn your page or pagesover to scan the other side. Arrange your page or pages as desired, andselect the option you want to continue scanning.
  2. When all pages, all sides have been scanned, click Done in the Microsoft Office Document Scanning dialog box.
  3. To scan additional pages, review the Get started section above, and then repeat the instructions in this section (Scan your pages.)
Organize pages in the saved file(s)Now that you've finished scanning, it's time to take a look at theresults. If your scanned pages are not open in Document Imaging, do thefollowing:
  1. On the Start menu, point to All Programs (Programs in Windows 2000), point to Microsoft Office, point to Microsoft Office Tools, and then click Microsoft Office Document Imaging to start Document Imaging.
  2. In Document Imaging, click Open on the File menu.
  3. Locate the file you want to open (by default, the scanned page(s)is saved to the My Documents folder with an auto filename based on thefirst words on the page, such as Page1of.tif) and then click Open.
  4. Repeat steps 2-3 until all of the files you need are open.
You now have an online version of your stack of paper. Here are a few tips to get you started organizing pages.
  • Rearrange pages within a document In the thumbnail pane (thumbnail pane: Presents the current scanned document as one or more small images.), select one or more pages to move. Click any selected thumbnail and drag the selection to the new location in the thumbnail pane.
  • Copy a page to a new document In the thumbnail pane, select the page you want to copy. On the Page menu, click Copy Page. Switch to the Document Imaging document into which you want to insert the copied page. In the thumbnail pane, select the page that precedes the location where you want to paste the copied page. On the Page menu, click Paste Page.
  • Delete a page In the page pane or the thumbnail pane, click the page you want to delete. On the Page menu, click Delete Page.
For more information about scanning or organizing pages, see Microsoft Office Document Imaging Help.
The papers that were once cluttering your desk have now beentransformed into electronic documents. Within these documents, you canarrange pages, move pages to different documents, delete pages, printpages, add annotations, copy text to other Office programs, or send apage to someone in email. And still have room on your desk for yourcoffee.
Posted on Jan 27, 2009
  • 523 Answers
SOURCE: Sending multiple pages in one email attachment after scanning
well go to scanning setting and change it, you change the setting to be sent one by one, if its connected to network, browse the ip address and go to scan and change the setting, if to usb cable go to the driver setting and change it, and i think from the machine setting itself can let you, so its just setting.
Posted on Mar 21, 2009
daryn720
  • 113 Answers
SOURCE: I want to Scan and send by email in PDF format all pages !!
Looking at my manual , it tells me you have a software user guide on the cd-rom ....this is where you will find the answer.
Posted on Jun 02, 2009
  • 857 Answers
SOURCE: scan page > send to my email account > email
Follow these steps :
•1
Place your scanned messages in an easy-to-find folder or on your desktop so that you can quickly locate the files to send them.
•2
Launch your e-mail application, such as Yahoo! or Gmail, and create a new message. Enter the recipient's address in the "To:" field and type in your note in the body of the e-mail message.
•3
Click the "attach" link or button in your open message to append the photos and scanned messages to the e-mail. This action causes a box to automatically appear, which allows you to locate and select your desired photos and messages. Once you've selected the file you would like to attach, click a button like "Done" to complete the link between your files and the e-mail. Alternately, some mail applications, such as Mac OSX mail, allow you to click and drag the files to the body of the message to create the attachment. If you need further instruction on creating an attachment, see your e-mail provider's "Help" or "FAQ" page for guidance.
•4
Click the "Send" button in your e-mail message to send your photos and scanned messages. The e-mail may take longer than normal to complete the delivery process, depending on the number and size of the files that you are sending.
Posted on Oct 20, 2010
How to send a email after scanning?
Save the scan into a folder like my pictures, then send it as an attachment to your email. There are other ways but this is the best and esiest to understand.
Please rate my help for Fixya, it improves my status and it is all I ask for my time helping you with your problem. Thanks
Jan 18, 2012 | Office Equipment & Supplies
How do I scan and transfer to outgoing email??
Hi. Here are the steps you need to do to send a scanned document/image using your default email application. Place your orinal document/image on the printer. Using the Productivity Studio software, click email, select the scan type (photo, several photos or document). Click start. Click create email to attach the file to the email message. Hope this helps. There's also a PDF file User Guide you can download from the Lexmark website for your reference. Just click on this link: http://bit.ly/9gZV0u . Click on the 9500 Series All-In-One User's Guide found below the page. Download the PDF file. Refer to Scanning page for concerns about scanning. Good luck!
Mar 22, 2010 | Lexmark X9575 InkJet Printer
I am a first time user of the scan function. Brother MFC 8440.
Hi there
I myself would just scan the one first and send it to your PC and then scan the other part and send it to your pc and then just copy the first 1 in to the Microsoft word program and then copy the second one and past it into first under it so it becomes as 1 then upload it to your email and send, this is what I do.
Or of cause you can upload 1 first to your email then upload the other one to your email and send.
All The Best Pineworks
Feb 18, 2010 | Brother MFC 8440 All-In-One Laser Printer
How do I scan several pages to email
Create a directory called Scans on your C drive
Scan each of your images and save them as a.jpg or whatever to the Scans directory.
Open a new eamil go to the top bar and hit Attach
Navigate to the Scans directory then hold down the shift key and click on the files you want to send
Hit Attach and they will appear in the box on your email
Send an normal
You can add picture in the same way , just make sure that you place the cursor where you want each picture to show on the body of the email
Jan 25, 2010 | HP ScanJet 2400 Flatbed Scanner
Scan 5 pages. I go to email I have 5 seperate
you can do that by following steps 1.scanning all that pages and save them as different files in your computer. 2. open a word document and copy all the contents of the five different files and paste them in the word doc and save it 3. while mailing you can attach this word document to send all the files as a single attachment
Jul 21, 2009 | Dell Office Equipment & Supplies
Sharp arm 450n (ce-02)
1) If you're actually scanning to an email address, make sure your SMTP email server information in the copier's web page is correct.
If you are using names instead of IP addresses, also make sure your DNS server IP's are correct.
2) If you're scanning to create the fake email set up by Sharp Network Scanner tool, the connection info in your copier is old and needs to be refreshed.
From the computer you're trying to scan to, right click on the Network Scanner Tool icon in the tray, go to Automatic Profile Update, and select Update Now. If you have no tray icon, reboot your computer.
If your copier is set up to store names instead of IP addresses, make sure your DNS information is correct in the web page.
Jun 30, 2009 | Sharp Office Equipment & Supplies
Jun 02, 2009 | Brother MFC 7840W Printer
Turn off confirmation page
log into the web administration page as administrator
choose fax/scan tab
report settings
Tx Report
choose turn on/off/if tx fail
I chose both single and multiple destinations
if tx fails
Tested scan to email and fax to bad addresses and page printed as confirmation of failure
No pages printed for successful Tx
Note - you can still manually request confirmation at printer menu
Fax/scan
fax menu
tx report
on
enter
start fax or scan to email
Nov 05, 2008 | Minolta bizhub 200 All-In-One Printer
Lexmark X4270 All-In-One InkJet Printer Logo
262 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
