Question about IBM 3500 Typewriter
IBM Correcting selctric II keys are jammed
IBM Correcting selectric II allkeys are jammed,space bar does not work.and will not forward or tab. It will return but slowly. I have removed the ribbon which was tangled.
It sounds like the cycle shaft is not fully in home
position. With the machine OFF, try to turn the print shaft (the steel shaft with the single groove that goes through the carriage) top towards the back of the machine. Then turn the machine on. Try the space bar first. If it works, your machine probably needs the cycle clutch spring adjusted or replaced.
Posted on Feb 28, 2009
How to unlock typewriter?
Remove cover and in the back there is the motor and belt, with machine off, try turning the belt. There is a tool that screws into the main cam shaft that allows you to turn the main cam shaft. most likely something is stuck. These IBM Selectric need oiling on a regular schedule.
Aug 15, 2017 | IBM Office Equipment & Supplies
Space bar on sylectric 2 ibm typewriter is not moving the type
There are a few things that can cause your spacebar to not move the carrier. Do you hear any sound when you press on the bar? There are adjustment that may need to be made to the machine or perhaps there is something sticking in the mechanism. Unfortunately you mey not be able to fix this yourself as these machines need a technician to properly repair and service the machine.
Feb 15, 2015 | IBM Correcting Selectric II
How do I remove and replace the tab set/clear button on an IBM correcting selectric II typewriter
Yes, all the keys are snap on. Use a spring hook on top and bottom of the key and wiggle (carefully) upwards to remove. (If you don't have spring hooks, then hefty paper clips will do. Create a 90 degree or better bend on the end of the clip)
Nov 27, 2014 | IBM Correcting Selectric II
IBM Selectric II jammed
The lubricants dryp over the years. Try spraying everything with WD40 you can't hurt it.
DickyO
Feb 23, 2013 | IBM Correcting Selectric II
IBM correcting selectric - keys sticking and won't advance when keys or space bar struck
By this time almost all selectrics need a good clean and oil the lubricants have turned to gum.
DickyO
Jul 31, 2009 | IBM Office Equipment & Supplies
I have a IBM Correcting Selectric II and I'm having trouble clearing out the margins. Can you help?
space to the right side of the machine, hold down the tab clear key and hit return.
If the carriage stops partway back, one of the tab stops has rotated too far on the tab bar.
remove the platen and paper pan, go to the stuck stop, rotate it to the rear of the machine to line up with the other tabs
Jul 16, 2009 | Nakajima AE-710 Typewriter
IBM Selectric II typewriter stuck in correcting position
If you know how to remove the right dust cover (black inside the T/W below the carrier) next to the R. side frame is the correction set up mech. spray some WD40 on the arms especially where they pivot, they should free up.
DickyO
Jul 02, 2009 | IBM Wheelwriter 30 Typewriter
IBM Correcting Selectric II Works fine except space bar stopped working recently. (Can't make a space--pressing the key has no effect.) Is there anything I can do myself -- or, can you tell if this is...
Probably not much you can do it probabily needs a cycle clutch or at least adjusted. If you know how to remove the case you can try spraying with WD40 it may work but it will be temporary. DickyO
Jun 11, 2009 | IBM 3500 Typewriter
IBM Correcting Selectric II backspace not working
The tab tensioner is probably broken you need a tech.
DickyO
Mar 17, 2009 | IBM Wheelwriter 30 Typewriter
Correcting IBM Selectric II Typewritter correcton ribbon won't engage
Selectric I and II type elements are identical (88 char) where Selectric III uses a different element (96 char). The 88 character element will have white lettering and the 96 character element will have yellow. Directly underneath the lift-up tab to remove the element will be a 3-digit number. That's the last 3 digits of the element's part number, which will be preceeded by 1167 for 88 character, or 1352 or 96 character. For example, if you have a '052" stamped on the element, and it's an 88 character style, the P/N will be 1167052.
The correcting mechanism is an intricate additional function of the backspace function. To test it/adjust it/or repair it requires the machine be hand-cycled using a hand cycle wheel which is screwed into the right hand side operational shaft. It's unlikely that an un-trained party would be successful repairing this..
May 15, 2008 | IBM Wheelwriter 30 Typewriter
IBM 3500 Typewriter Logo
274 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
CheckitRight
CheckitRight
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
