Question about EliteGroup P4M800PRO-M Motherboard
I switched out the power supply on an elitegroup p4m800pro-m. I was originally using a 300w and now using a 680w, but now my computer wont even start up. Any input?
  • 5 more comments
  • guvianii Feb 18, 2009
    I don't wanna try a cmos cuz I can't even get the comp to power on at all. I don't even have a chance to get into bios. My power supply makes a little short high pitch sound when i turn it off. Not sure if that means anything
  • guvianii Feb 19, 2009
    i tried both power supplies and still nothing. Now my next question is, will the front panel connectors have anything to do with it? I'm assuming if they are in the wrong place then the comp won't show that it's getting power?
    yeah, it's just not doing anything at all. Right now i am trying to find a diagram for the motherboard since i don't have the manuel
    thanks alot :) downloading now. I'll let you know what happens
  • Peter Steiert
    Peter Steiert May 11, 2010
    Correct, if a jumper is misplaced or the power button switch connector is misplaced the computer will never start. Is that what is happening? Is your computer not starting at all? No noise, nothing budges? If so then there is the possibility you moved a jumper or you placed the power button connection on the wrong prongs.
  • Peter Steiert
    Does your old 300W still work? If so, as was suggested by Smithbrother, your new 680W might be bad. If it is bad, get it returned and buy a more reliable brand such as the PC Power & Cooling brand available on this website. Just search for PC Power Cooling and you will get a list of all their products.They are the most reliable brand single-rail PSU you can find.
  • Peter Steiert
    Try a CMOS reset then get back to us.
    Sergeant:
  • 219 Answers
Do you have the Elitegroup P4M800Pro-M? If so here is the manual:
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?DetailID=574&CategoryID=1&DetailName=Feature&MenuID=44&LanID=0
It should contain instructions on how to insert the power button cable(s) properly.
Posted on Feb 19, 2009
  • Peter Steiert
    Peter Steiert Feb 19, 2009
    Alright, I hope you get it fixed. Never fun to exchange broken parts.
    President:
  • 2,692 Answers
I believe that your power supply may be bad. If it is new , send it back. I have had that high pitched sound before and it usually indicates a capasitor going or gone bad.
Posted on Feb 18, 2009
Which vga card compatible wit P4M800PRO-M2, Pci or AGP?
Hi. Thanks for your question.
Video card compatible with your motherboard is an AGP 8x.
Hope this helped. For more info about your motherboard please see this link------>http://www.dealtime.com/Elitegroup-ECS-P4M800PRO-M2-2-0-Via-Socket-775-MicroATX-Motherboard-Audio-VGA-AGP-8x-10-100-Ethernet/prices
Thank you for using FixYa.
Dec 17, 2010 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
Had to change p/supply installed new 680w apower reinstalled powered up fine shut down moved to where pc would sit plugged in and nothing pulled apart again checked connects powered up fine shut down and...
you could open up the power supply and look for any fuses that may have blown, the ones ive seen are the glass type and are cheap to replace and easy to find at radio shack just take the blown fuse with you and replace with the exact amps. and make sure that everything is unplugged from the wall and be very cautious around the large cylinders inside the power supply aka "capacitors" they can hold a residual charge and WILL harm you
Jan 13, 2010 | EliteGroup GF7050VT-M Motherboard
How to reset this motherboard? P4M800PRO-M2 (V2.0) from elitegroup.thanks
remove power lead and internal battery for 5 mins then replace all and it will be reset to manufacturer date and settings
Oct 21, 2009 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
What power supply should I buy for a gt4022
The computer has a 300W powersupply from factory, I would buy a 400W powersuplly for it, depending what components it has inside, if the video card is upgraded to a new one 300W won't be enought, and in that case even 500W might be a good choise. if its with the original parts from the factory it should do fine with either 300W or 400W. ATX here are powersupplies: http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=40000058&Description=400W%20ATX%20power%20supply&name=Power%20Supplies note that if the link isn't clickable then select it completely, copy and then paste it to your addressline to open the page.
Jun 04, 2009 | Gateway GT4022 PC Desktop
Power swith order
It does not matter -- pressing the "power" button on the front of the computer closes the circuit, and the motherboard boots itself.
May 19, 2009 | EliteGroup P4M800PRO-M Motherboard
Power supply burn
If the supply was the previous problem, the motherboard may be destroyed as well. Try it with just the motherboard, PC speaker, processor/cooler and power supply. If there are beeps, then the motherboard is ok and it may be the memory.
Nov 04, 2008 | EliteGroup P4M800PRO-M478 Motherboard
No power
Dear Sir,
Try Changing the Power Supply.
Jun 21, 2008 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
EliteGroup P4M800PRO-M Motherboard Logo
111 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
