Question about E-Machines eMachines Desktop PC
MY COMPUTER WANT LET ME GO TO NEXT STEP
AFTER SETTING UP MY COMPUTER IT TELL ME TO NAME THE COMPUTER AFTER I DO THIS THE COMPUTER HOUR GLASS JUS KEEPES ON SPINING WHAT DO I DO
  • Ralph  Walekr
    Ralph Walekr May 11, 2010
    What name or you trying to give it?
    What operation system are you using?
  • Peter Steiert
    Peter Steiert May 11, 2010
    Did you just buy this computer? Who did you buy it from?
    You might have to take the computer back to the manufacturer to get it replaced, if you just bought this computer replacing it should be free of charge.
    Scholar:
  • 164 Answers
Try using the name ADMIN...
or leave it blank. It is not necessary to give it any real name. DO NOT USE YOURS!
Depending on the processor and RAM, it can take 5 minutes.
Posted on Feb 19, 2009
How connect a tcp ip printer.
Hi Kumar,
You can modify or change port in the printer driver to connect it through LAN cable. Please notice whether you use static or dynamic ip address. Please follow below step.
In the following step we will modify your existing USB connection. Check it out!
Step:
  • Open printer driver list.
  • Right click on the printer drive name (e.g Canon IR2270).
  • Select Properties.
  • Click Ports tab.
  • Click Add Port, then select Standard TCP/IP Port.
  • Click New Port.
  • Click Next on add port wizard menu.
  • Type IP Address (for static ip setting) or Printer Name (DHCP), then click Next (computer will search the printer).
  • When the printer has been found, finish the wizard.
  • Close Add Port menu.
  • Now you have new port represented by IP Address or Printer Name (with checked box active) in port list .
  • Click Apply.
Bingo! Now your printer ready to print via LAN. Sometimes printing right after setting this new port not always succeed. Don't be panic. Restart both of printer and the computer.
Next time you want to connect the printer via USB port so you change port back to USB. Just simply check on the check box next to USB Port in port list and click apply. You may need to restart both printer and computer too :)
Have a nice day!
Printer Clinic
Jan 13, 2014 | Canon iR2270
I have a Samsung Duos B7722 and I have a problem with a message that appears whenever I open pictures. The message is as follows: "Not Enough Resources. Close some applications and try again."...
it may solve through widget setting just remove some widgets from the widget tab on the screen 1 of ur duos phn and it can be done in the just go in display and light setting in the phone stteing menu thn widget n thn jus unmark the not reqired widget its like Setting>display and light>widget>unmark unnessary widget.....thts it hopefully it will work jus try......
Jul 29, 2011 | Cell Phones
HOW TO INSTALL CANON MF 4100 PRINER DRIVER
hi
just follow the step
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} · step 1 Place the computer and printer next to each other and make sure that all the wires are connected to both the printer and the computer.
· Step 2 Turn the computer on and wait for it to boot up.
· Step 3 Plug the printer into the wall and then take the USB cord that is attached to the printer and plug it into the appropriate port on the computer.
· Step 4 Turn the printer on.
· Step 5 Click on "Start menu" and go to the "Control panel".
· Step 6 Find "Printers and hardware clip_image001.gif" box and click on it.
· Step 7 Take mouse and click "Add printer".
· Step 8 When you see "Welcome to the add printer wizard," hit "Next."
· Step 9 Click "Automatically detect and install plug and play printer" on the add printer wizard page. Click "Next."
· Step 10 Installing the printer will begin if the network can automatically detect it. Otherwise, the message unable to detect will pop up and you will be prompted to install the printer manually. Click "Next."
· Step 11 Select printer port. Use the recommended port for best set up options. Click "Next."
· Step 12 Pick manufacturer and printer. Click "Next."
· Step 13 Type a name or confirm name if it appears in the box and set printer as default printer if wish. Click "Next."
· Step 14 Print a test page to be sure printer is set up and online. Click "Next."
· Step 15 Receive a successful completion of installation of printer message. Click "Finish."
Aug 05, 2010 | Computers & Internet
How to install (assemblw) hp d2668
hi
  • Place the computer and printer next to each other and make sure that all the wires are connected to both the printer and the computer.
  • Step 2 Turn the computer on and wait for it to boot up.
  • Step 3 Plug the printer into the wall and then take the USB cord that is attached to the printer and plug it into the appropriate port on the computer.
  • Step 4 Turn the printer on.
  • Step 5 Click on "Start menu" and go to the "Control panel".
  • Step 6 Find "Printers and hardware" box and click on it.
  • Step 7 Take mouse and click "Add printer".
  • Step 8 When you see "Welcome to the add printer wizard," hit "Next."
  • Step 9 Click "Automatically detect and install plug and play printer" on the add printer wizard page. Click "Next."
  • Step 10 Installing the printer will begin if the network can automatically detect it. Otherwise, the message unable to detect will pop up and you will be prompted to install the printer manually. Click "Next."
  • Step 11 Select printer port. Use the recommended port for best set up options. Click "Next."
  • Step 12 Pick manufacturer and printer. Click "Next."
  • Step 13 Type a name or confirm name if it appears in the box and set printer as default printer if wish. Click "Next."
  • Step 14 Print a test page to be sure printer is set up and online. Click "Next."
  • Step 15 Receive a successful completion of installation of printer message. Click "Finish."
  • Jul 12, 2010 | HP Office Equipment & Supplies
    How to get wap setting for imate jaq
    Please tell me first are you wap setting to your mobile...If your mobile then first step is to click on start----then setting-----click connection tab-----click connection icon-----click on advance tab-----click on select network button-----program that automatically connect to the internet----should connect using-----click new button-----under this type setting name-----click on modem tab-----click on the new button-----enter a name for the connection-----select modem(cellular line gprs)-----click next------access point name(depen on your connection)----next-----click on finish----click on proxy setting tab------check this network connects to the internet-----check this network uses a proxy server to connect to the internet----click advance------select wap----in server type(should be a ip address number as on your connection)-----in port type----(should be a port number as on your connection)------click ok-----secure wap in server type(should be a ip address number as on your connection)-----in port type----(should be a port number as on your connection)------click ok-----click ok-----click ok-----
    Thats all please do this i thing then you can access wap site in your mobile......
    Feb 16, 2010 | i-mate JAQ Pocket PC
    Lost disk and need to reinstall printer. How do I install my printer without a disk?
    Download a driver from manufacturers website or go to the place where you bought it and enquire about a duplicate disc .
    OR
    Go to your computer website...example if u r using HP go to http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=445441&lc=en&cc=us&dlc=en&submit.y=0&submit.x=0&lang=en&cc=us
    & select your OS and do what they are telling
    OR Go through the instructions given below
    Instructions
    Step 1:Place the computer and printer next to each other and make sure that all the wires are connected to both the printer and the computer.
    Step 2:Turn the computer on and wait for it to boot up.
    Step 3:Plug the printer into the wall and then take the USB cord that is attached to the printer and plug it into the appropriate port on the computer.
    Step 4:Turn the printer on.
    Step 5:Click on "Start menu" and go to the "Control panel".
    Step 6:Find "Printers and hardware" box and click on it.
    Step 7:Take mouse and click "Add printer".
    Step 8:When you see "Welcome to the add printer wizard," hit "Next."
    Step 9:Click "Automatically detect and install plug and play printer" on the add printer wizard page. Click "Next."
    Step 10:Installing the printer will begin if the network can automatically detect it. Otherwise, the message unable to detect will pop up and you will be prompted to install the printer manually. Click "Next."
    Step 11:Select printer port. Use the recommended port for best set up options. Click "Next."
    Step 12:Pick manufacturer and printer. Click "Next."
    Step 13:Type a name or confirm name if it appears in the box and set printer as default printer if wish. Click "Next."
    Step 14:Print a test page to be sure printer is set up and online. Click "Next."
    Step 15:Receive a successful completion of installation of printer message. Click "Finish."
    I think this will heip
    Feb 03, 2010 | HP OfficeJet 6310 All-in-One Printer...
    Craig 4gb mp3 model cmp616f does nothing but blink hour glass
    left craig mp3/video player model cmp616f on while disconnected from computer over night. connected to computer next day seen hour glaas 2 or 3 seconds then craig blue screen . it connected to computer and stated charging again seems to have reset its noon now dec 28 2009 ill post again results when fully charged and try to use.
    Dec 28, 2009 | Craig CMP168C MP3 Player
    My craig mp4 player shows an hour glass and will not work.
    Turn on the MP4 player and let the battery go all the way dead. Plug it back into a computer and mine reset.
    Dec 09, 2009 | Craig CMP168C MP3 Player
    HOW DO YOU RESET A SLICK MP3
    it doesnt let mii put music on it or it doesnt want to go to the main menu it jus has an hour glass picture on it
    Nov 24, 2009 | Bell Technology Techsolo Slick Stick MP3...
    E-Machines eMachines Desktop PC Logo
    Top E-Machines Computers & Internet Experts
    Alun Cox
    Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
