My wiring harness for my trailer hookup seems different on my ford truck than on my GM is that possible? The fuses all look good and my marker lights are not working on my truck bed either.
SOURCE: 1982 ford stepside. no brake lights. tried putting
Check the brake switch on the back of the brake pedal up behind the dash it should have to wires going to it and will be about 2 1/2 inchs long and threaded. one end will hit the brake pedal on the back side it will look like this >L where the arrow points you will see the switch it will have a quick disconnect on the back of it, and if you take a paper clip and install on the back side intot he wire harness quick disconnet swith look to see if the brake lights are on. If they are on then the switch is bad. to replace it has a half inch lock nut you can back off 1/4 turn then unscrew it out any parts store will carry it. It lists for 14.95 it could be the turn signal switch too. Now this is assuming you checked the fuses also this has two buttons on it and it may be the plug is loose. here is the web page the brake switch is at the bottom and the turn signal switch is about midway. This has a picture with it and price as well. Thanks for using fix-ya http://www.jcwhitney.com/switches/c1643j1s17.jcwx
SOURCE: Ford F-350 Trailer blinkers not working
Check the 20amp fuse that is in a small fuse box close to the fire wall and is mounted to the fender well. you will not find it in the power distribution box,,in my '97 ford pu is all by it self,and the small fuse box is about 3/4"W X 1/12L and it only has two fuses in it a 20amp wich that is the one you need to check and a 5 amp for a diferen purpose.let me know if it helps Email [email protected]
SOURCE: no left turn/brake light on trailer
The ford f250 has a saparate fuse panel for the trailor lights if using the ford wiring connectors and no ( aftermarket parts ) The stock fuse panel has the relays and fuses in a separate fuse panel near the brake master cylinder. The main power for the trailor brakes( If it has them) comes off the power distrbution box just to the left of the brake pedal hi on the firewall in the floorpan. The most likly cause after the fuses test good is the trailor itself. The flat four wire connector is easy to test with 12 volts ( jump box, Car battery, Battery charger, jumper cables) connect the grond ( negitive to the ground ( toung, or white wire in the plug ) Its the one thats different or oppisit the others. touch the positive to each one of the other wires one at a time to see if the lights come on. green is left turn and stop yellow is right turn and stop and brown is running lights.as long as the connections don't make a strong spark and the lights come on like described then the problem can be in the truck. The trailor doesnt light though and doesnt spark hard while test the lights and one wire doesnt light something leave it connected and start at the bulb and work forward bcak to the connector with a test light ( an ice pick device with a light bulb and a ground wire with an allagator clip to hook to ground.) Tes a good wire first to be sure the light is working and the ground your using is a good one. with say the running lights on remove the bulb and probe the socket base at the bulb base connectors and see the light work the other connector will be the brake turn light. Change to the wire at the connector that runs the light to be tested and see if it lights the test light. if not trace the wire to the front of the trailor or just run a new wire from the connector al the way to the light base. If this proves to be too much troble (hard to trace all the wires appear old and crodded, just dept store, or discount auto parts store buy a universal trailor lighting kit its all wired up and ready to go for less than $40 Has the wire and the two lights, install the lights and thread the wire, plug in and your done! Again if the truck is bad make sure the regular lights work right first. then again with the test light grounded test all the plugs wires at the plug with the tailor disconnectedand with the hazard flashers on and the parkings lights on all wires should light the test light except the white grond and it shouldn't even light dimmly. if it does repair where it connects to the frame of the truck . most problems when you find them on a system that used to work OK are crodded connections and broken wires always cheack the bulbs and replace regularly with new ones as trailors carrode and bounce and pound mre than the truck and heavy dudy bulbs should be used most common are the 1157 that can be upgraded to the 2057 fit the same and sometimes even cost the same. If you think your going to do this alot 10 blub packages of bulbs cost about the same as 2 bubble pacs of two blubs or 6 blubs for free. Brand name bulbs last longer and fail for vibration less than the never heard of bulbs that all of the stores are selling now. Wagner GE Sylviania and others you reconize may save you more than a traffic stop. they may unknowingly save you from the jeporardly that the policeman in the long run is trying to save you from. They got their job to do, we hired em, lets not have them work on us the other guy will be fine. The truck follow the dead wire that should be on to the front of the truck or find it at the front of the truck turned on and cut it install a new wire to the rear of the truck cut the wire near the connector and connect your new wire. If you would like the connection to last solder and heat shrink are best, crimp connections work and are faster but need to be crimped with the right tool again if you expect to do this kind of repair very often the more expensive tools do abetter job The connectors can be bought as heat shrink and are best sealed with a heat gun ( an extra hot blow drier for hair ) A lighter or a propane torch works but working with fire is just that you know who you are that can control this kind of work if you drop things and can't get the keys into the locks in your daily life on the first try don't use flame. Tape will work but seems to never last very long again the brand name tape the costs so muck you can't beleive it the cme from the name brand auto parts store and is their Hi dollar choice you may do just fine carefully installed on clean wire and connectors. Even well done tapedd connections seem to fail in around a year. A seasoned mechanic in a pro shop is likly to use the right techniques and is going to charge for his time but may save you big money down the road as the wiring will stay good and the accidents caused by lights not working right and major wiring fires that require major harness repairs can be avoided. Most vehicals don't have wire harnesses made as replacement parts so if you need on the manufacturer may make you one but they will make you wait awhile and they'll get way deep in your pocket or credit card account at the pay window to the point you may have to call the bank to see why not. Were Talking over $1000 for a part harness there can be as many as three or four for some cars imports can be as few as one and you better believe that some older vehicals are totalled easyly by needing the whole harness and paying to have it installed. Figure $1000 install fee I've been the man hired more than once. even at the dealers I've worked at. The boss treats me real nice when the job is going. as the customers money burns down hardest of any job going in the shop. Don't burn one if you can help it. Always be ready to disconnect the battery and try it before you get going. even a helper to disconnect as soon as troble shows is best. Thats all the helper is allowed to do too! Have fun anything can be fixed with money just your persoal saftey can be way out there in the area where money can't buy. Be careful and take you time working on live circuits. 12 volts won't get you but the hybride cars and spark systems have the power to kill you and most of the circuits are marked. If in dought have a pro do it and consider the money well spent.
SOURCE: 98 expedition trailer brake and blinker lights stopped working
check you bulb and there sockets its possible that you burned out one of the two
SOURCE: tail light wiring connectors and wiring diagram
A test light checking each connector would be faster and easier to do. Maybe somebody may have a illustration for you but by far a simple test light is all you need with a helper turning on the different lights as you check them out and writing all your findings down
4-Way
5-Way
6-Way
7-Way
Green
Yellow
Brown
White
Red
Blue
Purple
Right Turn & Brake
Left Turn & Brake
Tail Lights
Ground
Backup Lights
Electric Brakes
Auxiliary Power
Green- Right Turn and Brake
Yellow- Left Turn and Brake
Brown- Tail Lights
White- Ground
Red- Reverse (Back Up) Lights
Blue- Electric Brakes
Purple- Auxiliary Power
It sounds like your green and yello wires are shorted together somewhere along the length of the harness. I would check the wires on the trailer first. Easier yet, if you have another trailer to connec or access to another to use for testing, connect to it and see if the problem repeats; if it does the trouble is in the vehicle's wiring.
