Question about Frigidaire ATF6000ES Front Load Washer
My Frigidaire front loader (about 14 months old) won't drain. It hums (or buzzes) loudly and does nothing.
  • thomsone11 Feb 18, 2009
    At first, I could get it to rinse, but then it just stopped completely. The drum doesn't turn. It won't drain. I tried taking the wash out of it (in case I had overloaded it), but it still doesn't work. There is about 2 inches of water in the drum. How do I access the drain pump?
  • clrcrossland Feb 20, 2009
    I have the same problem!!!! The washing machine is two weeks old and all it does is hum............NOTHING!!
    Genius:
  • 1,075 Answers
You really need to tell me a little more;is the drum turning does the machine wash other than this hum is everything else ok?I would say there might be a sock or simler stuck in your drain pump as i dont have enough information i cant really tell you anymore.adrian
Posted on Feb 18, 2009
Our refrigerator does a very loud buzzing for 5 seconds 3 or 4 times a day what is the problem its only 3 months old and very annoying
Normally as loud buzzing from the fridge on that frequency it just the icemaker cycling, the water inlet solenoid valve often makes a buzzing noise depending upon water pressure. Other than the noise, there is nothing to worry about.
Sep 26, 2016 | Frigidaire Refrigerators
My Frigidaire gallery front loader series model GLTF2940FSO stopped working during quick load - water still in machine, started making buzzing/humming sound but wouldn't drain or finish cyle. Unplugg
Sounds like a bad start capacitor in your drive motor. Not expensive to fix, but you have to know what you're doing. If you're not handy at that sort of thing, I'd suggest a handyman who fixes washers.
Dec 31, 2014 | Frigidaire Washing Machines
I have a whirlpool duet 2 1/2 years old I t has started to make a loud buzzing hum sound (that sounds like old top loader mixing valve malfunction?) and has error code 5d what is this ?
Actually, your error code is "Sd" and indicates that the washer thinks that there are too many suds in the basket / drum.
Your buzzing sound is also likely to be the water inlet valves, common to top loaders as well, as the washer is adding additional water to rinse excessive suds out. Check your supply hoses for kinks, connections for scale buildup inside, as well as the screens on the inlet ports of the washer itself.
A kinked or restricted drain hose can also throw an Sd error code as well.
Jun 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Front loader problems
call repair before warranty runs out...possible door switch if it's a loud humming noise ..try pressing in on door latch side to see it hum changes
Sep 06, 2008 | Frigidaire GLTF2940ES Front Load Washer
Constant humming/buzzing noise
I purchased a poloroid tv 3732 in may of 2005 from circuit city, after about 14 months the set began making a clacking sound and humming sound that gets so loud it is unbareable. I have to turn the set off. I have found out I am not the only one with this problem that has a poloroid tv. I had a technician at my home that told me there is a service warranty on these sets because the wrong part was used and the part needs to be replaced.
Oct 29, 2007 | Polaroid FLM-3732 Television
Frigidaire ATF6000ES Front Load Washer Logo
179 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
