Question about Acer Aspire 5315 Notebook
My acer 5315 laptop wont load up got the 2 recoverey disk 1st 1 loads and brings up erocoverey menu but cant do anything else can any1 help me?????? it asks for the user back up image??
  • nath555 Mar 27, 2009
    i took my acer aspire 5315 apart put it bk together turns it on the green light comes on and the fan kicks 4 about 2 seconds and i get nothing on the screen??
    Problem Solver:
  • 10 Answers
If you have an option to skip that, skip that process and go further....
check out if the Hard drive has gone bad
Posted on Feb 18, 2009
Wirless setup
try these drivers
http://laptop-problem.blogspot.in/2012/01/acer-aspire-5315-windows-xp-driver.html
Nov 12, 2013 | Microsoft Windows Vista Home Premium with...
Hi my laptop wont go to windows , it just saying prepare boot to os . can anyone help please
Windows may not be starting due to a driver problem. In any case, see if you can get into the Windows Advanced Options Menu as follows...
1. have the ac adapter connected
2. power on the laptop and watch the screen
3. when the Acer logo is showing, press F8 repeatedly
4. Windows Advanced Options Menu should now start
5. once you are in the Menu, use the up and down arrow keys to select an option
You could try starting with ...
Last Known Good Configuration (your most recent settings that worked)
OR
Safe Mode
where you could do a System Restore to an earlier date when the system was working
If none of this works and you don't have any user data that needs to be saved, then do as follows.
All Acer netbooks have a factory install image on a hidden partition of the hard disk. Suggest you should re-install the original windows factory image. All user data on the C: drive will be cleared by Acer eRecovery which you would start up as follows....
1. have the netbook connected to its AC adapter which is plugged into AC power line
2. power on the netbook and watch the screen as it starts up
3. when the acer logo is showing, hold down the Alt key and press F10 repeatedly
4. until screen indicates Acer eRecovery is starting
5. once eRecovery is loaded, follow the directions given on the screen
May 08, 2011 | Acer Aspire 5315 Notebook
My boot priority order changed now my computer wont go to my desktop
Hi!
Sorry, I hope I was not too late. You can fix priority order issue by restoring the default value of BIOS. You can do that by doing the steps below:
1. Reboot your Acer Aspire 5315 notebook.
2. Wait about 30 seconds until you see the Acer logo on your laptop screen.
3. Press the "F2" key on the keyboard to enter the Acer Aspire 5315 laptop BIOS menu.
4. Select the BIOS option "Load Default Setting" using the arrow keys on your keyboard. Then press "Enter."
5. Press the "F10" key to save the BIOS that is reset to the factory default settings.
Hope this helps.
Apr 16, 2011 | Acer Aspire 5315 Notebook
MY LAPTOP IS ACER ASPIRE 5315/2492 WINDOWS
it seems u have done every try.So now i recommend u too backup ur necessary files and install a fresh copy of windows via cd.
I recommend u to use xp or windows 7.
Mar 31, 2010 | Acer Aspire 5315 Notebook
Windows wont boot
reinstall your os again not update, may be you will not facing the problem again.
Laptop screen wont work.
Assuming you don't have 2 drives installed in your laptop then you will need to get a windows system disk or install disk and boot up with this in the laptop to load windows whatever into your hard drive and set your laptop up to run on the new drive. Here is Microsoft's tutorial on how to install and set up windows:http://www.microsoft.com/windowsxp/using/setup/winxp/default.mspx
Hope this helps you.
Mar 29, 2009 | Acer Aspire 5315 Notebook
Cannot reload operating system
for xp in acer 5315 you have to load sata driver from external floppy disk with floppy and press F6 optin at starting point of xp boot disk while booting.
and follow the instraction when ask for sata driver spacification.
and enjoy loading xp.
Jan 19, 2009 | Acer Aspire 5315 Notebook
Blank screen
Have you tried starting in the 'Safe Mode?'
If not, either F5 or F8 (right after anything  appears on the screen) will bring up a short menu to allow you to choose the boot mode; choose the Safe Mode. This loads only the most basic windows files and will let you do some fundamental checking of the hard drive and Win installation.
If you can get that far, Click on 'Start,' then 'Run' and enter 'rstrui' and OK. This should start the Restore routine.
If it does, choose 'Restore to an earlier date.' Hopefully you have had Restore turned on and then you will have a calendar with light and bold dates. Choose a date a few days in the past and let it run.
This may or may not put you back in operation.
Jan 11, 2009 | Acer Aspire 5315 Notebook
Broken??
If the computer is only a couple weeks old, you need to cantact Acer for technical support under the warranty.
http://www.acerpanam.com/synapse/forms/webpage.cfm?siteid=7293&areaid=7&website=AcerPanAm.com/us
Click the ESupport link in upper right corner
Jul 06, 2008 | Acer Aspire 5315 Notebook
Acer Aspire 5315 Notebook Logo
70 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
