Question about Sewing Machines
My metrowealth 820 ATFN 820 ATF Super Zig Zag electric sewing machine does not work anymore but the lights still works... what's wrong with it? How can I fix this?
RickE1
  • 202 Answers
SOURCE: Zig Zag Not working on my Bernina 830.
Basically it is a matter of a stuck part. Flip open the top by prying up on the front or ends of the lid. You already noticed the hinges on the back. When you get it open, exercise the right hand lever on top (marked ZZ at bottom and 1-20 at top. If you look just to the right of this lever against the back wall you will see that it moves a little part back and forth into triangle shaped grooves. The part is not going completely into the grooves so drop some oil in there and exercise it a few more times, using your fingers if necessary to make the part move into the triangle grooves at the front and back. After a while it will loosen up where it should operate by itself smoothly . Hope this helps.
Posted on Dec 12, 2008
  • 323 Answers
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
Posted on Feb 16, 2009
SOURCE: Kenmore 1560 Sewing Machine
Be sure TOP control shows zig-zag. Flip top right bar from red to black or black to red on side of machine facing you. You can then change the widths by changing the numbers on that same circle control.
Posted on Jul 17, 2008
  • 18 Answers
SOURCE: Singer 457 Zig Zag Sewing Machine not catching bobbin thread.
There are manuals avilable online to purchase for the singer machines, SOrry I was not able to locate a site that has them for free.
.... http://sewingonline.co.uk/singer-manuals.html
Posted on Aug 16, 2009
SOURCE: bobbin singer stylist zig zag model 477
Check this web page
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_477_threading_diagram.htm
Posted on Jan 23, 2010
Please how do I work a zig zag pattern on my manual operated singer sewing machine
Hello, Annelien -
Unless your manually operated sewing machine has switches to realign your sewing machine needle to make zig zag stitching, as is demonstrated in this YouTube video (starting at around 6:30 minutes in the video):
https://www.fearlessmakers.com/manual-sewing-machine-works/
you cannot. Note: The machine in the video is a Necchi brand sewing machine.
Without knowing the model number of your manually operated Singer sewing machine, I cannot try to find operating instructions for it to determine if your machine has zig zag stitching potential.
Best wishes.
Jan 24, 2018 | Singer Sewing Machines
I have the settings correct but it still doesn't zig zag correctly??? what could be wrong???
try a new needle
could also be something wrong with the cam that does the zig zag stitch
would be a good idea to have the machine checked to see if there is something wrong with the cam
Mar 09, 2016 | Husqvarna Viking Emerald 116 Sewing...
How can i find a manual for a universal sewing machine kzm 022951
Universal Sewing Machine Product Support ...
www.manualsonline.com/support/universal/sewing-machine/
Just aquired a universal sewing machine model Kzm. Universal Sewing ... Needmanual for Universal AZZ Super Zig Zag sewing machine. Universal Sewing ...
Universal Zig-Zag Deluxe sewing machine w/ manual ...
? 4:06
www.youtube.com/watch?v=ZWmBB6za9-s
Oct 28, 2013 - Uploaded by hindsight80
Universal Zig-Zag Deluxe sewing machine w/ manual. I just cleaned and oiled it it is ready to go. Awesome ..
Nov 05, 2015 | Sewing Machines
Zig zag quits working and goes to straight stitch
there could be something wrong with the gear or cam that the machine uses for zig zag, it would be a good idea to have the machine checked
Jun 09, 2015 | Sewing Machines
Have a Bernnina record 530. The zigzag will not work, just straight stitch on any width setting. all the other fancy stitches(1-12) work fine.
the cam or gear of the zig zag could be worn or damaged,, having the machine checked,, would tell you for sure what wrong with the zig zag..
Sep 28, 2013 | Bernina Sewing Machines
Width
it sounds like both of the machine need to be check to see what
is wrong with the zig zag stitch controls or if it's the cam inside the
machine. a sewing technican can tell for sure
Jun 08, 2012 | Janome Sewing Machines
Trouble sewing lycra fabric using a zig zag stitch
You have the machine set for blind hem stitching. Change the stitch selector to stretch stitch, which is a single, in line stitching zig zag stitch.
Cheers,
Embroidery Services
San Diego, CA
Sep 13, 2017 | Sewing Machines
Zig Zag Stitch not working
THis problem occurred as I was sewing on Neoprene. I was using Gutterman all-purpose thread and a size 80 needle. Tried switching to a size 70, then to size 90. Still unable to zig zag. After inserting a test sample of cotton, the zig zag worked perfectly, so I knew it was not a mecahnical problem. I switched needles again. This time to size 90 for stretch fabric. Voila! Problem solved.
May 23, 2009 | Bernina Virtuosa 150
Feb 26, 2008 | Kenmore 15516 Mechanical Sewing Machine
Sewing Machines Logo
698 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
