Question about Lakewood Economy Radiant LAK-205 Coil / Ribbon Mid-Size Heater
Thermal switch opens after a few minutes of operation
I need to replace the thermal overload switch
  • 34 Answers
Visit this page for parts and service center info:
http://www.lakewoodeng.com/html/parts.html
Posted on Apr 18, 2009
I have a Spek pool pump which keeps cutting out every 5 to 8 minute and then it comes back on after about two minutes. Very strange.
it it has a thermal over load , not strange at all
check the amps being drawn or replace the thermal overload unit
Jul 23, 2017 | Pool Pump Pool & Spa
My aqua drive 1100 auto reset pool pump runs warm and stops after a few seconds after i switch it on then goes on after a few minutes And this continues. Why
Thermal Overload Switch: Something is creating an overload on the pump. Once it is overworked, the motor will overheat. This will be sensed by the T.O. switch. Once the switch senses that the motor has cooled, it will start again.
Reasons for overload:
  • Bearings no longer spinning freely & without restriction
  • Foreign debris in the volute, jamming against the impeller
  • Failing T.O. switch
Good Luck
Mar 11, 2015 | Aqua Pool & Spa
Will not start...where is the motor thermal overload switch
A motor thermal overload is usually mounted internally in the motor and is not replaceable. You might have a problem with your door switch though, because if the door switch is not making proper contact, the dryer thinks that the door is still open and it will not start. I would start with that and go from there. That will also be a less expensive repair. Hope this helps!
Feb 15, 2015 | Dryers
Maytag med5740tq0 that shuts off after running a few minutes. It runs fine and heats up, but then shuts off after a few minutes. If I hold the start button in it will run until I release it. After...
Hello & Welcome to FixYa
If you have already tried cleaning the vent then the problem is with the Thermal fuse (part#7 in this picture). When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair.It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test the fuse for continuity before replacing, if the fuse is fine then check the thermostat (part#8) and thermal cut off (part#9) in the above picture. Please get back to me if you have any other questions.
Kevin
Apr 27, 2011 | Maytag Dryers
Mixer shuts off when I whip potatoes
It apparently has a thermal overload switch . When it warms up it shuts off.. Only remedy is to buy instant potatos. Just kidding, the thermal switch needs replacing.
Oct 27, 2009 | Food Mixers
Clicking noise every few minutes
the thermal switch is going bad it is a easy fix unplugh the refriderator and buyt this part from this online store http://www.appliancepartspros.com/Appliance-Parts/FRIGIDAIRE-Puresource2-water-filter--wf2cb--item-number-AP2538969.aspx
or you may need the thermal switch on the pump but need model number to find a replacement for it.
Oct 05, 2009 | Magic Chef Refrigerators
ELECTROLUX C101H JUST SHUT OFFWHILE WIFE WAS VACUUMING, DOES THIS HAVE AN INTERNAL THERMAL OVERLOAD SWITCH ? HOW TO OPEN UP CANISTER TO SERVICE ??
it does have an internal thermal overload device you need to put the vacuum into the shop they should be able to fix it in a few days
Aug 01, 2009 | Electrolux Guardian Bagged Canister Vacuum
CLEANER SWITCHES ITSELF OFF AFTER A FEW MINUTES USE. IF LEFT FOR SOME TIME, IT WILL START AGAIN FINE, THEN AFTER A FEW MINUTES MORE USE , IT WILL SWITCH OFF AGAIN.
check all filters, if they can be washed do so, if not clean or replace. next check for a clog in the machine and in the hoses. the machine as a thermal device that if it senses an overload or getting to hot, the machine will shut itself off for safety resons.
Jul 28, 2009 | Vacuums
Oven not working
I had the same problem. At the back of the stove is a plastic cover with thermal overload written on it.
Switch off your power.Remove the cover, pull out the two luggs and connect the two luggs straight to each other. Make sure the oven knobbs are in the off position. turn on the power. If your oven clock etc. comes on the thermal overload is faulty and needs to be replaced. It is fixed to the stove by a screw from the inside of the oven, so open the door and remove screw to remove thermal overload at the back of oven. Take sample to electrical shop and replace. DO NOT USE OVEN WITHOUT THERMAL OVERLOAD.
Dec 27, 2008 | Ovens
Dryer starts then shuts off
it seem like your motor could be faulty (overheating) causing the thermal overload to open, stopping the motor after awhile it will cool down and the thermal will reset, if this the case the bearings or the windings could be faulty
Dec 13, 2008 | Dryers
Lakewood Economy Radiant LAK-205 Coil / Ribbon Mid-Size Heater Logo
276 people viewed this question
Top Lakewood Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
Paul Carew
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
