Question about KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher
Loud buzzing noise coming from motor when running.
  • 70 Answers
You either have something stuck in the impeller area or the motor bearing is failing.Honestly, this type of pump/sump assbly is NOT a part that can be serviced. you have to swap them out for a new sump/motor unit. Approx cost part # 8572617 = 186.00US plus labor and a service call.
If the unit is working fine,just a bit nooisey,I would let it be until it quits.
Good Luck!
Posted on Feb 19, 2009
2 Suggested Answers
  • 189 Answers
SOURCE: whirlpool GU1500X dishwasher motor noise got loud
Hello- Yep- it's toast. A small seal on motor shaft failed, causing water to destroy bearings. Motor is about 100$. Installation instructions available if you choose that route. Let me know if this info helps- have more if needed.- Thanks - Ed
Posted on Mar 12, 2010
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
When I turn the machine on it makes a buzzing noise, (not loud but it might be like an alarm).
If the mixer is still running and making the buzzing noise one of the electrical contactors is making the noise and should be replaced.
If the mixer is not running and just making a buzzing noise it can be because off single phasing, check the incoming supply to the mixer and make shore you get the right voltage to the motor (test on motor connection terminals)if the voltage to the motor is right the motor might be faulty
Jul 29, 2015 | Hobart 60 Qt. Mixer
Motor making loud buzzing noise
The grinding noise could be asking for lube. If that is possible, do it.
Dec 13, 2013 | Precor C956i Treadmills with HR /...
Loud buzzing noise
Mine is loud also when playing games. When playing DVD's it is not. I think it is a factory defect on some of the systems. I would not attempt to pull apart the DVD drive and try and fix it. It is working and on an XBOX 360 you should feel lucky that it is.
Aug 18, 2009 | Microsoft Xbox 360 Console
Motor noise coming out of speakers
you may have a short in one of your speaker wires, or your antania
Aug 07, 2009 | 1993 Buick Century
Loud buzzing noise
seems the the motor is ****! avoid switching it more further to prevent its motor from burning!
motor could be stuck due to rust build-up.
or something might have jammed along the motor area or along the rotating part.
Jun 18, 2009 | Dryers
Loud buzz when starting, then shutting down after 10 min.
Yes, this sounds like the motor cutting out on thermal lockout.
Apr 10, 2009 | Kenmore 62602 Electric Dryer
Dryer makes a loud buzzing noise then quits working.
Sounds like the motor's done. That thing is probably the start-run switch. Not worth trying to fix on an old motor. I've found dryer motors to be fairly generic, you should be able to find a replacement. I use Repairclinic.com when I can't get parts locally.
Nov 26, 2008 | Magic Chef CYE4000AWW Electric Dryer
Loud buzzing noise
sounds like the color wheel needs to be replaced very easy repair on that model Samsung.
Jul 05, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Loud Buzzing noise
Sounds like the fan is hitting some ice build-up. If you can access the area of the fan motor you can try a hair dryer to defrost the ice out of it.
Apr 15, 2008 | Frigidaire FRS23R4A Side by Side...
KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher Logo
230 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
