You can't get audio from HDMI cables. You have to connect the regular AV cables into your sound system first or you can use the digital output from the PS3 into your sound system if you've got the right cables. You'll also have to configure this through the audio settings. This should solve your problem. Let me know if it doesn't.
First I select the digital output and then select the audio output formats that my receiver supports (Doly Digital 5.1 in this case). then you you go back to the previous menu and it says to turn the unit on. Well it is on, the cable is connected but it will not leave this menu. The optical connector symbol on the screen remains dark. it will not leave this menu without cancelling your changes!! What is the problem here?
Thanks!
