Question about Samsung SpinPoint T HD501LJ 500 GB SATA Hard Drive
Sata hdd not detected in bios
I have recently bought gigabyte GA EP43-S3l motherboard, intel core 2 duo E8400 CPU and 2 x 2GB DDR2 SDRAM. I put it all together with my 600W PSU, NVIDIA GeForce 9600 GT graphics, Philips DVD burner, Hitachi 80GB IDE HDD and Samsung Spinpoing 500GB 16MB cache SATA II HDD as primary drive with Windows XP on it. Everything was working ok for over a week (no problems at all) until I changed my PC case (the old one had faulty power button and looked very old so I changed it. I haven't changed anything in bios or Windows at all. I plugged all the cables as it was before and the bios can't detect my Samsung SATA drive. Only says "Detecting IDE devices..." and that's it. When I unplug it, bios finds my Hitachi IDE drive and prompts no system found, etc. (because there's no system on the Hitachi drive-fair enough). When I just plug the SATA drive on its own, bios still can't detect it. I have tried other sata and power cables for that drive but still no live. I can't even feel it spinning. Is it dead? I had it only for about 10 months, veber removed it before, installed it on my own, everything was smooth till now. The other drive, Hitachi IDE one I had for about 4 years, removed it always took it with me to mates and it always works fine. What happened to my SATA drive then?
Can someone please help?
Tried a differant SATA power inout into it? Is it making a clicking sound?
Posted on Mar 17, 2009
Hi u there?
Posted on Jul 29, 2009
Sir,i have install 3 sata hdd on my motherboard gigabyte 945 GCM-S2L 1. 160gb 2. 500gb 3. 1 tb. my pc many times hangs on bootup and freezes then i disconnect the cable to turn off. how to fix that...
Do extensive diagnostic tests:
1. Set BIOS to default settings and do not use overclock settings, check.
2. Memory test, download ISO image, burn it onto cd and boot from it.
If memory fails after several hours testing: Replace memory
3. Flash the latest (original)[beta] BIOS version.
4. Connect just one (1) harddisk and test for longer time. *
5. Add second harddisk and test for longer time. *
6. Add third harddisk and test for longer time. *
* If connecting or adding harddisk leads to freezes, exchange that harddisk and retest.
Sep 25, 2011 | Gigabyte GA-945GCM-s2C socket LGA775...
Hp laptop having CPU T8100 or above and windows XP professional
Try this model in HP - HP Pavilion dv9700t CTO Entertainment Notebook PC.HP ? Intel Core 2 Duo T9300 Processor (2.50 GHz, 6 MB L2 Cache, 800MHz FSB) ? 17.0" WSXGA+ High-Definition HP BrightView Widescreen Display (1680 x 1050) ? 512MB NVIDIA GeForce 8600M GS ? 2GB DDR2 System Memory (2 Dimm) ? 240GB 7200RPM SATA Dual Hard Drive (120GB x 2) ? 32-bit Windows Vista Home Premium Webcam, fingerprint. Call to this toll free number : - 1800 42 54 999 for HP reseller showrooms.
Jun 06, 2009 | HP RP5700 POINT OF SALE E6400 CPU 80GB...
I have gigabyte series g31 m-es2L i want use memory pc 5300.... it's support with this mainboard ???? tx pls reply to : it_mid@yahoo.com
First, clarification: the closest Gigabyte model is GA-G31M-ES2L... there is no "g31 m-es2L"
For this kind of question the easiest way to find the answer is from the manufacturer: Gigabyte
A quick search of their products results in:
http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ClassValue=Motherboard&ProductID=2889&ProductName=GA-G31M-ES2L
which states that up to 800mhz DDR2 (PC6400) is supported
( 667mhz (PC5300) is also supported. )
Generally with motherboards, if a higher speed of memory is supported, the lower speeds are also supported.
PS: mhz times 8 yields the PCxxxx number, PCxxxx divided by 8 yields the mhz number
Feb 09, 2009 | Gigabyte Matx Intel G31 775 DDR2-800...
New Computer
Hi im David,
1. To start to buying a computer, you need a Standard ATX case, they sell only ATX cases so you can choose one at the shop that suits you. Then you might want to get a power supply because the pne that comes with the case will not supply enought power. You would want at least 550W. I recomment the Coolermaster 660W.
2. You will then need to think what Brand CPU your going to use. These days AMD is not making the best CPU's So i recommend Intel. Based on what you want to do and what the shop has, i would get the Dual Core E7200 (2.53 GHz 3MB Cache) or the E8400 (3.0GHz 6MB Cache). There is no point for buying a Quad core as it is expensive and not many games can use the full extent of the CPU.
3. Once chosen teh brand on the CPU you have to buy a Motherboard that supports the CPU, they only sell One type of Intel CPU and that the LGA 775 so any Intel Motherboard will work with your CPU. I would get Gigabyte GA-EP43-DS3 at $125. Dont bother buying anything higher than $155 unless you got the money and really need it. I psersonally use GA-EP43-DS3 because it has all the features i need like Dual Graphics (not SLI), 3 firewire connections, 12 USB ports, 7.1 Surround Sound, 6 SATA Ports and 4 ram slots.
4. Once gotten your motehrboard you will need RAM. They sell Kingstom and Corsair DDR2 Ram at speed of 800MHz. Corsair is a much better brand but you wont notice much difference between the two of them. 2GB is more than enought if your going to run XP but you will need 4GB for Vista. get 4X1GB and you will get faster speeds than 2X2GB.
5. Getting a Hard Drive. Depending what you are going to store on your Hard drive, you can get different sizes. The bigger the size the cheaper it is per gigabyte. I would get a 500GB. Western Digital and Samsung is quieter than Segate but isnt as fast in speed but you wont notice the difference. Make sure you get 3.5" or if u want you can get a 2.5" but it wont fit anywhere in your case so you will have to rest it soemwhere. It still can be plugged it to your motherboard. I use a 2.5: with my Desktop PC because it reduces noise.
6. Getting an optical Drive. Make sure you get a DVD Burner, they are only $40. YOu may consider getting a Blu-Ray Drive so you can watch Blu-ray movies on your cmputer or use your Computer as a Blu-ray player and plug it in your LCD TV. Blu ray will cost $175 for LG or $215 for Pioneer. Pioneer is better.
7. Next you will need a PCI-Express graphics card. For your games the minimum i would buy would be Gigabyte Nvidia 8400GS. I recommend Gigabyte Nvidia 9600GT 512MB.
8. You may want to buy a monitor, you can choose since its just a monitor.
You can choose any preheripals such as mouse and keuboard. Wireless mouse is recommend but theres no point for wireless keyboard unless you plan to sit a few meters away from the computer.
Once bought you can get the shop to buid it for you or you can buid it yourself.
When building yourself, make sure you wear a Electrostatic Discharge Wrist band to prevent damage. Or simply touch the metal of the case to get rid of the static. Do not touch any electrical compunet pins such as CPU pins and CPU socket Pins.
Once made you will need to install an operating system. You can buy one or Download a pirated version.
Oct 10, 2008 | Computers & Internet
Will not display anything when booting up.
does your motherboard has a builtin video card? u probably connected your monitor to it which supposed to be connected to your new installed video card.
Jan 15, 2007 | Gigabyte GA-8N-SLI Motherboard
Samsung SpinPoint T HD501LJ 500 GB SATA Hard Drive Logo
1,233 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
