Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Washer won't rinse, drain or spin.
My washer filled and agitated just fine but at the pause/cool down step it stopped. I could manually move the control to rinse and it would work for a few minutes but then it would stop and not drain. The control timer made a faint whirring noise and then nothing. I tried the rinse on delicate with the same results. I checked the lid sensor and it is clicking so it is fine. I tried starting from the start and now nothing at all. I think it is the timer but want a second opinion.
  • Anonymous Mar 03, 2009
    i have the same exact problem
  • 117 Answers
My guess would be that you have a faulty timer if you can manually move it and the operation of the washer resumes.
http://tclaundryrepair.com/
Posted on Feb 26, 2009
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
Aug 26, 2011 | Maytag Washing Machines
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
WASHER FILLS WITH WATER AND AGITATES FOREVER. I
Based on your discription you do need a new timer.
Jun 11, 2010 | Hardware & Accessories
Washer will not agitate/spin.
The lid switch is fine. The timer needs to be replaced.
Jul 22, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine does not drain during rinse cycle?
Turn timer to rinse cycle. let fill up and agitate. when it stops agitating it should pause then start to pump water out. After about 2 minutes it should pause for 3-5 seconds then start again and spin. If it starts the first time and never stops it will just continue to pump but no spin. The 3-5 second pause allows the transmission to shift to spin. If it does not do this the problem is your timer. You may need to do this a few times to verify the problem.
If that is not the problem it is likely that you need a new clutch. You will need a technician to install a new clutch for you
May 17, 2009 | Whirlpool LSQ9600L Top Load Washer
Washer only works by manually advancing the dial.
yes this sounds like a timer it sounds like it is getting stuck in the cycle. replace the timer and this will clear up the problem
Dec 29, 2008 | Maytag SAV3710AWW Washer
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
146 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
