Question about HP Pavilion DV6405US Laptop
Ask the person who had it before if you are still in touch with them and ask if they know.
Posted on Feb 18, 2009
Aug 17, 2013 | Lenovo ThinkPad Computers & Internet
Jan 10, 2013 | Microsoft Windows XP Professional With...
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cables
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a non-bootable source.
This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
make sure there are no disks in cd floppy usb drives
How to Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your
Windows installation disc, or can't access the recovery options provided by your computer manufacturer."
or
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
a) Insert the Windows 7 System Repair DVD or Installation DVD and reboot.
b) Select the correct keyboard input method and click 'Next'.
Note: If you are using the Windows7 Install DVD then at the 'Install Now' prompt (Do not pick the Install
Now option) instead choose the 'Repair your computer' option located in the lower left of the dispay.
c) The System Repair tool will search for a valid operating system and will report that "Windows found problems with your computer's startup options. Do you want to apply repairs and restart your computer?"
d) Click 'Repair and restart' and reboot again to the Windows 7 System Repair environment.
e) Click 'Next' at the keyboard selection prompt and when the 'System Recovery Options' screen appears verify that the "Use recovery tools that can help fix problems starting Windows" is selected.
Note that on your Dual Boot system there now should be only one operating system listed. Click the 'Next' button.
f) Now from the menu list select the 'Command Prompt' option.
g) At the DOS prompt type the following three commands:
bootrec.exe /fixmbr
bootrec.exe /fixboot (may return an 'Eliment not found' message)
bootrec.exe /RebuildBcd
h) Close the command prompt window and click the 'Startup Repair' option.
i) The repair process may take some time, so wait until the process completes at which point you will see two messages "Windows cannot repair this computer automatically" and "Startup Repair cannot repair this computer automatically".
These messages are the result of the radical changes made by removing the other drive. Ignore the Send/Don't send options.
J) Close this message window by clicking on the X in the upper right corner of the Send/Don't send window. Next click on the 'View advanced options for system recovery and support' option and from the main menu once again click 'Startup Repair'.
This time the repair process may only that a few seconds and when prompted "Startup Repair could not detect a problem", click 'Finish' and run the 'Startup Repair' option one more time, click 'Finish', and then remove the System Repair DVD and click 'Restart'. Reboot the computer.
hope this helps
Oct 09, 2012 | Dell Studio 1737 Laptop
Sep 08, 2011 | Computers & Internet
Hi
You don't say which Operating System you use, so my answer will be presented in general, Windows terms. If yours is a non-Windows Operating System and my answer seems to be of some relevance to you, please consider applying the logic and principles involved here to your own Operating System and, if in doubt, please feel free to add a Comment or Clarification to this Question. Please include information about its Operating System. Doing so helps us makes faster, more accurate and more assured Remote Diagnostics leading to better quality and more useful Advice, Answers, Guidelines , How-Tos and Solutions.
You also don't say what happened and what fault caused you to need to try to run the recovery program.
It seems the recovery CD has altered the Boot Sector of the Hard Drive.
If the data on the hard drive is important:
Unplug and turn off the laptop > remove the battery > use a small screwdriver to open the Hard Drive compartment with the picture of a small stack of CDs next to it > remove the retaining screw or clip > remove the Hard Drive > use a Hard Drive Dock or an External 2.5" Hard Drive Enclosure (for this you have to remove the small silver Hard cradle that holds the Hard drive fast in the laptop) or an IDE/SATA to USB Connection Cable to connect the Hard Drive to a 2nd Computer > Back up all important data to an external storage device.
Reinstall the hard drive into the laptop > insert the installation disk > install a Windows XP Disc > Boot from the CD > When you reach the 2nd repair screen, press R to Repair XP.
If you have a different Operating System follow the same process > select Start Up Repair (for Vista or Windows 7)
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it.
This helps Answerers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can.
If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa
Sep 06, 2011 | IBM ThinkPad R31 2656 Notebook
Jan 12, 2010 | Compaq Presario 5000 PC Desktop
Dec 05, 2009 | Acer Aspire 3680 Laptop
Apr 20, 2009 | Computers & Internet
Jul 31, 2008 | Toshiba Satellite A70 Notebook
Jul 03, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Sep 09, 2010 | HP Pavilion DV6405US Laptop
71 people viewed this question
