Question about Esky Honey Bee King 2 RC Helicopter
Copter spins c clockwise.
Moved tail servo both ways and no change. im,m new to flying and not sure what to do
Hi try fliking the switch on the gyro to rev or opposite to what it is now
Posted on Aug 27, 2009
Tail rotor blade is bent and helicopter wont fly forward or backwards
Fixing Your RC Helicopter - The Basics + Tips / Tricks ...
? 3:26
https://www.youtube.com/watch?v=Gxst73zE0VY
Jan 16, 2011 - Uploaded by Live2Fly94
i have a heli and the tail rotor will spin right but not left .... im having problems with my silverlit nano copter the tail ...
Frequently Asked Questions - RC Helicopter Wiki
www.rcheliwiki.com/Frequently_Asked_Questions
Probably the best way to learn to fly is to find a group of like minded people locally and ask their advice. ... The tail rotor should rotate so that the blades come 'up' towards the front of the heli. ... My helicopter won't stop spinning! ... still flying awesome but now tail vibrate and it issues backward forward. what should i do ?
Dec 28, 2015 | Toys
Iwont lift just spin
we have tail motor is burned out change it that's why it keeps going around in circles and it doesn't fly
Dec 06, 2014 | HobbyTron Gyro Nano Spy Copter Remote...
I did check all the propellers and they were ok I would like to contact the seller but I don't have any address to do so I am hopeing it is still under warenty
What is the issue with the quadcopter?
All propellers spin but it flips over when trying to fly?
This would be clockwise and/or counter clockwise propellers on the wrong motor(s). For copters with an even number of propellers, each propeller turns the opposite direction from the ones on either side of it. The reason for this is so the combined engine torque is in equilibrium. Unbalancing this equilibrium is what allows the craft to turn left or right without a rudder or tail rotor.
Regardless of spin direction all propellers must blow air downwards.
Aug 11, 2014 | HUBSAN X4 H107c 2.4g 4ch Rc Quadcopter...
Hi my syma quadcopter x1 is stuck in the eversion how can i fix this ?? Thanks
Jun 22, 2014 | Syma rc x1 aerobatic bee quadcopter 2.4ghz...
I have a new walkera uflys (rx-2435) when i get it up off the ground it spinnes round and round how do i fix this problem
sir jeremydylan2
you have a problem with your rear rotor assembly.
if your rear rotor shaft is broken or the gear is the copter will spin around and around.
or, if these parts are not broken then your trim needs adjustment or, you need to learn to fly and control the rear tail rotor so it does not spin around. Thats your answer. thundermounts@gustywinds.com
Feb 18, 2011 | Walkera Toys
Wen i put the batteries on the control and followd the instructions the light keeps flashing and it wont work to fly my helicopter uj377
I may need more details but is this the way it goes?
1. Turn on the radio, or remote control
2. Turn the power switch in the copter to the on position
At this point, you should see the green light flashing on the control. Simply move the lever that controls your elevation to the full up position and then let it come back down to neutral. The light on your control should now be on with no blinking.
At this point, you are ready to go as advancing that "up" lever again will get that rotor spinning!
The manufacture set it up this way so that you dont accidently "bump" the control before you are actually ready to fly which prevents injury or damage to the copter.
Jan 12, 2011 | Toys
Brand new unit forward and reverse seems very slow moves a little then just hovers.
Make sure you're charging fully, until the light on the charger doesn't get ANY brighter when you unplug the helicopter. Also, battery must be allowed to cool 10 minutes after flying AND another 10 minutes after charging.
Most crucial is that you must never fully discharge battery. Fully draining a Li/Po even once (especially when it's new) can cripple or ruin your battery. As soon as you are unable to maintain altitude, land copter and power it off. Also, there is a button on the remote, labelled "tail motor speed switch" located near the trim control. With it in the "off" or up position the tail motor is much slower allowing for more precise control. When button is pushed to the down or "on" position, tail motor moves faster giving more tilt, and thereby much more forward/reverse 'thrust'. Verify that tail rotor is moving when right joystick is actuated (and that it reverses when right stick is pulled in opposite direction) and that it isn't loose on it's shaft... this can be tested by verifying tail rotor spin in one direction then reversing joystick... tail rotor should instantly start spinning in the other direction with NO hesitation, if it slows and then starts spinning in other direction or anything like that then it's loose. Turn helicopter upside down then VERY CAREFULLY apply a small drop of super glue where the shaft meets the tail rotor, be very cautious to not get any glue near where the shaft comes out of the motor, and do not turn right side up until glue is fully dry.
Hope this helps,
r
Jan 07, 2011 | SYMA Toys industrial Syma S032 Ready to...
Spins counterclockwise...already adjusted trim
This problem can be especially confounding because the way the copter distributes torque on a slick floor can be a spin opposite to what you see in the air!
The solution is to get the machine in the air quickly and make your trim adjustment based on that. The tail rotor is very sensitive as you know so you need to be working that stick constantly to acheive trim, this is part of what flying an RC copter is all about. A four channel copter is much harder to fly but your dragonfly can prepare you for this.
Dec 24, 2010 | Jumbo RC JUMBO HELICOPTER
Does the rc jumbo dragon fly helicopter fly forward or just up and down? Any help would be greatly appreciated. dave
This is a two channel Dave, meaning that the radio is only capable of up or down, or to spin the tail left or right. You will get forward momentum out of it because the design of parts like the removable cockpit housing, or the weight of the battery pack way out front give it "ballast" for forward momentum.
This is very similar to the way the small indoor models work. You will need to get the copter trimmed out to see this happen. Keys to stable flight are to stay at an altitude that you prescribe,
Dec 19, 2010 | Jumbo RC JUMBO HELICOPTER
Spins out of control wont trim out
Have you tried checking the back tail? It comes down right under the rotor. If it is ripped, DONT TAPE IT! Taping will just ruin the weight balance and ruin it. If it is ripped, return it and exchange it, dont try and fix it.
Jun 01, 2009 | Air Hogs Havoc Heli Helicopters
Esky Honey Bee King 2 RC Helicopter Logo
258 people viewed this question
Top Esky Toys Experts
ray gallant
Are you an Esky Toy Expert? Answer questions, earn points and help others
