Home | Bialetti | Moka Express 6-Cup Coffee Maker | Water comes up clear.
Bialetti Moka Express 6-Cup Coffee Maker
Problem for Bialetti Moka Express 6-Cup Coffee Maker
By goldiechow on Feb 18, 2009
When I first got my Bialetti Mukka, it would leak from the sides.  Online, I found the fix of soaking the O-ring in hot water before using.  I was using Peets ground coffee and it worked fine for months.
Now, I switched coffees (one fine grind Nero, one medium ground Fresh n Easy), and water comes out clear.  However, if I turn it off for a while when water first steams through, then turn it back on, it comes out with coffee.  Anyone have this problem or know a fix?  I've tried tampering with temperature, high, low, still same problem.
Thanks!
Popular Solutions for Bialetti Moka Express 6-Cup
Questions and Unsolved Problems for Bialetti Moka Express 6-Cup
Do you recommend Bialetti Moka Express 6-Cup Coffee Maker?
Answer
Answer
How long does it take for the water to reach the top of the tank? Also, the sales clerk sold me... (More)
Answer
My bialetti coffee maker ends up boiling the coffee if left on the stove. Is it meant to do this?... (More)
Answer
The pressure valve on my Bialetti 6-cup Moka espresso coffee maker blew out after 1 month. I have... (More)
Answer
When I add water to the bottom (top of the filter) I can not get water to drop down into the chamber... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bialetti Moka Express 6-Cup...:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 881
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
