Question about Toshiba 43H70 43" Rear Projection Television
Toshiba Tube TV 32AF45 Picture Squeeze in middle
It just happen to my 3 year old Toshiba Tube TV. The screen become squeeze in the middle part. There are no screen picture adjusting screw or control for adjustment. Can it be fix? Thanks for help
In all inputs including digital cable you can see a dark top of a circle across the bottom of the screen with a blue outline of the top circle above it. above that is blue lettering matching whatever the bottom reads (i.e.: TV VIDEO: TO SELECT)
Posted on Mar 27, 2011
    Scholar:
  • 164 Answers
Try unplugging TV while it is on and let sit for 20 minutes. Re-connect and see...
It sounds like your horzontal control is bad. It requires a new circuit board.
Mastersage!
Posted on Feb 18, 2009
My Toshiba 46XV540U LCD TV. Has ghost image plus many white vertical and horizontal line when it is turned on. These lines and the ghost image stay for 20 to 30 minutes and than the picture becomes clear....
Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish board that call T-CON board to do a replacement.This T-CON board sit in the middle at the bottom of the tv LCD screen panel.This T-CON board control all the picture pixels going throught to the tv LCD screen panel.
Jun 11, 2011 | Toshiba 46XV540U 46 in. LCD HDTV
65" toshiba projection tv no picture but has sound..
if you could hear only sound in tv and not picture means it might be the picture tube problem just check it.
Sep 17, 2009 | Toshiba 55H70 55" Rear Projection...
Toshiba 32AF45 Black Rectangle Issue
go into your menu and find closed caption, someone has accidently set the closed caption mode to text, when the on screen display of channel or volume goes away the box appears. turn off the closed caption feature or switch it to something other than "text" mode, and your box will go away.
Apr 10, 2009 | Toshiba 32AF45 32" TV
Picture only in middle of screen
Sounds like vertical problems on your circuit board. Unless you have some electronics experience you'd better take it in for repair.
The inside of a tube TV contains high voltages even when off and unplugged.
GL
Oct 04, 2008 | Toshiba 36A50 36" TV
Picture to wide
This trouble symptom picture wide or"blooming", the picture becomes dim even with the brightness control full on,and there is an abnormal enlargement of picture or raster.Usually,the enlargement is uniform,but there may be some defocusing.In some circuits,the brightness control operatesin reverse(rotating the control for an increase in brightness produces a decrease) after reaching a critical point on the control. If the picture wide is not accompanied by insufficient width(a symptom of horizontal output failure) the probable cause is a high volatge circuit ony,particularly the HV rectifier and HV winding.Any circuit problem that reduces but does not completely eliminate the high-voltage output to the picture tube second anode can cause overscan. The most likely defects are leaking high-voltage capacitors,defective high voltge tube rectifiers,leaking high voltage leads,defects in high voltage circuit protective resistance,and shorted turns in high voltage winding of the flyback transformer.
Hope this may help you;
DON'T FORGET TO RATE:
Regards,
Sep 06, 2008 | Toshiba 32AF45 32" TV
Toshiba tv
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
cost for DYI is about 60 bucks
Feb 12, 2008 | Toshiba 42H81 42" Rear Projection...
Color is not good around outer edges of picture
When the colors are off around the edges on a regular picture tube TV, it usually means that the degaussing thermistor's solder joints have cracked loose. Another possible cause is that a strong magnet, such as in a stereo speaker, was brought very close to the picture tube and has magnetized the tube. Resoldering the solder joints on the degaussing thermistor and demagnetizing the picture tube should put the color back to normal.
Aug 17, 2007 | Toshiba 32AF45 32" TV
Missing channels
Try going through the auto program feature first and see what happens. Otherwise if the set is new have it replaced.
Apr 12, 2007 | Toshiba 32AF45 32" TV
Half a picture
Dont use the set and call a service tech,you might have loose conections in the horizontal circuit,if you keep using it for this problem it might become worst.
Aug 29, 2006 | Sony KV-36XBR450 36" TV
Toshiba 43H70 43" Rear Projection Television Logo
397 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
