Question about Husqvarna Husky 165
Husqvarna 51 chainsaw will barely run, magnito and carberator ok
Magnito, carberator, fuel filter and fuel are all good, will barely run anyone think of what could be wrong?
  • adamw603 May 11, 2010
    do you have spark? is the plug wet from pulling it over? got the right fuel mix? turn the kill switch off, pull the plug, it will be easy to pull over, put your finger or thumb over the plug hole and pull it a few times, do you have compression? if not it may be the piston or rings-best to change both at the same time if your able. jacks small engine on the net is a good source for husky parts.
Factory rebilt 445,ran good 1st time using it. using husqvarna oil. now engine cranks good and revs up good. but when gets under load it stalls. can take it out of cut it still dies. Help
Posted on Mar 14, 2011
    Guru:
  • 597 Answers
Probably need to re-adjust the carburetor jets. They are very small screws in the base of the carburetor. They will be labeled with an "H" and an "L" . Set the low speed first by turning it in slowly until the rpm drops slightly then start turning it outward untill the engine idles smoothly. At that point you can also adjust idle speed. Then you need to be careful here but you need to hold the throttle wide open at the same time adjusting the high speed jet. Turn it in until the rpm drops then slowly turn it out. The rpm will keep increasing. Once you get to a point where it is max'ed out then screw the jet back in one half a turn. Changes in altitude like using your chainsaw in town versus going to the mountains for firewood can sometimes make it necessary to adjust the fuel/air ratio.
Posted on Jun 02, 2009
Husqvarna viking sewing machine bobbin
Could the part number be 4011770? I've found the Viking 7 bobbins here: http://www.mysewingmachineparts.com/top-quality-metal-sewing-machine-bobbins-4011770-husqvarna-viking/ . Another site with them is http://www.sewingpartsonline.com/bobbin-viking-4011770.aspx . This bobbin is compatible with the Husqvarna Viking 7, 49, 51, 52, 21 & 21E . It probably will work for other machines. Sears also has them listed as 11770: http://www.sears.com/generic-viking-sewing-machine-bobbins-sewing-machine/p-SPM6124767105?prdNo=1&blockNo=1&blockType=G1 .
I also found these bobbins: http://www.amazon.com/Viking-Metal-Bobbins-5-pkg/dp/B000YZ5QSC . The part number appears to be 1702.
I hope this helps.
(googling Husqvarna Viking metal bobbins found a number of hits.)
Mar 05, 2013 | Husqvarna Viking 1
My fuel pump stopped working. Checked relay and
A fuel pump on a sewing machine? I don't think so.
Mar 08, 2010 | Husqvarna Viking 1
Husqvarna Huskylock 550D manual
I have a Huskylock 550d overlocker and the manual. Where do you live? email me on bmustert@gmail.com
regards Barb
Sep 16, 2009 | Husqvarna Sewing Machines
Local Parts ?
Sounds like a chainsaw issue.........this is a sewing machine forum, suggest a re-post in a different category to get a sensible response quickly.
Sep 09, 2009 | Husqvarna Husky 165
Husqvarna chainsaw repair
Usually empty fuel, use hook to pull out line , remove filter. Remove air filter cover and airfilter ,now you should be able to see line. Most just pull of carby and go through tank, some you may have to take screws out of av mounts in back of tank to see hole to put it back in.cheers hope this helps if where a stihl i could tell exactly.
Oct 29, 2008 | Husqvarna Husky 165
My Husqvarna 142 chain saw, new out of the box, starts and runs well enough but left to idle it continually stalls. Any ideas?
The carb needs to be adjusted. Look for 2 adjustments label High(H) and Low(L). Low is the one that you want. Start you chainsaw and let it warm up and turn the L adjustment a until you are able to let it idle on its own. Hope this helps.
Jul 07, 2008 | Husqvarna Husky 165
Chainsaw (Husqvarna 345e) will not start due to start attempt without adding oil to fuel.
If this was started without oil in fuel, then the piston is likely scored, and the compression rings stuck in a smeared aluminum mess. You can remove the muffler and probably see the damage to the piston. It can probably be repaired though. Take it to a reputible shop, then read the owners manual and get some help to learn how to safely use and maintain your investment that you have in this saw.
Jul 04, 2008 | Husqvarna Husky 165
HUSQVARNA 41 CHAINSAW CANT GET TO START
ok, remove spark plug and touch the threads (CAREFUL) to metal engine casting near plug hole. now try a start and look for a spark at plug.
Oct 04, 2007 | Sewing Machines
Walking foot for my machine
If you still need assist, suggest you visit an authorized Husqvarna Viking dealer for assistance. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Sep 07, 2007 | Husqvarna Freesia 425
Sewing Machines Logo
242 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
