Question about Whirlpool RBS305PD Electric Single Oven
Electrical schematic for Whirlpool oven model WBP58500
The element blew in our oven which also has the convection element. I am looking for the electrical schematic for the plug in.
There are four connectors. two yellow, one white and one bronze colour. What is the proper orientation.
Once they are plugged in is there anything else to do or should the oven work. The model is WBP58500
Thanks
  • 4102 Answers
SOURCE: whirlpool electric oven
does your unit have a button to open door or do you just pull it to open it they are sometimes really stiff at first if it is button then it will need lock replacing about 60 pound if it just pulls open then these can seem stuck but will open as there is no mechanism to open the door so it will open but might take a bit of force the first few times untill it wares in a bit so dont be afraid of using force as it will open post back if you have any trouble and i will find a manuall and see what it says in their ok hope this is some help.........................................
Posted on Nov 17, 2007
SOURCE: Whirlpool GBD307PDS Electric Double Oven
I fixed my problem by disconnecting the control board, cleaning all the contact points (including the ribbon cable) with alcohol and reconnecting everything as tight as possible.
I did notice that one of the contacts had become very corroded, so I scrubbed this one for a while. Prior to this I had done some selective unplugging and replugging (ribbon cable in particular) to no avail (each of these attempts powered on to beeping and no display).
Not a fancy solution, but it did work!
Posted on Jan 20, 2008
protek480
  • 1723 Answers
SOURCE: Cold Whirlpool AKZ451!!
You may have had a surge during the storm. Check main control board in console for damage.
Posted on Sep 01, 2009
SOURCE: how to remove the control panel on Whirlpool double oven Model RBD305PDS14
Emge & Associates is investigating gas and electric ovens manufactured by Whirlpool, including such popular brands as Whirlpool, Jenn-Air, KitchenAid and Maytag.
The firm is investigating reports that the electronic control panel on certain models is subject to failure after a limited number of uses of the appliance’s “self-cleaning” setting. While most foods are cooked at temperatures reaching 375 degrees, the “self-cleaning” setting raises the interior oven temperature to 1,400 degrees. Due to defects in the design and or manufacturing, the electronics contained on many ranges are damaged by extremely high heat. Repairs to damaged control panels typically cost in excess of $300 per replacement.
If you have experienced failure of the control panel in your range after using the “self-cleaning” setting, you can join this investigation by contacting Emge & Associates at (800) 629-3409 or (619) 618-2974.
Posted on Dec 19, 2009
barkencoa
  • 3463 Answers
SOURCE: Whirlpool AKZ 446 Electric fan starts but oven
Yes , the element is easy to replace
Remove the cover at the rear of the oven, there you will see the element, undo the screws securing it, and replace the element.
This should solve your prob.
Good luck..
Posted on Dec 29, 2009
Bosch HBL 645 Convection Oven -- No Heat
first out put voltages measures,when output voltages ok , then see the control circuit.after tnat every thing ok. replace heating elements.
Dec 10, 2007 | Bosch HBN 442 / HBN446 Electric Single...
Wbp58500
Can be awkward but open the door fully, on the hinges there should be a small sliding clip, slide forward to lock hinges and lift door from close to oven.
Oct 01, 2014 | Whirlpool 30" Self-Cleaning Freestanding...
I have a GE Monogram Built-in Convection Wall Oven (model no. ZEK737WP3WG) and the heating elements have stopped working. The electrical power is working, and the control panel, light, convection fan...
It is possible that a relay on the control board is bad. GE has a relay in the common circuit to the bake and broil element. this has been a problem in a few ovens I have repaired. Check for this it is usually an orange relay on the board.
Apr 27, 2014 | GE Ovens
Whirlpool Gold Electric convection oven does not heat up.
Check for a broken wire or even broken element on top and bottom of unit. To do this, the unit must be unplugged or otherwise removed from power completely, then remove the screws that hold each heating element in place and gently pull out and inspect the wire connections. You should have just enough slack to check them. There should also be just enough slack to strip the wire clean to make the new connection to the heating element.
If the repair has been done before, you may need to fish a new lingth of high temp wire into the location.
Jul 13, 2012 | Whirlpool Ovens
Hobart electric convection oven model #cn90 ser. # 07-007-968-nj
Have you tried shutting down all power to your oven at the electrical panel, waiting 10 minutes and then returning power to the unit? Procedure could reset the defaults. Best of luck.
Apr 09, 2010 | Hobart HEC501-240V Electric Oven
Elements in convection oven won't heat
DO you have a model number for that. I'm almost sure it's a thermal fuse in the back of the oven. Usually they go out during or after cleaning but that would shut down both elements. If you have the model (usually by the inside door look all over and up in the cavity) Then if you go to this link
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
It will show you a breakdown of the oven and where it is. If you give me the model I'll show you what I'm talking about. Good luck.
P.S. if it the fuse it's a cheap fix, little hard to get in back of the oven but cheap!
Mar 04, 2009 | GE Ovens
Finding parts for La Germania- Explorer Oven
The distributor for LaGermania in North America has gone out of business. However, parts can be ordered directly from the manufacturer in Italy. A contact that worked is: Daniel Pedrazzini
Customer Support
BERTAZZONI S.P.A.
phone +39 0522 226415
fax +39 0522 226440
e-mail: dpedrazzini@bertazzoni-italia.com.Note that shipping will be expensive, but it is still much less than buying a new stove.Also, I have found a model sold in Australia that is very similar in features to the models that were sold here, with the exception that they don't have a separate burner lighting button. Here's a link:http://sampfordixl.com.au/lagermania/upload/LUEP01-90-S._W1883_%28A.pdf
UPDATE: (January 5th, 2018)
Unfortunately, the Australian distributor no longer carries the La Germania line, and has removed all La Germania related information from their website. I uploaded the manual I had gotten from the above dead link and also the parts breakdown drawings and parts list that were sent to me from the parent company in Italy, Bertazzoni. This parts list can be used to order parts from Reliable Parts, which is a U.S. distributor of Bertazzoni parts, and they can order the La Germania parts using the parts numbers from this list by contacting their Bertazzoni reps and getting the Bertazzoni part numbers where they differ.
Here's a link to the directory that contains this information on a Google Drive. Using this link you should be able to browse, view and download the documents:
https://drive.google.com/drive/folders/1dYHsPsU-_WZ71kR4nLobiv7thY-lJV2t?usp=sharing
A few notes that may help people when repairing these 1990's La Germania branded stoves:
1. These La Germania branded stoves are well built and worth repairing. They are the same quality and similar build as the stoves currently being sold in the U.S. under the parent company's name, Bertazzoni. After replacing two burned out oven heating elements (see below) in mine in 2008, it has been operating flawlessly for over 10 years -- pretty good for a 1990's dual-fuel stove.
2. Some of the electrical elements can be replaced with domestic parts. For example, I took the burned out circular convection oven element to a local used appliance store (used appliance stores often have appliance repair departments) and was able to match it up exactly to a used convection element they salvaged from a domestic stove. Unfortunately, because this was a salvaged part, I was not able to determine the make and model of the "donor" domestic appliance, otherwise I would have posted it here. However, their technician assured me that it was a commonly available part. You just need to match up the dimension of the round element (both diameter, and depth) and make sure the wattage rating is about the same -- in my case the one I found was exactly the same, including the support brackets. Since in the U.S. oven elements are 220-240V rated, they will work in the La Germania (and Bertazonni) ranges. While I was at this used appliance store repair department I also looked for a replacement for the burned out lower oven element. Unfortunately I could not find an exact match for the lower oven heating element as I had for the convection element. However I did find a used domestic lower heating element that was approximately the same dimensions and wattage, and the end with the connectors very closely matched the original element, and so could be mounted and connected up exactly as the original element had been. I had to extend the two front support legs on it by about 1/2 inch, but that was easy to do with some scrap aluminum flat stock and a small bolt, a washer, a lock washer, and a nut to hold the extension in place.
I attached this extension to the bottom of the two V-shaped wire "feet" that were already welded to the front of the used element I had found. These two wire "feet" were welded at the top of the "V", so, being attached to the bottom of the "V" the extension wouldn't get the full heat from the element. This reduction in direct heat allowed me to use easier to cut and drill flat aluminum stock instead of using much harder to cut and drill flat stainless steel scrap stock. (I would not have trusted aluminum to withstand the heat of direct contact with the heating element.)
Because I was able to find workable domestic used parts, the total cost of repairing both elements was less than $20. It would have been far more costly just to have had factory replacement parts shipped from Italy.... I also was able to do the repair immediately instead of having to wait for the parts to arrive.
WARNING!!!! If using non-factory elements it is EXTREMELY important that you pay attention to closely matching the wattage of the existing elements. Putting in lower wattage elements will result in slower warm up times for the oven, and putting in higher wattage elements could be an EXTREMELY DANGEROUS FIRE HAZARD because the element would burn hotter than the stove was designed for and could potentially cause a fire due to this, OR it could cause a fire due to overloading and heating up or burning the supply wiring inside the stove because it wasn't rated to supply that high a wattage/current. WARNING!!!!
I realize that this kind of mix-and-match parts finding is not something that a person without some good DIY skills and experience would be able to do. However, competent professional repair people can and do use quality generic replacement parts all the time for out-of-warranty repairs -- they just make sure that the manufacturer is known for their quality and the wattage is an exact or very close match, and thus maintain the engineering and safety integrity of the stove.
3. Regarding getting factory replacement parts for these La Germania branded stoves:
While the parts can be ordered directly from Italy, I was quoted more than $100 just for shipping to get the parts I wanted shipped direct from Bertazzoni in Italy. Because La Germania and its parent company Bertazzoni produced very similar products, a great many of the parts were shared. Because of this, a Bertazzoni U.S. parts distributor like Reliable Parts will be able to supply many of the wearing parts (elements, burner caps, hinges, door seals, etc.) from their existing Bertazzoni stock. They would just need to contact their Bertazzoni representative and ask for the cross-matching part numbers between the two related companies when the part numbers differ. The U.S. parts distributors order a lot of parts at a time, possibly by the container load, which drastically reduces the cost of shipping for each individual part. So, if you aren't the experienced DIY type person that can work with matching and using domestic replacement parts, or just want to stay with the original factory parts -- attempting to get replacement parts through a U.S. Bertazzoni parts distributor could save you a lot of money (and time). I know this to be true because I researched getting the parts through Reliable Parts prior to discovering I could find and use domestic replacements.
4. The oven light bulbs for these stoves are hard to find, and expensive in the U.S. because of their shape and voltage. I was quoted between 8 to 10 dollars per bulb (not including shipping). However, if you do a search on a site like Ebay, you can find these bulbs for a lot less, even when considering the shipping cost. If you can wait for 2-3 weeks you can get a pair of these bulbs for about $2.50 from China or Hong Kong, including shipping. If you want to order from the UK to get quicker shipping, you can find them for about $8 for 2 including shipping. Just do a search for "25W 220V oven E14" or "25W 220V 300C E14" and you'll find them. Make sure they are high temperature rated (300 degrees Centigrade.) You can find them on Amazon as well, but I only saw Chinese suppliers listed (a 3-4 week shipping time usually indicates a Chinese seller).
Nov 22, 2008 | Ovens
Neff model U1461
your convection element has blown by one online and replace it yourself
May 25, 2008 | Neff U1461 Double circotherm plus Electric...
Gaggenau oven won't heat on convection setting
this could be due to more than one cause selector switch faulty elements faulty. however this would mean both elements gone - there is one at the top and one at the bottom also worth while looking at the wiring to the convection elements. does the thermostat neon come on when convection is selected?
May 18, 2007 | Gaggenau EB294/295 Electric Double Oven
Whirlpool RBS305PD Electric Single Oven Logo
452 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
