Question about Apex Digital AT3208S 32" TV
Apex tv I am having the same problem, my tv has no picture. Someone mentioned something about a fuse. Where is the fuse located on the apex tv 19 inch model?
    Problem Solver:
  • 9 Answers
Should be inside the back cover on the left hand side toward the rear of the television
Posted on Feb 18, 2009
My 19 inch Apex tv will not turn on with of without the remote Should I just throw it away or is there something I can do to fix it?
First, I would suggest listing it on Craigslist or your local Freecycle if it's determined that you can't fix it. Generally, someone out there can at least scrap it out for parts or recyclable materials.
Now, to the original question. Was it working prior to hooking it to the VCR to begin with? Or did it stop working before you tried hooking it to the VCR?
There are multiple things that could be wrong, the worst one being that something burned out inside the power supply in the TV. Generally, if that happens, the replacement part is higher than buying a new TV, unfortunately. You could search you local yellow pages (physically or online) to find a repair shop, and call them for advice. They will often tell you whether or not something is worth fixing or not, or at least give you a price estimate, and you could decide whether it's worth it.
If it's ruined, I would definitely suggest listing it on Craigslist or Freecycle, and leave it out on the curb or in your parking lot, where whoever wants it need never meet you in person.
Aug 25, 2015 | Apex Digital LD1919 19 in. LCD TV
My 70 inch tv won't turn on, it was working
smell in the back on either side. if you can smell something like hot or burnt plastic/rubber it would be your flyback transformer. You could also check the fuse. It would be located inside where the cord goes in. If you have no knowledge of electric,I suggest you have someone who does check the fuse.
Sep 09, 2014 | Televison & Video
Apex LD4088 no picture
The inverter is the usual suspect with that symptom. It may be hard to find a replacement inverter for an apex model. But you might be able to get one from www.tvrepairworld.com
Oct 29, 2012 | Apex Digital LD4088 LCD TV
My tv is locked
It sounds like the manufacturers are asking you to get it looked at by an engineer! Try their website, maybe they will have a firmware download or a key combination that can be pressed to force the system to re-boot when powering up, something like the sky+box has. Try and press the channel up & down buttons while pressing the on button, or maybe it'll be another combination, it's worth experimenting before you get an engineer out. Hope this helps
Jul 17, 2009 | Apex Digital AT2702 27" TV
Hdmi cable location???
Click HERE to see HDMI Jack image, if it is there at back of TV then OK and if do not, then TV has No HDMI facility.
Apr 28, 2009 | Apex Digital GB43HD09 43" Rear Projection...
Tv screen is normal, then green then off. Please help
It can be one of two items. The green output transistor or the green cathode has developed a short.
Jan 10, 2009 | Sylvania Televison & Video
Apex TV
it may be a little late for your answer, but it takes a 5A 125V fuse commonly found in christmas lighting...Ace Hardware has them for a bout $1.50 for two....
the problem is this, something caused your fuse to blow...so if yours is like mine, you'll blow a fuse everytime you put one in because there's a short in the circuitry...which means either get a degree in electrical engineering, or buy a new tv.
Apr 29, 2008 | Apex Digital AT3208S 32" TV
Apex 43 inch tv
Convergence is when you aim all three of the projectors, your tv has three, so that the images they produce all line up with each other. This usually doesn't generate a white line across the middle of the screen though, there is a button on the front panel of your set that automatically converges the three projectors, you can try using that.
Nov 06, 2007 | Apex Digital GB4308 43" Rear Projection...
Tv went off.
i have the exact same problem except with a different tv model.and i cant get help.
Jun 01, 2007 | GE 19GT357 19" TV
Apex Digital AT3208S 32" TV Logo
529 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
