Question about Western Digital 500GB My Book Pro-External 500 GB Hard Drive
My external hard drive won't turn on
Light doesn't come on and computer doesn't see it. Tried multiple outlets and still didn't work.
  • 7 more comments
  • Anonymous Mar 19, 2009
    I can't get the computer to recognize the hard drive (western Digital)
  • Anonymous Mar 21, 2009
    me too
  • Anonymous Mar 23, 2009
    mine used to work and when it did, i would feel a light vibrate and and a little sound. Now there isn't a sound at all and it doesn't vibrate. Plus, my computer cant see it either
  • Anonymous Apr 20, 2009
    can't get the computer to recognize the hard drive (western Digital) exacly the same :(
  • Anonymous Apr 23, 2009
    my hard drive will not turn on. I press the button and nothing happens.
    No fan, no light no nothing, I verifyed the outlet is working and plugged the harddrive from the power strip directly into the wall outlet...nothing!
  • Anonymous May 01, 2009
    My WD external HD worked one week ago and has been sitting in my backpack in my house.  Plugged it in today and... nothing.  No light, no buzz, no vibe.  Squat.
  • Anonymous May 02, 2009
    Western Digital exernal hard drive will not turn on.
  • siklyrik23 May 14, 2009
    My External Harddrive won't turn on. Dude, I had it for a week, put all my music and videos on their and then it just stopped working. Tried it on 4 different computers and nothing.
  • Anonymous May 18, 2009
    i have the same problem ... external doesnt turn on WTF!!! man....
Ok, this just happened to me, my western digital my book studio external drive was not booting up, i could hear the disk spinning, but it would then cut out and the light on the drive was never turning on. i called Western Digital customer support and found out that the proper way to connect a drive is to plug in the power cable FIRST then the data cable. Also, with the My Book Studio Edition you should never have to press the power button, the drive just turns on when you plug it in. Hope this helps somebody...
Posted on Mar 10, 2010
My seagate freeagent external 500 wont turn on. It was working fine days ago and it turned it off and today i tried using it and it wont even turn on. i tried diffrent plugs and outlets and nothing. WTF!!! No light, No buzz nothing! anybody know how to fix this???
Posted on Apr 16, 2010
When this happens to me, I can usually fix it by holding down the power button until the light flickers and then it works fine.
Posted on Feb 16, 2010
Did you find a solution for this
Posted on Oct 26, 2009
5 Suggested Answers
anaesarora
  • 180 Answers
SOURCE: My external hard Drive DIGITAL Research just flashing
most of the time its the pcb which is responsible for not detection of hd in any system
also one should take into account
1 cables should be good
2 powersupply should be good
3 controller card should not be faulty.
4 any primary master slave conflict should be solved.
the suggestions in 1 2 3 4 are essential before testing a hard drive.
later a bootable cd or floppy drive helps to make us do a scandisk
or a fdisk .
if fdisk reports no hdd or fixed disks then one should be vigilant that the drive may have been lost mbr or boot recotds
Posted on Jul 30, 2008
bronk50
  • 27725 Answers
SOURCE: MY COMPUTER WON'T RECOGNIZE MY EXTERNAL HARD
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if your computer came with a motherboard disk the drivers could be on it
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
Posted on Jul 03, 2011
jaibo86
  • 82 Answers
SOURCE: Computer will not recognize one 500 external hard
What OS are u working on? some old ones dont recognize this big hard drives, cant remmember the limit but it was around 300. Try updating ur OS if u are working on windows xp(get it to Service pack 3). I think this problem was fixed at sp2, but just to be sure.
Posted on Nov 02, 2009
  • 81 Answers
SOURCE: I'm having a problem with my SmartDisk external
Some units have two cords one power one data , in the event
that a unit is not recognized its always the data cord , data cord
hooks itself to a computer via its data cord , so two items are
needed a good working 2.0 high speed USB and a good working USB cable , hook your unit up to your computer , reboot your
computer then try looking in my computer for the drive , if the
HDD is in working order its only way to your computer is the cord
or its USB connector , sometimes USB connectors break for no
apparent reason try checking your USB connections with other
items such as flash drives but not items such as lights fans or
headphones
Posted on Jan 28, 2010
Maxtor basics 500GB external hard drive not working
Every time you turn your computer on it is going to "spin up" and the light is going to come on. Just because the light goes out and it idles so that you can't hear it anymore doesn't mean it isn't still on. It is. You can verify this by using windows explorer to view it and its files.
Jun 29, 2012 | Maxtor BASICS Personal Storage 3200...
External hard drive won't show files
If it behaves like this for multiple computers with multiple operating systems, I would think that the problem is with the hard drive or with how the files were stored. I would recommend trying a free recovery utility:
http://www.piriform.com/recuva
If this does not work, there are professionals who can do this service for you however it is generally expensive.
As a last ditch effort, boot your computer from a free Ubuntu CD (http://www.ubuntu.com/download/ubuntu/download) and see if it recognizes your files.
Dec 13, 2011 | Buffalo Technology Buffalo DriveStation...
My toshiba external harddrive usb 3.0 won't work
if this fails to fix the problem
hope this helps you
Sep 18, 2011 | Toshiba Notebooks Canvio E05a075cau3xw 750...
Lacie by stark external hard drive is suddenly not recognised by my computer (always worked until now) and has a permanent red light. Tried all usb ports and restarting computer. Whats wrong?
have you dropped it? it could be any number of disc errors, two of the most common errors are caused by viruses and dropping. try putting the hard drive in the freezer for a day or so in a moisture and static resistant bag. just a possibly remedy, if that doesn't work, try removing the casing on the hd and setting it as a secondary drive after you plug it inside a desktop computer.
May 09, 2011 | LaCie 500GB Starck Mobile USB 3.0 External...
Hard drive lights solid,monitor goes dark/w amber power light. multiple hard drives have been tested with the same results.
NEVER BUY IBM!!!! THERE HARD DRIVES AND EXTERNAL HARD DRIVES NEVER WORK!!! SAME WITH HITACHI!!! if u wanna good external hard drives check out these links: store.westerndigital.com and http://www.seagate.com/www/en-us/products/external/ hope helps :)))
Dec 22, 2009 | IBM eserver xSeries 205 8480
My harddrive just stopped working one day...I didnt drop it or anything. Once it is plugged in the blue light comes on and it whirrs for a few seconds but then nothing...it goes quiet and nothing comes up...
this happens when the card of the hard disk becomes faulty check for the warranty status of your hard drive generally hard disk have 2 to 5 years of warranty it will be changed
Oct 08, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
External Hard Drive doesn't work
There is a (laptop-size) hard-drive inside the case, and that hard-drive is failing. As it spins, it generates those noises, like a dying dinosaur. If it still is under warranty, exercise the warranty, and replace it. If the warranty has expired, tough luck.
May 21, 2009 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
My computer stopped reading my external hard drive
Try the drive in a different USB port. If it still fails try another computer. If it still fails then it's possible the drive is bad. If the warranty has expired you may be able to find a tech savvy friend to remove the actual drive from the case and hook it up to another computer directly. If it recognizes fine then the case is bad. If it does not recognize the drive then the drive is dead.
You won't be able to retrieve the files on the drive unfortunately unless you use an extremely expensive service. These tend to run in the hundreds of dollars.
Nov 22, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
150 GB Seagate Free Agent external problem.
Yes, this could have blown an internal thermal fuse.
Jul 08, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
External Hard Drive No Longer Recognized
hey im the same person who just posted above. i went to WD's website, and it said unplug the hard drive from the computer, and unplug it from the power source. then plug it into the power outlet, wait for it to spin up, then plug it in via USB/Firewire, whatever. it worked for me, so hopefully it will work for you.
May 11, 2008 | Western Digital My Book Home Edition 500...
Open Questions:
See all Western Digital 500GB My Book Pro-External 500 GB Questions
Western Digital 500GB My Book Pro-External 500 GB Hard Drive Logo
16,121 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
