Question about Dishwashers
The vent on front of door expels steam in drying cycle and water drips on floor and also gathers under counter top
  • 547 Answers
Change the seal around door
Posted on Feb 18, 2009
Water seems to be gathering and then dripping from under the control panel which is situated in the main fridge, on the back wall, behind the top shelf.
sounds like a bad plugged evaporator drain plug? which then freezes up and moister - water/ ice build up takes place in fridge
Mar 08, 2015 | Refrigerators
I have a ge dishwasher model GSD5211 purchased in may 2006. Water appears to be dripping from under the front ss panel to the bottom of thepanel. I cannot open it to check the source of the leak. Alo found...
You may want to inspect the seal around the door to make sure it's not worn out or has some foreign material stuck to it causing it to not make a watertight seal during operation. If you don't see any problems there, then you should pull the machine out from under the counter to see if the drain hose has been damaged or dislocated. Most dishwashers are fastened to the bottom side of the counter by two brackets. Open the door to the machine and look at the top where it meets the underside of the counter to see how it is fastened. It's usually just two screws. Once you've removed the screws you should be able to gently slide it out and take a look at the drain hose. You may also want to take note of the condition of the floor below the machine to see if there is any long term water damage that either needs to be fixed or will give you an idea of the location of the source of the problem.
Hope this helps!
Jun 25, 2010 | Dishwashers
Water on floor; problem was occassional, but today was a ''flow''. Coming from left-side back corner and noticable on hot water wash cycle; swithced to warm cycle, went to drip. Suspect whatever the mixing...
Upon further investigation (opening up the front panel & top) could tell it was the injector valve (between the mixing valve and tub inlet). You would think after 21-years they would have designed a more robust solution!! Quick trip to the parts store, back together and working fine.
Thanks for letting me vent.
Mar 31, 2010 | Maytag Washing Machines
Is it normal to see steam coming out of the dishwasher in the drying cycle?
Yes, The colder the room its in the more steam you will see. It will look like more steam if sun light is shinning over it. Just like your clothes dryer blowing steam out side. Its just drying.
Oct 30, 2009 | Dishwashers
LG dishwasher is dripping water from vent onto floor
Good that it is working. Recommend you keep a lose eye on the vent on the bottom of the door panel. This model will probably begin leaking again if it has not been retrofit with a kit that LG developed.
Please open a new problem when it starts to leak and please provide the Model and serial number when you do. Good Luck!
Mar 24, 2009 | LG LDF6810ST Stainless Steel Built-in...
Steam coming out near bottom of door causing water to pool
Steam coming out is not normal and you should get it serviced soon. While not dangerous, it probably means that water is leaking inside the door panel from the "Hybrid Drying System" that is a feature which LG uses/touts. Other disheashers use a conventional condensing drying system.
The moist air enters through the internal drying system in the door panel, dry air is added from the outside air with the help of a fan and that air is routed though ducting down to the bottom of the door.
That system is clearly broken. If you have more questions on this, please reply. Good luck!
Mar 19, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
In the spin cycle water leaks onto the floor,
If the hoses at the back are not leaking, you need to check the drain hose lines, aksi check that the machine is not dripping from the inlet valve hose, or because of a leak from the door gasket.
Dec 09, 2008 | Maytag PAV3240A Top Load Washer
Ge dishwasher gld4160looss
Where's the vent on top/or the end of the door under the cabinet? Some steam is normal.
Nov 21, 2008 | GE 24 in. GLD5560LSS Stainless Steel...
Dishwasher maytag 945 awq
Door gasket or sealOver time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Nov 08, 2008 | Maytag MDBH945AWW / MDBH945AWQ /...
The top of the dryer gets very hot, but inside the clothes are not drying. I have to dry the clothes 2 or3 times.regular size load. When I use cotton setting, it's worse. Water gathers along the inside of...
okay this is a easy problem, your dryer is clogged, check your vent hose and make sure it is not kinked, also check your vent duct from wall to outside...What is happening is your heat and lint is not going outside but it is going back into your dryer, causing your dryer to get extremely hot....
your dryer is suffocating
marclavoris/Whites Appliance Repair
Apr 03, 2008 | Dryers
Dishwashers Logo
313 people viewed this question
Top Dishwashers Experts
